Finding the Optimal Sub-frame Exposure Length for
Astrophotography
Abstract
There has been a great deal of discussion about the optimal
sub-frame exposure length and papers have been written on the subject. This paper discusses the issues of
noise from all sources in astrophotography and attempts to find the optimal
sub-frame exposure length from both the mathematics and empirical data. The current wisdom of simply
overwhelming camera noise with light pollution noise as the optimal sub-frame
exposure is found to be false. This
paper shows that when shooting for the faintest details, target noise becomes the
overwhelming problem and it cannot be reduced efficiently by stacking. The end result shows a formula to
calculate the optimal sub-frame exposure based upon the camera’s noise, location’s
light pollution noise, and total exposure. A number of interesting guidelines result from this formula.
Motivation
About once a month someone posts the question “What length
should I use for my sub-frame exposures?”
Conventional wisdom is that it depends upon the amount of light
pollution and is based upon a formula from this paper by John C. Smith here:
http://www.hiddenloft.com/notes/SubExposures.pdf.
This seemed incorrect for at least three reasons.
1) Why would I care if the light pollution signal was 20
times the read noise? I am not imaging
light pollution and will subtract it out of the final photo. I image targets and the target’s signal
should overwhelm read noise.
2) What about quantization error? Cameras do not have infinite resolution and cannot report
fractions of an ADU. They have
whole number values and some faint target signals will only achieve 1 or 2 ADU
if the exposure is too short.
2) My own empirical data did not support the formula. I got better low level detail when
shooting longer than recommended sub-frames for the same total time.
Since my first read of Smith’s paper I have come to realize
he was computing the noise in the light pollution signal is equal to the square
root of the signal. So my first
statement is wrong and he was trying to get light pollution noise to overwhelm
the read noise. I am leaving 1)
because my belief in it was part of the motivation for this research and does
not affect the final results. The
first part of this paper will cover in more detail what the paper above already
covers but uses empirical data instead and also has a different goal.
Purpose
Stacking sub-frames is the preferred method for reducing
noise over increasing exposure time because in addition to reducing camera and
light pollution noise, it can also reduce other types of noise and non-random
events that longer exposures cannot.
Also shorter exposures are less prone to guide errors and if a sub-frame
is bad, throwing it out has a smaller impact. However, we do not want to use exposures that start with a lower
than necessary SNR. The goal is to
find the optimal sub-frame exposure time defined as the point where the target’s
SNR of stacking two sub-frames is within 5% the target’s SNR of exposing for
twice as long. This is not the
same as trying to find the point where camera noise adds only 5% to the total
noise as the paper referenced above calculates and the difference will be shown
later.
Basic Equations
Following are the basic equations used throughout the paper.
(1)
Where: B = Bias of camera
DC
= Dark Current of camera
E
DC
= Dark Current noise
R
= Read Noise of camera
LP
= Light pollution
E
LP
= Light pollution noise
Tgt
= Target
E
Tgt
= Target noise
t
= exposure time
Gain
Vign
= Gain caused by vignetting (<= 1.0) of the optical tube or lens
(2)
Equation 1 represents the equation for the value of the pixel
after time
t. All pixel values in this paper will be in ADU, Analog to
Digital Units (i.e. the value read from the camera), and not in electrons. One thing missing from Equation 1 is
the hot/cold pixel gain. The errors
caused by hot/cold pixels are best handled through dithering and nearest
neighbor type solutions. This
paper deals with the 99+% pixels that do not have pixel gain significantly
different from 1. Equation 2
represents the resulting noise error term when combining two independent noise
error terms. Stacking two sub-frames
is equivalent to combining two identical independent noise terms. This leads to
(2a)
Stacking two sub-frames increases the target signal by 2 but
noise only by
so the resulting SNR is increased by
, shown in Equation 2b.
(2b)
Equation 2 also allows us to solve for E
1 if you
know E
3 and E
2.
(2c)
All noise terms, expressed as E
subscript or
R are expressed as the root mean square (RMS) of the
error.
Now it is time to work on the noise. Since the CCD is a linear detector we
can treat each term independently.
Camera Noise
Let’s first look at the camera’s contribution to signal and
noise.
(3) Camera =
Dark sub-frame subtraction will remove both the bias and the
dark current signal so we are left with dark current noise and read noise. The formula for camera noise
Ecamera is
(3a)
We will not concern ourselves with the issues of dark
current saturating the sensor and assume the camera’s manufacturer limits the
maximum exposure to below this threshold.
Both the read noise and dark current noise terms can be measured easily
so we do not need the values from the manufacturer. Now what happens to our optimal exposure length if we only consider
camera noise, ignoring light pollution?
If we focus on just the read noise of the camera we get the
. If we double
the exposure to increase our signal by 2, the read noise remains constant so
our SNR goes up by 2. We have
already shown in Equation 2b that stacking two sub-frames only increases SNR by
, therefore we should expose for as long as possible to
increase SNR when considering only read noise. What about dark current noise? Since it increases at a rate of
, doubling the exposure or stacking two sub-frames are
equivalent. So the camera’s
optimal sub-frame exposure is as long as possible; or is it? A new question arises: Is there a point
at which the dark current noise overwhelms the read noise such that the SNR of doubling
the exposure is equivalent to the SNR of stacking two sub-frames? This is what we are trying to do with
light pollution noise but let’s look at the camera in isolation.
