Home / Eyepiece Qualities and Aberrations
by Don Pensack 01/09/06 | Email Author
 Voice your opinion about this topic in the forums
EYEPIECE PARAMETERS AND ABERRATIONS
EYEPIECE QUALITIES AND ABERRATIONS
By Don Pensack
In today's eyepiece market, there is a lot of confusion about eyepiece characteristics and problems. What follows will be a basic guide, and I owe much of my text to innumerable threads from Cloudy Nights and other web sites: "It's easy to stand tall when you stand on the shoulders of giants". My thanks go out to all of you who have made these points clearer. In my humble way, I hope to pass along what I have learned.
I will not review eyepiece types, here, nor go into every possible design parameter for an eyepiece. I will merely define some terms in QUALITIES, and describe the usual problems we see at the telescope in ABERRATIONS.
QUALITIES
  1. Resolution. This can be measured by the use of a grid or line test, but, if those tests are performed, the results are not published, so we do not have tests to compare. Our own eyes tell us which eyepiece is sharper and which is less sharp. There is more to sharpness than merely the center of the field, however, and it is the resolution of the outer perimeter of the fields of view that really set apart the superb eyepieces from the good. If you'd like to make your own test, use small details on the planets and Moon to compare one eyepiece with another. Subtle though they may be, differences will soon display themselves.
  2. Apparent Field of View. This is the size of the field our eye sees when looking into the eyepiece. The manufacturers can quote larger fields of view if allowing distortion at the edge of the field, but that is for later discussion. Suffice it to say, 30-45 degrees is considered a narrow field, 50-60 degrees considered a normal field, 65-70 degrees considered widefield, and 78-85 degrees considered an ultra-wide field of view. Many people have trouble seeing the entire field at once if the field is ultra-wide.
  3. True Field of View. This is determined by the telescope. Essentially, the field stop of the eyepiece encompasses a linear field of view from the telescope. The true field of view depends on the linear scale of that field stop, as determined by the magnification of the eyepiece in that telescope. Telescope focal length divided by eyepiece focal length equals magnification, and (approximately), the eyepiece apparent field divided by the magnification equals the true field. I say approximately because distortion at the edge of the field in an eyepiece changes this relationship somewhat.
  4. Focal length. Eyepieces have intrinsic focal lengths and work as simple magnifiers of the focal image of the telescope. Shorter focal lengths produce higher powers.
  5. Eye relief. This is the distance above the eye lens (the lens closest to the eye in the eyepiece) that the eye can be held and still allow the observer to see the entire field. There is no true standard for measurement of this parameter, but it is usually described as the distance the cornea is from the center of the eye lens. Note that glasses wearers will need 18-20mm or more of this parameter, whereas otherwise eye reliefs can be as short as 8mm without being short enough to cause the eyelashes to continually brush the eyepiece. Eyepieces can be found with shorter eye reliefs than that, but they are not comfortable to use for long periods.
  6. Contrast. This is the most misunderstood of all parameters of performance. It will be very difficult to measure or come up with a system of measurement for this characteristic, because it describes many different characteristics all lumped together into one word. It encompasses light scatter (the reflected/scattered light in the eyepiece FOV), quality of coatings, light transmission, light absorption, surface accuracy of the lenses, and all the aberrations eyepieces are prone to. Ultimately, even the resolution (sharpness) of the eyepiece comes into play when attempting to see the faintest stars. I don't like this term as it is applied to eyepieces, because so many external factors come into play (the mirrors, seeing, transparency, fatigue, eye quality, etc.) that have nothing to do with the eyepiece. At best, a direct comparison of two different eyepieces with the exactly same focal lengths, used in the same scope, on the same night, on the same target, at nearly the same time, and seen by more than one observer, can show you some valid differences. But change any of the factors I mention, and the outcome is suspicious. Apparent field even enters into the picture, as eyepieces of small apparent fields seem to have their fields of view surrounded by blackness. This elimination of peripheral light may allow the maximal opening of the eye's pupil, reduce field brightness, and give a perceived edge to the narrower field of view. Dark adaptation is critical for evaluating contrast, as the better dark adaptation will see fainter details. And finally, eye problems such as cataracts will have profound effects on the contrast evaluation. Contrast is an elusive parameter, yet we all use the word, so I put it in here as a descriptor of eyepieces.
