Home / Autumn Double Star Tour
by PJ Anway 10/15/03 | Email Author
 Voice your opinion about this topic in the forums
When the change of seasons comes to the Upper Peninsula of Michigan it hardly goes unnoticed. Gone is the plush vegetation of summer that covered the forested landscape; it has been replaced by a rather desolate outline of barren open branches devoid of leaves. At first the new setting seems hopelessly abandoned, but with a closer look and some contemplation you discover that a haunting beauty remains.
Such dramatic contrast is not the sole possession of the earthly scene. The observable universe of the evening sky undergoes a similar transformation. The densely populated caverns of the Summer Milky Way are setting in the west, leaving only the open figures of autumn's constellations that seem quite sparse in comparison. One look at the 84-hour exposure made by the Hubbell Telescope in northern Adromeda helps us to appreciate that this is not really the case, the sky teems with celestial wonders unimagined. However, for the backyard sky-watcher with much more modest equipment, the autumn sky presents a challenge when compiling one's observing list; even the seasoned observer may find the pickings slim. Including binary stars in with your "deep sky" targets, may help to fill the voids.
Binary Stars
The term "binary star" was coined by William Herschel in 1802 to describe "the union of two stars that are formed together in one system, by the laws of attraction." Often they are called double stars and they can be both technically challenging and aesthetically pleasing. The former quality appeals to some and with practice, binary star systems can be carefully measured for both separation (the distance between the components) and position angle (the angle formed by a line plotted due north from the primary star and a line plotted between the primary and secondary stars). In time these measurements can reach a high enough level of accuracy to be used in determining the orbits of these systems. However, with the exception of some with very interesting and shorter orbits, I prefer the latter quality of aesthetic beauty. I observe them for enjoyment and find some to be very captivating. I'm not alone; even those who pursued extensive scientific studies of binary systems, on occasion, made heart felt exclamations over their beauty.
The double stars I have chosen from many dwelling among the autumn constellations are some of the most beautiful or interesting or both. Sixteen specimens are listed by right ascension and a small finder chart and drawing are made for each. My hope is that you will enjoy them enough to include double stars as a regular part of your observing list in the future.
The Target List
As you look over the target list, you might notice that all the primary stars are bright enough to be seen with the naked eye from a dark viewing site, I can see all of them from front yard on dark moonless nights. This should help the beginning observer, in that he can put his red dot, crosshair, or bullseye right on the target. From a less-than-dark site you'll need to star-hop from the stars you can see. Also, you should be able to split all the pairs in a 3" telescope and most in a 2"; that puts them in the range of the equipment of almost every beginning observer. I am able to split all of them with my 80mm f/15 achromat refractor.
The constellations I have included are: Andromeda, Aquarius, Aries, Capricorn, Cetus, Delphinus, Equuleus, Pegasus, Pisces and Triangulum. Again, they are all visible from my observing site at 46°+ latitude, so they should be easy from most locations in the Northern Hemisphere. The star charts were made using Guide astronomy software and the drawings were made using Adobe Photoshop. With the drawings, I tried to give a good idea of what you will see at the eyepiece, however, the orientation of the two stars may differ from the drawing, depending on what equipment you are using.
The Targets
Let's begin in the West and work our way East.
Our first stop is at Alpha Capricorni. The widest and only naked eye double on our tour. The two stars, Alpha1 and Alpha2, together were named Algiedi by the Arabs and the individual stars Prima Giedi and Secunda Giedi respectively. At 48X, I see them both as yellow and just below Alpha1, it's faint secondary is a dim yellow. Actually both stars have companions, making this a double-double, but within the narrow field of view of my long focus 80mm, I can only view three stars at one time.
Alpha Capricorni can be used to help illustrate the importance of limiting magnitude of an instrument in detecting faint doubles. Alpha1 has a second companion about the same distance and direction as the one in my drawing, however it is near magnitude 14, beyond the limit of my 80mm. It is also just beyond the limiting magnitude of a 6-inch telescope as famed double star observer William Smyth mentions it in his "Bedford Catalogue". With reference to A1 and it's dim companion he says: "The telescope, however, shows it to be multiple; but it requires an instrument of no small power to reveal the most minute point of light, which long baffled my attempts to catch it. Indeed, when John Herschel first wrote to me about it, in a letter of the 7th of October, 1831, the case appeared hopeless; but under clock-work motion, on a singularly fine September evening, I caught it in little evanescent flashes, so transient as to recall Burn's snowflakes on a stream. ....its position angle was within estimation, but the distance is nothing more than a vague guess." "The determination ........ may be reserved for one of the new grand telescopes, and will indeed be a triumphant achievement." It says a lot about Smyth's observing skills to even glimpse a 14th magnitude star in his 5.9" refractor at Bedford. However, the "triumphant achievement" would come to S.W. Burnham who listed it in his "General Catalogues of Double Stars" in 1874. Under the designation of BU 295 he says: "The faint star was added with the Washington 26-inch" So what was just beyond the limiting magnitude of Smyth's 6-inch was "caught" and measured by Burnham in a 26-inch. Limiting magnitude of an instrument can be an important factor in splitting faint doubles.