Let’s define optimal for the camera the same way we defined
optimal for light pollution. The
optimal exposure for a camera is the point at which the SNR of combining two
images is within 5% of the SNR of exposing twice as long.
Now at this point let me take a quick mathematical side
trip. When combining two noise
terms, how much larger does the first term have to be than the second term to
reach the point where stacking and doubling are within 5%? Using Equations 2 and 2b we have
(4)
where
p is the
percentage tolerance, 5%
The left hand side represents the
increase in noise by stacking and the right side represents
the increase in noise by doubling the exposure. The error terms E
1 and E
2 are equal
since we are trying to solve for the
X
multiplier. Since we know the
right hand side will be the smaller term, it is the one that gets the (1 +
p) term. Squaring both sides and just using
E for the error term since they are all identical, we
get
(5)
Solving for X and skipping a bunch of in between steps we
get
(6)
So in Equation 2, the
noise term must be 4.38 times higher than the
term we are trying to overwhelm. What does this do to the resulting total error value
E3?
Plugging back into Equation 2 we get
(7)
So we only need to expose until our measured total error to
2.32 times the error we are trying to overwhelm. Compare the above with the formula given by John C. Smith’s
paper where he computed
X=9.76. Using that value and solving for
p
we get
p=2.4%. So using a goal of read noise being 5%
of the total noise reduces the error from stacking to just less than half of
our stated goal. The choice of
p is somewhat arbitrary but we will stick with 5%.
For my SBIG ST-10XE camera, I measured a read noise of 6.3
ADU RMS. Using the data from SBIG,
they have a read noise of 8.8e RMS with a conversion of 1.3e/ADU, which gives a
read noise of 6.8 ADU RMS. To measure
the read noise I took 16 bias frames at CCD temperatures of -5C, -15C, and
-25C. I then computed for each
temperature the error (X
Pixel-X’
Pixel) for the same pixel
among the 16 frames. Finally I
computed the RMS of all of the error terms over all of the frames and pixels,
called E
pixel. This is
more accurate than taking one frame, averaging all pixels and computing E
pixel
from the overall average because of hot/cold pixel bias. The assumption is that a bias frame
contains zero dark current noise, which seems reasonable. The results showed that read noise is
independent of temperature.
Now I needed to find the dark current noise of the camera. The equation for total camera error is
shown in Equation 3a. I took 1
minute, 5 minute, 10 minute and 20 minute dark frames at -15C, measured the
total error from the frames and solved for dark current error using Equation 2c. The results were:
CCD temperature = -15C
1 minute
5 minutes
10 minutes
20 minutes
Ecamera
measured
6.52
7.26
7.91
9.03
computed from
1.66
3.61
4.78
6.48
EDC/minute
computed
1.66
1.64
1.51
1.45
The 5 minute shot goes up almost exactly by
, and the 10 and 20 minute dark current noise values go up very
close to
, as predicted.
The decreasing
EDC
term shows that dark current noise isn’t quite following the
formula perfectly and that dark current gets slightly less
noisy the longer the shot. After
20 minutes the dark current and read noise terms are effectively identical.
From Equation 6 we know that we need to overwhelm the second term by 4.38 to
achieve the optimal exposure so that means we should expose for 4.38*20 minutes
= 87.6 minutes, longer than the 60 minutes maximum exposure of an SBIG camera. The pessimist view is my camera’s read noise
is too high to get the optimal exposure below the maximum allowed exposure
length. The optimist view is the
dark current noise is sufficiently lower than read noise to not reduce maximum
exposure. For another camera, its
parameters would have to be measured and run through the equations.
Notice how the camera’s total noise increases as the exposure
time increases. This will be
important when solving for the optimal sub-frame exposure in the next section.
Light pollution Noise
Now we come to the heart of the paper. We have empirical values for camera
noise and we have solved what it means to overwhelm a noise term with another
noise term in Equations 6 and 7. We
just need to measure the light pollution noise of the sky at a location. The light pollution
signal adds uniformly to every pixel of the entire frame,
ignoring gradients. The value of
this signal is the average background value where no astronomical target exists
(i.e. background of space) minus the camera bias. This value will simply be subtracted from every pixel when
setting the black level so it is of no consequence. Smith’s paper uses an estimation of
, but I prefer to actually measure it to verify reality
follows theory. The RMS of the
actual error was measured across multiple frames from my research shots. If you want to measure it, I recommend
taking one minute shots and use that as the unit of time T. It has the advantage of long enough to
remove transient errors and most people shoot in units of 1 minute. You could use something shorter like
10, 20, or 30 seconds if you normally shoot in multiples of those lengths but
the length must be long enough to overwhelm read noise.
At my Bortle orange level light polluted house, I took 45
1-minute shots, 27 2-minute shots and 9 5-minute shots of the same object,
NGC7331, interleaved at 5 1-minutes, 3 2-minutes and 1 5-minute nine
times. The RMS of the noise terms
were
CCD temperature= -15C
1 minute
2 minute
5 minute
ETotal
measured
16.5
23.5
31.5
computed from
15.2
22.6
30.7
ELP/minute
15.2
16
13.7
Avg. background pixel value measured across all frames,
camera bias of 100 subtracted.
~245 ADU
~500 ADU
~1300 ADU
in ADU
13.7
13.9
14.1
If we use the 1 minute
ELP
value as the basis, the 2 minute shots were slightly noisier and the 5 minute
shots were less noisy but reasonably close. Estimating
ELP
using
is pretty close
and more stable but might be a conservative and is theoretically the lowest
possible value.