ABERRATIONS
  1. Chromatic Aberration. Eyepieces are made with lenses, and as such do not focus all colors at exactly the same point or with the same resolution. It is a very poor eyepiece that displays "blur circles" of different sizes for different colors on axis, but it is not at all uncommon for even excellent eyepieces to do so at the edge of the field. Sometimes, chromatic aberration is chosen as the "lesser of two evils" when correcting a nasty edge-of-field aberration that may be worse. This aberration can express itself as a color fringe to a bright object like a star or the edge of the Moon, or it can express itself as a slight prismatic effect seen when viewing sideways through the eyepiece (usually on the edge-of-field objects). Also, if an eyepiece design is created to correct for color up to a lateral field size of, say, 50 degrees, but is created with a 60 degree field, that final 10 degrees of field may display color beyond the parameters of the designer, sometimes unpredictably. Daytime use will often show the extent of the problem easier than any nighttime viewing (except, perhaps, on the Moon). Some early eyepiece designs, such as Ramsden or Huyghens, do not correct well for this aberration, and should be avoided.
  2. Field Curvature. Most telescopes' final focal plane is positively curved—that is, the focal plane is convex toward you and slightly curves away as the field of view widens. Fortunately, this curvature is very slight in the narrow fields we observe through the telescope. Nonetheless, it is there. Eyepieces can have either negative (concave toward you) or positive field curvature depending on their designs, and this brings into play the idea of a telescope-eyepiece interaction that points out that eyepieces will perform differently in different scopes. If the negative curvature of the eyepiece matches the positive curvature of the telescope exactly, this can result in a perfectly flat field of view through the eyepiece. Neither the eyepiece nor the telescope is perfect—merely the interaction between the two. This is why evaluating field curvature in an eyepiece is merely a statement of how the curvature appears in your scope. There may be other telescopes in which the eyepiece does not present the same field curvature (though the differences will be slight). Field curvature is seen as a defocusing of the star images at/near the edge of field. If further infocusing (racking the focuser toward the objective) focuses the stars at the edge, then the field curvature is positive. If outfocusing is necessary, then the curvature is negative. Young people, whose eyes can accommodate more focal differences than older people, will be bothered less by this aberration. Ideally, if an eyepiece has no field curvature, all that will display is the very slight curvature from the scope itself. Note that this is NOT the same aberration that causes a feeling of "looking through a fishbowl" when panning the scope.
  3. Angular magnification distortion. This is where the magnification factor at the edge of the field is not the same as it is in the center. I see this all the time in well corrected binoculars, and it is usually applied to correct for rectilinear distortion (I'll discuss this next). In an astronomical usage, this is not a severe aberration, but it does play havoc with trying to figure out what the apparent field or true field of an eyepiece is. The speed with which an object will drift across the FOV in an undriven scope is not linear, but changes with distance from center. This can result in a star-drift timing (to determine the true field of view) that results in a true field that cannot be derived from the apparent field quoted for the eyepiece. As an extreme case, picture sitting in space and watching a city on the Earth as it first appears on the limb, then traverses the disc and finally exits the view. It will move fastest when moving across the center, yet slowly when entering and exiting the FOV. A timing of the passage would lead you to calculate a wider field for the image of the Earth than actual. As a comparison, this would mean, in an eyepiece, that the true field of view is wider than the apparent field would calculate. And the reverse can be true as well. Fortunately for us, this distortion is usually small in eyepieces. Most star drift timings of true field result in only small discrepancies from the apparent field predictions of true field.
  4. Rectilinear distortion. This is the distortion at the edge of the field that causes straight lines to bow in toward the center (called pincushion distortion) or bow out away from the center (called barrel distortion). It is usually unnoticeable in star fields, and is often tolerated to correct for astigmatism, an aberration that is much more easily seen. It does mean that the geometric arrangement of the stars in a field of view will be different at the edge of the field than in the center, but this is easily tolerated. This is a horrible aberration for an eyepiece in binoculars, when used on land objects in the daytime, but is no big deal in an astronomical setting. However, people who pan their scopes back and forth often get nauseated by the "passing through a fishbowl" effect this can cause in the field of view. If your usage involves a lot of scanning of the skies, this may be an aberration you won't want to tolerate. For most of us, though, it is so hard to see that it is quite preferable to astigmatism, the aberration it is designed to hold in check.