About 2.5° south of Alpha Capricorni is Beta. Dabih, as it is called, is nearly as wide as Alpha, but is just beyond naked-eye visibility; making it a nice binocular double. In my 80mm at 48X it shows nice color contrast with a primary that is yellow and the secondary of bluish white. Smyth saw it as Orange yellow and sky blue as did both Olcott and Flammarion.
Located in the snout of the Dolphin is Gamma Delphini - a beautiful double star. It is one of the most colorful in our tour. It is an exquisite sight in my 80mm at 96X, with subtle shades of yellow and blue. However, this double may show the variations of color often noted by different observers viewing the same object. For Smyth calls it "a beautiful double star" with a yellow primary and a light emerald secondary, while Olcott notes a bluish-green secondary to this "beautiful object" and Flammarion, as well as Couteau saw orange and green. This color difference is mentioned by Crossley in his "Handbook of Double Stars". He states that " B appears to vary in colour; it is given as yellow, green and blue, by different observers." What colors do you see?
To the southeast of Delphinus lies the lopsided pentagon of Equuleus, the little horse. The western most star in this constellation is Epsilon Equulei. I like to use a bit more power on this double and so at 150X in the 80mm the primary appears yellow-white and the secondary an ashy white. Olcott saw white and blue and Smyth, white and lilac. Couteau states that it is a "Good test for a 10-cm refractor" and is obviously referring to the 11" separation of primary and secondary. Yet, Epsilon Equulei is in fact a triple star with the primary having a second, very close companion. The discovery of this dim companion illustrates the effect that orbital motion has on the ability to separate a binary. In her book, "The System of Stars", Agnes Clerke uses Epsilon Equulei to illustrate this. She writes: "Double primaries occur as freely as double satellites; and their common centre of gravity presumably constitutes the focus of attraction for their remote attendants. ... Another specimen is Epsilon Equulei, one of Herschel's pairs, the larger member of which was again divided by Struve in 1835. The feat had become possible through the progress of orbital motion, the continuance of which has since rendered it easy." As orbital motion caused the separation of Epsilon Equulei and it's dim companion to increase, discovery was inevitable.
If Pegusus, the winged horse, were going to win a race "by a nose", it would be Epsilon Pegusi leading the way. At 48X in my 80mm, the colors contrast subtly as yellow and white. Olcott saw then as yellow and violet, while Smyth noted yellow and blue and speaks of a distant third member of violet color. Enif was discovered by John Herschel and he also noted an unusual phenomenon that earned this double the nickname of the "Pendulum Star". Olcott remarks: "Epsilon Pegasi exhibits a phenomenon noted by Herschel; the pendulum-like oscillation of a small star in the same vertical with a large one, when the telescope is swung from side to side; merely and optical illusion of course." To see this effect try bumping the telescope while viewing it.
The Water Carrier, Aquarius, lies directly south of the head of the winged horse. The "Y" formation in this constellation, commonly called the "Water Jar", holds our next target. Zeta Aquarii is the center star of the water jar and is one of my favorite doubles. What it lacks in color, it makes up in elegant symmetry. I can split them with my 80mm at about 90X, but I like them best at about 200X; a pleasant view of two white stars of equal magnitude. Like a pair of headlights on a distant highway, these two twins sit almost exactly on the celestial equator - declination 0°. Though Smyth notes them as very white and white, some observers do see a trace of color in them. Webb, for instance, saw them as greenish-white and pale yellow. Couteau calls them a "good test for a small refractor" and at a separation of 2.1" they are at the limit of a 2-incher's resolving power. Try them with your 60mm, it should be a "good test" indeed. According to Crossley, Zeta Aquarii was first discovered to be double by Christian Mayer in 1777 when it was about 3" in separation and 18° position angle. Therefore, if you observe it at this time you will be seeing it on the exact opposite side of the orbit from where it was at it's discovery.
94 Aquarius lies in pretty remote area near the left knee of water carrier, but with a magnitude of near 5, it is still visible to the naked eye on a dark moonless night. To me at 48X the primary appears yellow/orange with a yellow white companion and Crossley seems to agree noting them as yellow and ash. Yet Flammarion saw rose and blue and Smyth gives pale rose and light emerald, while Olcott merely notes that the colors are contrasting. It is a lovely double, no matter what colors you see.