Note: When calculating the RMS of the error, it is critical
that each sub-frame be normalized with each other using the average background
value. The light pollution signal
changes over time and if they are not normalized, the RMS goes sky high. For the 5-minute sub-frames I collected
the average background ADU varied from 1200 to 1500. It also shows that a stacking program must also normalize
the backgrounds before stacking to get the most SNR improvement.
Now given
ELP
and
Ecamera, how long
is the optimal sub-frame exposure?
Using Equations 2 and 6 we get
(8)
Solve for S, the sub-frame length
(9)
The irony here is the camera’s dark current noise actually
helps reduce the exposure time. Plugging
in my local values where
ELP is
15.2 from the table and
EDC
is the camera’s dark current noise = ~1.6 and R is the read noise which measured
6.3 we get
(9a)
Equation 9 tells you how long to expose where stacking and
lengthening the exposure are equivalent in reducing light pollution noise plus
camera noise within 5% (i.e. overwhelmed read noise with light pollution noise). The units of
S are whatever length of exposure you used to find
ELP.
So for the data above, using 2 minutes gives 41 seconds and 5 minutes
gives 55 seconds. So there is a
little disagreement on the exact length because there is variance in the
variance when measuring the actual values.
Here is a table of minimum exposure lengths in minutes using
Equation 9 for both
ELP and
ETotal based upon my camera’s dark current
noise,
EDC, and read
noise, R, and may not be valid for other cameras.
ELP/minute
Min
Exposure in minutes
without
dark current
Double
Read
Noise = 12.6
ETotal/minute
Min
Exposure
18
0.53
0.54
2.13
18
0.61
17
0.60
0.60
2.38
17
0.70
16
0.67
0.68
2.69
16
0.80
15
0.76
0.77
3.06
15
0.94
14
0.88
0.89
3.50
14
1.11
13
1.01
1.03
4.05
13
1.34
12
1.19
1.21
4.74
12
1.67
11
1.41
1.44
5.63
11
2.14
10
1.70
1.74
6.78
10
2.88
9
2.08
2.15
8.32
9
4.21
8
2.61
2.72
10.45
8
7.15
7
3.37
3.55
13.49
7
18.67
6
4.51
4.83
18.03
5
6.31
6.95
25.23
4
9.37
10.87
37.47
Table SEQ Table * ARABIC 1 : Minimum Exposure in minutes
where stacking and lengthening exposure are identical
ETotal is
the photos’ total error (camera noise + light pollution noise) and will be used
for the remainder of the paper because it is camera independent and it can be
measured directly from the photos. As you can see, the minimum exposure remains
quite short until the light pollution noise goes below the camera’s noise, at
which point it takes a long exposure to dominate the camera’s larger noise
term. Also the dark current signal
is so small that it has almost no influence on the minimum exposure time. Look at what happens if we double the
read noise of the camera. The
exposure goes up by the square of the increase. Low read noise is very important if you want to stack as
many frames as possible in a fixed amount of time. The
ETotal
stops at 7 because the total noise cannot be lower than the camera noise.
If you cannot measure the actual RMS of the light pollution
error, then using
seems like a reasonable alternative. At worst case it calculates a value a
bit lower than actual error and that is better than too high. I hope to create a user friendly version of the program I
wrote that measures it from a bunch of FITS files. The current program requires changing the code to change the
file names and is not the least bit user friendly. Some might take issue with estimating
ELP from the entire photo since for the
bright targets;
ETarget
is much higher than
ELP. For the research shots I used this did
not affect the measured value by enough to matter.
So I have now found the optimal exposure length for my house
near zenith equals 45 seconds.
Wait a minute! One of the
reasons for doing this research was the fact that my empirical data did not
match up with the predicted formula.
I am now using an “improved” formula with the actual measured error
values and it says to shoot even shorter?
What is going on here?
Low Signal Error and
Quantization
Hovering over the faintest parts of a galaxy arm in my combined
1 minute research shot, the value was barely 2 or 3 ADU above the background,
which had an
ETotal = ~2.5
ADU. In the combined 5 minute
shot, the same pixels were easier to discriminate and about 15 ADU above the
background with an
ETotal
= ~10.3. The signal strength of
these faintest signals was about 3 ADU / minute. That is the issue.
In our zeal to overwhelm camera noise with light pollution
noise, we forgot our true purpose: Find the length of time where the
target’s SNR is within 5% when stacking or doubling
exposure time. We left out the
target’s noise term. The general assumption
is
ETgt is much smaller than
ELP when Tgt
Signal << LP
Signal
so it has no impact but let’s look at it in more detail for all cases. The previous sentence in plainer
English is “the general assumption is target noise is too small to matter when
compared to light pollution noise when the target is much fainter than the
light pollution”. From Equation 1,
if we assume that all other noise terms are zero, then
(10) SNR =
For objects with very strong signals like the Moon, planets,
and high magnitude stars, the target noise overwhelms all other noise and the
SNR is Equation 10 and the value is set by the transparency and seeing. Stacking is the only way to improve it
and our exposure length is set by the target’s signal, not light pollution
noise. For less strong signals
there is a choice of shooting longer or stacking. At this level
ETgt
and
ELP are on the
same order of magnitude so we really only need the combination to overwhelm
read noise, not an individual term. But for the weakest of signals, the ones the camera barely
gets any ADU, target noise from quantization error and low probability becomes
significant compared to target signal and light pollution noise is no longer the
biggest concern. The entire
concept of stacking / exposure doubling works equivalently at reducing noise
because we assume that the signals have a normal distribution so the error is ~
. That is only
true if we collect enough signal data.