  5. Astigmatism. This is caused by the vertical (sagittal) curvature of the eyepiece field being different that the horizontal (tangential) curvature of the eyepiece field. That this is tolerated at all is due to the fact that not all forms of distortion can be corrected at once. If you want low rectilinear distortion, some astigmatism may appear (and the converse, as I previously mentioned). This, in daylight use, causes a defocusing/blurring of the edge of the field of view. At night, it causes the stars at the edge of the field to appear as short radial lines on one side of focus, and short circumferential lines on the other. In focus, the star images may appear slightly blurry or appear like seagulls or bats. This is the most prevalent problem with inexpensive eyepieces, and is worse when the focal ratio of the telescope is short (say, f/4-f/5). Astigmatism can also be caused by tilted elements in the eyepiece housing, or wedge (faces of lenses not in same axial lineup). It can also be caused by an interaction of the eyepiece design with the astigmatism of the telescope's objective or the improper tilt of a mirror, which is why we are looking for an aberration that is equal in all directions from center in the FOV, where the eyepiece is concerned.
  6. Spherical aberration. With multiple elements, this would seem to be tightly controlled in eyepieces, yet it can be an issue. This would manifest itself as different parts of the axial ray (or all rays, for that matter) coming to focus at different places. The result is a blurred image (one that doesn't focus well or seems to have a long range of best focus) that cannot be sharply focused. I will state that the amount of this present in eyepieces is so small compared to the objectives that, to all intents and purposes, it is not there. What tiny amounts are present would largely go unnoticed.
  7. Spherical aberration of the Exit Pupil. This is found in some eyepieces and is described as having different parts of the eyepieces exit pupil come to best focus at different distances from the eye lens. How you would see it is that at different distances away from the eyepiece, you would see the outer edges of the field, or the center, or one edge or the other, but not at the same time. The field of view would appear to have kidney bean-shaped dark areas drifting around the field, depending on where you were holding your eye. There would be only one position for the eye that would result in most of the field of view being visible and in focus at the same time, and you might have to rock your head from side to side to see the edges of the field, one after the other. In essence, the exit pupil of the eyepiece, instead of being a small, circular plane, is a curved surface, usually curving away from the eye in all directions from center. The original Nagler Type 1 eyepieces, especially the 13mm, displayed this aberration, and the correction for it was the genesis of the Nagler Type 2. Most of the other eyepieces exhibiting this characteristic are long focal length eyepieces, or eyepieces with long eye reliefs, though it should be noted that blackout problems with an eyepiece do not necessarily indicate spherical aberration of the exit pupil.
  8. Transmission anomalies by wavelength. This is exemplified by an eyepiece's not transmitting all wavelengths of light with equal intensity. At best, it means a light rolling off of transmission at the extremes of the visual spectrum. At worst, it means a noticeable tint in the field of view, especially on the Moon. This is an aberration in all eyepieces. The difference is only in severity or noticeability.
  9. Vignetting. This is a loss of edge brightness (transmission anomaly by distance from center) due to improper lens diameters (one element unable to field the entire set of rays from the preceding one), barrel diameter (too small an internal diameter to pass all edge-of-field rays), or simply normal design (a 40mm eyepiece in a 1-1/4" barrel will vignette rays at the edge so that, regardless of lens diameter, the field of view will be truncated by the barrel's entrance diameter). The causes of vignetting, where it is described as being due to the size of the secondary mirror, is really an improper relationship of the field of the eyepiece and the telescope's focal plane. It is not the eyepiece that is vignetting, in that case, but the use of too large an eyepiece for the telescope's illuminated field. Vignetting in an eyepiece is harder to see, and can often be seen only by holding the eyepiece up to a bright sky and looking at the edges of the field. If it noticeably darkens at the edge, there is vignetting involved. If it doesn't noticeably vignette, it could still be there in lab tests, but is unlikely to cause problems in viewing.
  10. Coma. Yes, eyepieces can have coma. It is the same as coma in a short focal length lens or mirror, but is significantly smaller in quantity. It expresses itself, usually, as a radial unsharpness in the star images, as they move from center to edge, that gets gradually worse toward the edge. Because astigmatism is likely to be more severe and more noticeable, I am not sure how you would tell the eyepiece has coma other than by ray-tracing the design. It might be possible to notice it in a completely flat-field telescope that lacks coma (f/30 refractor?), but in the real world, coma is 99.99% an issue with the primary objective. Very simple designs can exhibit coma, but you are staying away from these, aren't you?
  11. Light loss. This can be caused by back reflection from lens surfaces, absorption by the lens elements (lack of transparency or tint), scatter from the lens surfaces causing destructive interference in the wavefront, and internal vignetting. I talk about each of these issues separately, but I lump them together as light loss. Ultimately, the reach of your telescope is dependent on the maximum transmission of each element. The eyepiece is merely a link in the chain.