The next constellation on our tour is Pisces, the fish. It strings out underneath Pegasus and Andromeda and contains four of our target doubles. The first of which is 65 Piscium, a fairly tight yellow-white pair that can be split at 48X, but that I like the view at 150X. Flammarion calls them a delicate, rather luminous couple; and being exactly equal in color and magnitude, "couple" would certainly apply. Like two peas-in-a-pod, it is difficult to tell primary from companion, but if you know you telescope view, you'll note the companion northwest of the primary star.
Psi Piscium is another very equal pair. At 48X they split nicely into a silver-white pair of approximately the same magnitude. When you look at them, try to imagine they are just as they were when Struve measured them over 180 years ago. It shouldn't be hard, cause they have not changed in separation or position angle since their discovery. When Olcott wrote his "Field Book of The Skies" in 1929, he said of Psi Piscium: "No change noted in 130 years"; so for over 200 years now, they have remained 30" and 160°. In his handbook, Crossley affirmed that they were a physical pair (a true binary system), easy to observe, but noting the unchanging physical properties he added - "yet the measurements are very discordant". Over a hundred years later they still seem quite odd. I think Smyth said it best when he remarked - " My observations tend to show fixity."
About 14° to the south of Psi is another wide double star - Zeta Piscium. Olcott calls it "a fine object" and Smyth: "a neat double star". Though both are white in my 80mm at 48X, the secondary seems a different shade of white, probably from the difference in magnitude. Couteau, in his book "Observing Visual Double Stars", notes that Zeta's secondary has a companion also, making this a triple system. This third star in the system (C) is over magnitude 12 and is just 1 arcsecond from it's primary. With a magnitude difference of nearly 6, this close binary would be very difficult to observe. In fact, it was discovered by S.W. Burnham using the 36" Lick refractor! Designated BU 1029, Burnham states that "The measures of C cover a sufficient time to show that the small star belongs to the system" and has a "slow orbital motion", but not as slow as AB. Of the wide pair he says: "The measures of the wide pair (Struve 100) are very numerous and cover, first and last, more than a century. The early distances, however, are inaccurate and inconsistent, and the reliable results commence with the measures of Struve. A few only of the measures are given above, but sufficient to show the relative fixity of these stars." The measurements in his catalog date back as far as 1832 and differ less than an arcsecond in separation and less than a degree in position angle from today - "fixity" seems to describe this double as well.
Excuse me while a digress a little from the west-to-east trek across the autumn sky and move a little further east to pick up the fourth star in Pisces - Alpha. Alrisha, located at the intersection of the tail-fins of Pisces, is easily seen with the naked eye at 4th magnitude. However, this is the one double star on our tour that is beyond the resolution of a 60mm telescope - in theory anyway. Still, the Dawes limit of 1.9 for a 2 inch scope is a theory and who knows, on a perfect night with clean, sharp optics and a keen eye, you just might detect the evidence of a double star. You may not be able to split it cleanly, but any elongation will indicate duplicity. Why not give it your best try? Theories are made to be tested.
Olcott states that it is "difficult for a 3 inch telescope"; I have found it moderately challenging in my 80mm at 200X. At this power in a 3 inch, the colors are too dim to detect, but using his 5.9 inch refractor, Smyth saw " a splendid object" of "pale green and blue". Others have seen a variety of colors and Crossley came to the conclusion that "both stars probably vary in colour and brightness".
Our tour now "retrogrades" a bit from Alrisha to two double stars in Aries, the ram. It is not an impressive constellations made up essentially of three stars; Alpha, Beta and Gamma. It is Gamma or Mesarthim that we take a look at next. Once again, in the 80mm, we find perfectly matched twin stars of the same magnitude and both silvery white. They can be split at 48X, but I feel the best view to be at 150X. They are also unique in that they have, in effect, two position angles; 360° & 0°. Yes they sit one on top of the other, like the makings of a snowman; kind of a prelude of what is soon to follow. Gamma Arietis was first found to be double back in 1664 by Robert Hooke. After commenting on the existence of double stars he says: "Of this kind, the most remarkable is the star in the left horn of Aries, which, whilst I was observing the comet which appeared in the year 1664, and followed till he passed by this star, I took notice that it consisted of two small stars very near together; a like instance to which I have else met within all the heavens."
About 3° northeast of Gamma is Lambda Arietis. With this double we return to one that has very contrasty colors. It is a lovely double that I can easily resolve it in my 80mm at just 48X, where it shows a striking contrast of yellow and bluish-green. Smyth agrees with my perception, but Olcott saw no yellow tint and lists "white and blue". It was discovered by William Herschel in the late 1700's, one of 848 pairs that he would eventually find. He was so enthusiastic about this "new" area of study that he was inspired to write: "The subject has already proved so extensive and still promises so rich a harvest to those who are inclined to be diligent in the pursuit, that I cannot help inviting every lover of astronomy to join with me in observations that must inevitably lead to new discoveries".