A better model for weak signals is the
Binomial distribution
and
Poisson
distribution for small ?.
I will not go into the gory details here and you can follow the links
for a detailed explanation.
At only 1 ADU every 20 seconds, a 1 minute shot only has a
? = 3 (expected number of ADU / time frame), below normal distribution. To add to the error, a signal of 3.0 to
3.99 will also appear as a signal of 3 due to quantization error. To add insult to injury, signals with
strength 1, 2, 4, and 5 ADU / minute are also below normal distribution and
significant quantization error, which confuse the situation even more. The noise cannot simply be stacked away
without a huge number of frames and quantization error still persists since we
are at the level of a few ADU and the sensors do not report fractions of an
ADU.
My 5 minute shot has a ?=15 (3 ADU / minute for 5
minutes) for the faint details.
Right around ?=15, the Poisson distribution is more like a normal
distribution and can be reasonably modeled that way. At ?=25 it is effectively normal and should be treated as
such. So now we need yet another
equation in the calculation of optimal sub-frame exposure, one that takes into
account low signal error. We now
have a new goal. We want to
guarantee at least 15 ADU from the weakest signal, but how weak is that? If we double the exposure then we can
get 15 ADU from a signal one half of the current weakest signal. Does that mean we need to expose as
long as possible again? No,
because we have a competing noise term from the camera and light pollution. At some point the noise is going to
overwhelm 15 ADU. At a minimum we
should expose to the point where the average background +
ETotal equals the average background + minimum
signal –
ETotal, or
where
ETotal =
?/2. Since we are defining
the minimum signal as ?=15 ADU, the
ETotal should be 7.5.
But can’t we reduce noise by stacking multiple sub-frames and so are
stuck in an infinite loop? Time
for us to do some more math heavy lifting.
No matter how many sub-frames you want to stack, there is
going to be a limit in total exposure time, call it
TTotal. The final combined stacked photo’s total noise term,
will be
(11)
Where:
ETotal
is the total noise for a shot of time T.
S is the sub-frame length in units
of time T
T
total is the total time
in units of time T
Equation 11 is a simplification and is valid if
(i.e. light pollution noise overwhelms camera noise in time
t). We
are no longer concerned with differentiating light pollution noise from camera
noise and assume
. Simplifying
the Equation 11 gives
(12)
To simplify the time units we will use unit of T = one
minute making the whole equation in minutes. Playing around with different values of
S we see that as we increase
S, the
term goes up
linearly so doubling
S doubles
. Since we also
doubled the signal by doubling the exposure time, SNR remains constant. Only a change in
TTotal will change the SNR. This is critical to understand. For all but the weakest signals, all
combinations of sub-frame exposure and number of sub-frames to stack that add
up to
TTotal have
equivalent SNR as long as the sub-frame exposure is greater than the minimum
value where stacking and doubling the exposure are equivalent, given in
Equation 9. Since we define
equivalence by our choice of
p, the
exact definition of equivalence is a bit flexible.
Now we stated above that we want
to be less than
?/2, or 7.5. Using Equation
12 and putting ? back into the equation in case someone wants a different
value for ? we get
(13)
Solving for
S we get
(14)
Equation 14 is the equation for the optimal sub-frame exposure
for
TTotal that is as short
as possible but leaves no reasonably detectable signal on the table. Plugging my location’s values into (14)
for a 45 minute total exposure, we get
(15)
This value is quite reasonable given my research shots. To verify Equation 14, let’s create a
table of
ETotal vs. total
exposure to see what it recommends.
ETotal/minute
TTotal in minutes
60
120
180
240
300
360
18
3.23
4.56
5.59
6.45
7.22
7.91
17
3.42
4.83
5.92
6.83
7.64
8.37
16
3.63
5.13
6.29
7.26
8.12
8.89
15
3.87
5.48
6.71
7.75
8.66
9.49
14
4.15
5.87
7.19
8.30
9.28
10.16
13
4.47
6.32
7.74
8.94
9.99
10.95
12
4.84
6.85
8.39
9.68
10.83
11.86
11
5.28
7.47
9.15
10.56
11.81
12.94
10
5.81
8.22
10.06
11.62
12.99
14.23
9
6.45
9.13
11.18
12.91
14.43
15.81
8
7.26
10.27
12.58
14.52
16.24
17.79
7
8.30
11.74
14.37
16.60
18.56
20.33
6
9.68
13.69
16.77
19.36
21.65
23.72
5
11.62
16.43
20.12
23.24
25.98
28.46
4
14.52
20.54
25.16
29.05
32.48
35.58
Table SEQ Table * ARABIC 2 : Optimal sub-frame exposures
in minutes
Here is a 3-d plot of the data
Figure SEQ Figure *
ARABIC 1 : 3D plot of optimal exposures for RMS and Total Time
As you can see, it recommends between a 5 and 10 minute
optimal sub-frame (60 minutes total in the front, 360 minutes total in the
back) except in cases of shooting short total time in extreme light pollution
or shooting very long total time in pristine skies with cameras that have
exceptionally low camera noise.