  12. Wavefront aberrations. This is similar to the problems caused by an inaccurate mirror surface, except that an eyepiece has many such surfaces. The reduction in the quality of the final image can come from poor polish on the lens surfaces (+/- wavelength %), poor figure (the lack of correspondence of the surface curves to design parameters—like the Hubble, originally), or an increase in surfaces. This is where fewer elements is often better. Unless the surfaces are all perfect (and that is HIGHLY unlikely), the more surfaces there are the more likely the final image's quality is likely to be reduced by these aberrations. Unfortunately, one manufacturer's 8-element eyepiece may have a final wavefront that is more accurate than another manufacturer's 3-element eyepiece, so we are truly generalizing when we say fewer elements are better. In specific, this may not be true.
  13. Loss of contrast due to light scatter. This is not, technically, an aberration, yet it is a problem in eyepieces that causes a diminution of the final image quality. It is caused by light scatter due to poorly polished optical surfaces, lens reflections due to edge-of-lens reflection, lens reflections due to poorly applied or absence of coatings, low angle-of-incidence scattering from the lens coatings, and shiny internal surfaces in the barrels and baffles. It is exemplified by a "graying out" of the background sky in a given eyepiece. Since larger apertures and/or lower powers show lighter background skies, the only way to really tell about the presence of this one is to compare another eyepiece of exactly the same field of view and focal length, or to put a bright object just outside the field of view and see if you can detect any internal evidence of the direction in which the bright object lies. Ideally, if a bright object leaves the field, there should be no visible evidence of its direction left in the field. Likewise, there should be no halo around any object, no matter how bright, that changes the darkness of the background sky around the object. In practice, many such problems are caused by the eye, or dirt or dew on the optics, so steps should be taken to minimize those issues before any form of evaluation. Ideally, this is one that should be measured on a test lab's bench, but we don't have access to such data as of yet.
  14. Thermal issues. If an inadequate clearance is left between the housing and the internal lens elements, as the barrel shrinks it may squeeze and/or bend the internal elements. This is more likely to be a problem in larger eyepieces, where the temperature differential between the housing and the internal elements is likely to be the highest. Big eyepieces have to come to thermal equilibrium, just like telescope objectives, in order to give their best images. Fortunately, the eyepiece will be at equilibrium before the mirror. This is a valid reason NOT to carry the eyepieces in a coat pocket or to store them in a closed case until used.
  15. Design flaws in the eyepiece. I've lumped these together, even though it is several issues. They are indicative of qualitative issues with the eyepiece design, and can indicate why you may not want to buy any of said eyepieces. Examples: Field stop not in focus (improperly placed field stop results in vague field edge. Wrong refractive index of glass used, resulting in aberrations not in the original design—this can be true of later versions of an earlier design. Critical f/ratio too high—wherein the eyepiece manufacturer designed the eyepiece to adequately field the narrow light cone of an f/15 refractor, but not an f/4.5 reflector. Personally, I think all eyepieces should be designed to handle the wider f/4 light cone well. Why should we have to become aware of which eyepiece does or does not work in our f/4.5 reflectors? This is a problem with many companies, unfortunately. Improper internal design, leading to vignetting or internal reflections. These are issues easily addressed, yet so many eyepieces do not. It may mean a poor optical design, a poor manufacturer, or too tight a budget to produce a good eyepiece. Whatever the reason, this is a good reason to eschew the purchase and use of these eyepieces until the problems are solved.
I've been very liberal in my use of the word aberration to include any deviation from a perfect image at the exit pupil of the eyepiece. It must be noted that these aberrations, though real, detract less, usually, from the final image quality than do the grosser aberrations of the primary mirrors and lenses. One should address, in designing the optimum optical system for one's budget, the quality of the mirrors and eyepieces together, for, ultimately, it is the combination of these elements that produces the final image.
How are we, in the absence of test-lab data, to come to any conclusion about the quality of any one of the over 1100 eyepieces currently on the market? Go to star parties. Ask users their opinions about their eyepieces. Read Cloudy Nights. Read on-line reviews. Read magazine reviews. Read books on the subject of telescope optics. Test for yourself by experimentation.
Maybe some day we'll get quantified lab tests. Until that day, just be aware that there is no perfect eyepiece—merely ones that are good enough for you.
Back to Top
Contact Us
CN Reports | Reviews | Articles | Forums | Classifieds | About Us
Copyright© 2004 Ad Libs Advertising.
Privacy Policy
Search Cloudy Nights
Advanced Search
Monday, July 28, 2014
Cloudy Nights Supporters
Astronomics
Telescopes  www.astronomics.com