Almach (Gamma Andromedae) is one of the most beautiful objects in the sky. It is at the top of my observing list whenever it makes it appearance in the evening sky. I have found myself staying up later that I wanted to on summer nights, waiting for it to clear the trees, so that I can get a glimpse. I'm not alone. Olcott, in his book "In Starland with a Three-inch Telescope", wrote, "Gamma Andromeda is one of the most beautiful double stars in the heavens; the contrasting color of the two stars is very fine". He gives the colors as "yellow or orange and greenish-blue". Couteau writes, "One of the most beautiful systems, orange and emerald". Smyth calls it "a splendid double star, A (primary) orange colour and B (secondary) emerald green; and of these colours I feel pretty positive, although the high authority of Herschel and Struve has pronounced them to be yellow and blue". In my 3 inch, I see them as bright yellow and deep blue, colors that hold up at 96X, 120X or 150X. More then any other star,
Gamma Andromeda gives me the feeling that I'm am seeing a star and it's planet. It's an illusion, but a very nice one and it is enhanced by the fact that the "planet" has a "moon". Crossley wrote: "The duplicity of (Gamma) B was discovered by Otto Struve in 1842." Smyth verifies this when he wrote: "Mr. Bailey put in my hand a letter which he had received from Mr. Struve, in October, 1842, announcing the unlooked for tidings that he had detected Gamma Andromedae to be a triple, and that the companion is composed of two stars of equal size, separated by an interval of less than 0.5 arcseconds." At that distance, I will probably never see the secondary's companion, but still, it nice to dream.
Triangulum is another three-star constellation which forms a triangular shape directly south of Gamma Andromeda. Iota Tranguli is directly south of the "triangle". It is another lovely double and is the third double star in a row that is yellow and blue. To be specific, it appears yellow and dirty blue in my 80mm at 120X. It is the only double star cited by Olcott for Triangulum and he gives the colors as "yellow and blue", calling it "an exquisite pair". Smyth on the other hand, gives topaz-yellow for the primary and green for its companion and Flammarion called it "gold yellow and blue green, very pretty." With a separation of just 4 arcseconds, it is a tight double, but easily split by the 80mm.
Cetus, the whale, holds our final sample of autumn doubles, Gamma Ceti. It is located in the whale's head, 10° due east of Alpha Piscium and north of the famous variable, Mira. Called Kaffaljidhma by the Arabs, Smyth notes that the "colours are finely contrasted"; a pale yellow primary and blue secondary and that is how they look in my 80mm at 150X. He describes them as a "beautiful object" in his 5.9" refractor and they make a good test for a 3". Olcott calls it the "finest double in this region and Flammarion says its "pale yellow and blue", a "charming" double.
Conclusion:
Flammarion's use of the word charming could apply to most doubles stars. They are the jewels of the evening sky and each pair beacons to be examined with care. It is estimated that about 70% of stars are mulitiple in nature, so there are a vast number from which the observer may choose. The most prolific double star observer, F.G.W. Struve, used the Dorplat 9 1/2" achromat over a 13 yr. period to complete a sky survey of 120,000 stars and cataloged the measurements of over 3300 double stars; a feat that required him to examine an average of 400 stars per hour! I am not encouraging anyone to engage in such an endeavor, but rather to observe the more notable ones and get to know them personally. Writing about the observation of double stars in her book, "The System of Stars", Angnes Clerke said: " It would be better to make intimate acquaintance with one than to know a score superficially." Perhaps you might consider adding more than one, to your observing list.
References:
1.The Bedford Catalog - Wiliam H. Smyth (1844)
2.Field Book of The Skies - William T. Olcott (1929)
3.In Starland with a Three-Inch Telescope - William T. Olcott (1909)
4.Observing Visual Double Stars - Paul Couteau (1923)
5.Stars and Curiosities of The Sky - Camille Flammarion (1882)
6.A General Catalogue of 1290 Double Stars - S.W. Burnham (1900)
7.A Handbook of Double Stars - Crossley, Gledhill & Wilson (1879)
8.The System of Stars - Agnes M. Clerke (1905)
Back to Top
Contact Us
CN Reports | Reviews | Articles | Forums | Classifieds | About Us
Copyright© 2004 Ad Libs Advertising.
Privacy Policy
  Search Cloudy Nights
  Advanced Search
Monday, February 8, 2010
Cloudy Nights Supporters
Astronomics
Telescopes  www.astronomics.com
NEAF 2010 - Cloudy Nights Sponsor