These times must also be checked against Table 1’s values for the minimum
time. The results seem to match up
with what most astrophotographers with SBIG cameras found empirically by trial
and error; the optimal sub-frame length is generally between 5 and 10 minutes.
There is a practical limit to the lowest level signal that
can be detected even if we ignored all light pollution and atmospheric
extinction. My SBIG camera’s noise
goes over 9 at 20 minutes and predicted as 15.6 at 60 minutes. At 1 hour exposures and reworking
Equation 14 to solve for
Ttotal,
I only need 5 exposures to achieve all I could reasonably get out of the SNR,
with a lowest level signal of 1 ADU / 4 minutes. A camera with even lower noise could theoretically go lower
assuming we haven’t reached atmospheric extinction. There are also other practical considerations of tracking
and seeing that might increase the minimum signal we can actually detect.
Equation 14 is a simplification based on the assumption that
. The true
equation for S is
(16)
Equation 16 can be used for all values of
ELP and R and must be used when
Discussion
It seems pretty clear from the equations that it is a
combination of the
target’s attributes,
read noise, and light pollution that decide on the appropriate exposure. Either the target’s exposure is limited
by its strong signal or we are free to expose for a large amount of time but
are limited at some point by light pollution noise. As was stated earlier, not all targets can actually take the
optimal exposure. Obviously solar
system objects, bright nebula, and clusters will need shorter shots to prevent
blooming. Another consideration is
the number of shots to be stacked.
In a very dark site with very limited exposure time, the optimal
exposure may be too long to get enough sub-frames to get a good distribution or
deal with other types of noise. At
that point you may be better off going with a shorter exposure to give enough sub-frames
to stack and sacrificing some low level signal. However, choosing a shorter sub-frame exposure and still
shooting the same or more total time gains nothing for stronger signals and
loses the low level signal. Let me
demonstrate this with an example.
Example 1
We are shooting at a location and camera combination that
has an
ETotal = 16. At this location we only need to shoot 48
seconds to be in the range where stacking and doubling exposure are
equivalent. The target has a
signal-strength of 150 ADU/minute.
We first shoot 64 1-minute shots.
Calculate the SNR of the target using a stacking method where we keep
the target ADU value the same and reduce
ETotal by the
, like averaging.
The SNR = 75 for the target. Let’s instead shoot 16 4-minute shots for the same total 64
minutes. What happens to the
SNR? The signal goes up by a
factor of 4 (4 times the exposure) and the noise goes up by the square root of
4.
SNR remains constant for the target. We should expect this because by definition
we are in the range where stacking and doubling exposure are equivalent with a
sufficiently strong signal. We are
free to choose any combination of exposure length and number of sub-frames that
totals 64 minutes. If we are free
to choose
any combination, why not
choose the one that discriminates the lowest possible signal? Equation 14 tells us the optimal
combination among all combinations.
This also leads to another interesting result. Let’s take Equation 14 and solve for
TTotal as a function of fixed sub-frame
length and noise.
(17)
Table 3 shows the number of sub-frames to stack for a fixed
ETotal
noise. The number of sub-frames
has been rounded up to X+1 if over X+0.2 to make sure we get enough sub-frames.
Sub-frame length in minutes
ETotal/minute
1
2
3
4
5
6
7
8
9
10
18
6
12
18
23
29
35
41
46
52
58
17
5
11
16
21
26
31
36
41
47
52
16
5
9
14
19
23
28
32
37
41
46
15
4
8
12
16
20
24
28
32
36
40
14
4
7
11
14
18
21
25
28
32
35
13
3
6
9
12
15
18
21
24
27
30
12
3
5
8
11
13
16
18
21
23
26
11
2
5
7
9
11
13
15
18
20
22
10
2
4
6
7
9
11
13
15
16
18
9
2
3
5
6
8
9
10
12
13
15
8
1
3
4
5
6
7
8
9
11
12
7
1
2
3
4
5
6
6
7
8
9
6
1
2
2
3
4
4
5
5
6
7
5
1
1
2
2
3
3
3
4
4
5
4
1
1
1
1
2
2
2
3
3
3
Table SEQ Table * ARABIC 3 : Optimal number of sub-frames
to stack
As you can see from the values, as noise increases, so does the
number of sub-frames that must be stacked to achieve the practical minimum
signal. The optimal number is also
effectively the maximum number of sub-frames. Shooting more than the optimal number of sub-frames will
improve SNR over camera and light pollution noise but for no reason, called
over-stacking or the law of diminishing returns. By definition we have already achieved the practical minimum
signal that can be distinguish from the background and lower level signals are
lost in their own noise no matter how many additional sub-frames are stacked. Shooting additional sub-frames is
equivalent to increasing TTotal. The new TTotal has a different (longer) optimal sub-frame
exposure and we could have achieved the same SNR increase and picked up fainter signals by
using it as shown in Example 1.
The only reasons to shoot more sub-frames than recommended are cosmic
rays, dithering requires it to fix hot/cold pixels, or to have a few extra sub-frames
in case of tracking errors, satellites, airplanes or periods of bad seeing with
the idea that some of them will have to be thrown out.
What about shooting exposures that are longer than the
optimal, equivalent to increasing the value of ? in Equation 14? What do we lose if the optimal exposure
is 4 minutes for 16 sub-frames and ETotal=15,
but we decide instead to expose those 16 sub-frames for 8 minutes? The noise in the combined sub-frames
will have gone from 7.5 to
because we doubled the exposure and are still stacking the
same number of sub-frames. The
weakest signal we can clearly discriminate is twice the noise value so it went
from 15 ADU to
ADU in 8 minutes or 2.65 ADU/minute. Now let us look at the optimal exposure
for TTotal = 128
minutes (16 sub-frames * 8 minutes) and ETotal=15. Using
Equation 14 we get S = 5.7
minutes. We have already shown
that the SNR for stronger signals is only dependent on TTotal so the SNR is the same. What about the weakest signal we can
discriminate? The optimal value
has 15 ADU / 5.7 minutes = 2.65 ADU / minute so the lowest signal remains
identical. The result of
shooting longer than optimal exposures for the same TTotal is effectively identical
across the entire signal spectrum and there is no advantage to it. The true effect is moving the weakest
signal closer to normal distribution, but if you already decided ?=15 or
10 or 20 is close enough to normal distribution then why make it more normal? What we lose by going longer than
optimal is the larger number of sub-frames that achieves the equivalent
result. The optimal exposure has
22.5 (round up to 23) sub-frames to stack instead of just 16. More sub-frames mean a bigger reduction
in other types of noise such as cosmic rays and hot/cold pixels and we still
achieve the same signal quality.
Why shoot 16 sub-frames when we can shoot 23 in the same amount of time with
equivalent results?
We can also reverse the question in the previous paragraph
for 8 minute exposures to “What do we lose if we only image 16 sub-frames
instead of the optimal 32?” By
stopping imaging early we did not achieve the lowest level signal possible
for the 8 minute exposure. To achieve
the identical low-level signal we could have reduced the exposure to 5.7
minutes and imaged 23 sub-frames instead of 16. Not imaging the full optimal
number of frames means there was a shorter exposure that would have generated
equivalent results.
At this point you may wondering what exactly is the
difference between the light pollution limited exposure given in Equation 9
and the optimal sub-frame exposure based on the target and light pollution
combination in Equation 14 so let’s take a detailed look. Equation 9 sets the exposure length and
then reduces noise by the square root of the number of frames stacked. If you want to double the SNR, stack 4
times as many frames. Low-level
signals will be seen after the noise is driven below them. Eventually the noise will be driven
down to 2 RMS or even <1 RMS.
Equation 14 takes a completely different approach. It assumes that signals
below ?(=15) ADU will not be easily discriminated and computes the exposure
length and
number of frames to stack for TTotal
so the final photo will have exactly ?/2 RMS error, no more and no
less. If you want to double the
SNR, you must shoot twice as long (doubles signal and increases noise by
) for twice as many frames (decreases noise by
). The problem
with the first approach is that low-level signals do not increase their SNR by
but something less than that. Also the law of diminishing returns kicks in when driving
the noise error so low. Once the
error term gets down to around 2, quantization error reduces the effectiveness
of stacking. By keeping the final
noise at ?/2, the optimal sub-frame exposure is always in the range where
noise is reduced by the
Examine how the two approaches make you think about the
problem of noise. Limiting
exposure because of light pollution makes you think that 1) you can simply stack
your way to any level of detail or 2) light pollution greatly limits the
detail. Both are false. The optimal exposure makes you think in
terms of length of exposure required to obtain the desired level of detail in
the target and that light pollution determines how many frames to stack to
drive the noise error down to ?/2.
Light pollution becomes the enemy of total time and could even prevent
the capture due to light pollution saturation. Look at Table 3 for a 10 minute exposure. A location that has strong light
pollution of ETotal=17
requires about 3 times as many frames to stack to drive the noise to ?/2
and generate the same end result as it does at a dark site where ETotal=10. Over 8.5 hours versus 3 hours because 10 minute exposures at ETotal=17 have a noise of ~54 RMS and at ETotal=10 they have a noise of ~31.8 RMS. Image details are not limited by noise;
they are limited by the length of exposure. You can always stack whatever number of frames necessary to
drive the error to ?/2 but stacking a vast number of frames will not allow
you to see signals you never sufficiently captured.
How does the optimal exposure length compare with the
minimum exposure length? Let’s
take another very detailed look at Equation 9. Table 4 shows the minimum exposure
in minutes for 3 different read noise values, 4, 7, and 15 in various ELP locations and the resulting ETotal.
Read
Noise
ELP/minute
18
17
16
15
14
13
12
11
10
9
8
7
4
0.22
0.24
0.27
0.31
0.36
0.41
0.49
0.58
0.70
0.87
1.10
1.43
ETotal
18.44
17.46
16.49
15.52
14.56
13.60
12.65
11.70
10.77
9.85
8.94
8.06
7
0.63
0.70
0.79
0.89
1.01
1.16
1.34
1.57
1.85
2.21
2.68
3.30
ETotal
19.31
18.38
17.46
16.55
15.65
14.76
13.89
13.04
12.21
11.40
10.63
9.90
15
2.64
2.92
3.23
3.60
4.02
4.52
5.11
5.80
6.61
7.58
8.72
10.06
ETotal
23.43
22.67
21.93
21.21
20.52
19.85
19.21
18.60
18.03
17.49
17.00
16.55
Table SEQ Table * ARABIC 4: Minimum Exposure for Read
Noise
As you can see, the minimum exposure time goes up by the
square of the read noise. What
does it mean if we cannot to expose for the minimum time? All the minimum exposure indicates is
the exposure length where light pollution noise overwhelms camera read noise
such that stacking and doubling the exposure are equivalent. Exposing below that minimum simply
means we would get better SNR improvement by exposing longer as opposed to
stacking so it will taking longer total time, i.e. not 100% efficient with imaging
time. Also high read noise cameras
do not benefit nearly as much from a dark site’s lower light pollution noise. The optimal exposure equation does not
care about the minimum and computes the breakdown of exposure and sub-frames
for
TTotal that creates the
final photo with ?/2 error RMS.
Looking at Table 4, for a read noise of 15 and
ELP=13,
ETotal is 20 and the minimum exposure is 5.8
minutes. If you only want to image
for 60 minutes, the optimal exposure is 3.9 minutes using Equation 16 because
, which is below the minimum. At this point we are better off trying to image at the
minimum exposure than the optimal because the SNR of the final image will be
higher. However, the minimum is
set by our choice of
p=5%. What happens is we are more flexible
and set it to
p=10%, the
equivalent of allowing read noise to be almost 24% of the total noise? The minimum exposure drops to 2.5
minutes, below our optimal value.
Using the 3 exposure lengths of 2.5 minutes, 3.9 minutes, and 5.8
minutes, the minimum signal and SNR for
TTotal =60 minutes are shown in Table 5.
Exposure
Min Signal ADU/minute
SNR for 10 ADU/minute
2.5
6
4.8
3.9
3.85
5.1
5.8
3.7
5.4
Table SEQ Table * ARABIC 5: Min signal and SNR for 60
It looks like
p=10% might
not be such a bad choice for the definition of “equivalence”. We lose an additional 10% off the SNR
and the minimum signal does almost double but the minimum exposure is less than
half. We cannot extend this logic
much farther because the curve takes a sharp dive and we will lose significant
SNR and the minimum signal keeps going up if we expose much shorter. Besides the optimal exposure is
normally much higher than the minimum exposure for any reasonable
TTotal except when the camera has extremely
high read noise at a very dark site.
For this case the results of the optimal exposure are very close to the results
of the minimum exposure when
p=5%
but with 15 sub-frames instead of only 10.
The optimal sub-frame calculation still works even if we are
well below the minimum exposure in the form of Equation 18 that computes the
number of sub-frames to stack for a given exposure length and
ETotal. Regardless of why
ETotal = 22, even 100% read noise and 0% light pollution
noise, the number of frames to stack tells you when you have achieved the
lowest signal possible from the exposure length by driving the noise down to
?/2. Stacking more frames
will not get any lower target signals and shortly will no longer increase SNR
at a rate of
“How do these equations help us image better?”
There are several ways to look at the results of these
equations. The main use is to
answer the question: “How long should my sub-frame exposures be if I only want
to have a total exposure of 120 minutes?”
Table 2 will give the answer.
This answer is the optimal breakdown between longer exposures and more sub-frames
for a fixed time assuming it is longer than the minimum exposure. Shorter exposures will result in a
lower quality image for low level signals with no improvement in SNR for the
stronger signals and longer exposures will be effectively identical but with
fewer sub-frames to stack.
Another way is to fix the exposure length, either because
that is all the target needs or that is all it can take before blooming, and
compare how many sub-frames are necessary at different locations to achieve
equal quality. This can be useful
for astrophotographers whose home is light polluted but their dark site
requires significant travel. Table
3 can be used to determine if the extra travel time could be used to collect
more sub-frames at home and generate the equivalent result. In my own case the travel time one way
is about 60 minutes plus 20 more minutes to tear down. Ignoring travel time to the location
and setup, which are in the light, I could gain another 80 minutes of exposure
and be much warmer by staying home.
The
ETotal at my home
is ~16 and the “dark” site, a border Bortle yellow/green, is ~12. Using Table 3 for a 5 minute exposure,
I would need to shoot an extra 50 minutes per object at home. During the week it definitely pays to
stay home but it might be worth the travel time on the weekend if I plan to
image for 4+ hours.
One final way to use the equations is to fix the number of sub-frames
to stack. There are papers on the
subject of how many sub-frames are necessary to deal with other forms of noise. If stacking 16 sub-frames gives the
best overall reduction in noise not associated with the camera and light
pollution, what is the correct sub-frame exposure length? Reworking Equation 17 gives
(18)
where F is the number of sub-frames to stack.
Total sub-frames to stack
ETotal/minute
5
8
12
16
20
24
32
18
0.87
1.39
2.08
2.78
3.47
4.17
5.56
17
0.97
1.56
2.34
3.11
3.89
4.67
6.23
16
1.10
1.76
2.64
3.52
4.39
5.27
7.03
15
1.25
2.00
3.00
4.00
5.00
6.00
8.00
14
1.43
2.30
3.44
4.59
5.74
6.89
9.18
13
1.66
2.66
3.99
5.33
6.66
7.99
10.65
12
1.95
3.13
4.69
6.25
7.81
9.38
12.50
11
2.32
3.72
5.58
7.44
9.30
11.16
14.88
10
2.81
4.50
6.75
9.00
11.25
13.50
18.00
9
3.47
5.56
8.33
11.11
13.89
16.67
22.22
8
4.39
7.03
10.55
14.06
17.58
21.09
28.13
7
5.74
9.18
13.78
18.37
22.96
27.55
36.73
6
7.81
12.50
18.75
25.00
31.25
37.50
50.00
5
11.25
18.00
27.00
36.00
45.00
54.00
72.00
4
17.58
28.13
42.19
56.25
70.31
84.38
112.50
Table 6: Optimal sub-frame exposure in minutes for fixed
This is a very powerful use of the equation because there
are many reasons to use a specific number of sub-frames, or at least X
sub-frames. Table 6 gives the
optimal exposure for the camera and location’s light pollution noise to get the
maximum quality out of those sub-frames.
Shooting shorter exposures does not achieve the minimum signal possible
(over-stacking). Shooting longer,
while creating an identical photographic result, does not meet the stated goal
of the shortest possible exposure to maximize the number of sub-frames. For my house at
ETotal = 16 and shooting 16 sub-frames, I
should use a sub-frame exposure of ~4 minutes. At my dark site with
ETotal = 12, I should shoot ~6 minute sub-frames. Notice that the exposure time goes up
linearly with the number of sub-frames to stack. If you double the number of sub-frames to stack, you should
also double the exposure time, which increases total exposure time by a factor
of 4.
The minimum exposure equation is necessary to determine if
the optimal exposure is valid but how else could we use minimum exposure
equation? Let’s look at a situation
where I have a target, like a bright nebula, where I can only expose for 1
minute before blooming is an issue.
From Table 1, I can get as low as
ELP
= 13 (or
ETotal = 15)
for my camera before I am below even the minimum exposure. What happens if I go to a really dark
site? Noise keeps going down but I
am no longer “optimal” because I could have achieved better SNR by increasing
the length of the exposure instead of just stacking more sub-frames. However I have already stated I cannot
shoot longer so that is not an option and am now in an under-exposure situation. The target is simply too bright to make
optimal use of the dark site’s lower light pollution noise because of the read
noise of the camera. This leads to
another interesting guideline. If
your dark site requires travel, choose targets that can take at least as much
exposure as necessary to overwhelm camera noise. The minimum exposure becomes a guideline to the appropriate
location for the exposure, not the length. Don’t waste your precious dark site
minutes on targets that you can shoot at home with equivalent results. This is obvious when talking about solar
system objects and bright stars but it also applies to DSOs. Now the corollary to this is “Results
will always be at least as good at a darker site because of the lower light
pollution noise”. There is no
object that would be better shot in light pollution than a dark site regardless
of exposure length chosen, but they might be effectively equal. DSOs also need less total exposure at a
darker site to achieve the same SNR as the light polluted site so time is
another factor in favor of the dark site.
With all of the equations and discussion so far, we should
be able to answer the question “What is the actual impact of light pollution on
astrophotography?” Light pollution
has the following two effects.
- Limits
the maximum exposure before light pollution saturates the sensor.
- Increases
the noise in each sub-frame.
The first effect limits the lowest level signal obtainable
in a light polluted location compared to a darker location because going
“deeper” requires longer exposures.
The second effect increases the number of sub-frames to stack to obtain
the equivalent SNR of a darker site.
Some view the second effect as reducing
required exposure time and apply the converse to a dark site,
which increases the required exposure time. Exposure length can be anything to the limits of saturation. There is no required minimum or maximum
exposure time but there is a suggested minimum below which the SNR is lower
than nominal. I hope you will see
that exposure time is set by the level of detail you want from the
target and not by some arbitrary ratio of light pollution
to read noise. Strong light
pollution simply means you will have to put a larger amount of total time into
the object to get the same SNR and may not be worth the effort.
There may be some disagreement as to the exact value of
? to be used, which will affect the sub-frame values. Poisson distribution starts becoming
normal at ? = 5 and a case can be made for using an aggressive value of
? = 10 (shoot shorter, stack more) or a very conservative ? = 25
(shoot longer, stack less). This
paper uses
p = 5% as a measure of
equivalence but something closer to 10% might be a better choice. There might also be some reasonable
disagreement about the necessity of shooting at the optimal combination given
time constraints and other types of noise. Plenty of targets have sufficient dynamic range that it
isn’t always worth going after the absolute maximum detail available at the
edges. Equation 14 simply states
how to achieve the theoretical maximum for a given camera, location’s light
pollution, and how much time is to be put into the target but we are talking
about fractions of a difference.
Exposing a little longer, a little shorter, or stacking a few extra
frames will not result in much change in the final photo. The key is that stopping at the minimum
exposure when the optimal is twice that value makes a big difference. Use equations 9 and 14 to help make
the most efficient use of your time under the stars. Table 6 is very useful if you like to shoot a specific
number of sub-frames and do not want to shoot below the dark site’s potential. Table 3 shows when image quality is
being lost from over-stacking. In
the end there is wiggle room at the margins but the overall guidelines remain
intact.
Conclusion
Our initial goal of simply overwhelming camera noise with
light pollution noise did not produce the optimal sub-frame exposure for faint
objects. It incorrectly ignored
target noise and signal probability in low level signals where it became the
dominant problem and cannot be solved by stacking more sub-frames. Also we may need to relax the
definition of “overwhelm” for a camera with high read noise. Equation 9 is a recommendation for the
minimum exposure; below which imaging is not as efficient at noise reduction. It is a useful guideline to determine the
most effective location at which a target should be imaged if imaging at multiple
sites and time is a premium.
The equation to find the optimal sub-frame exposure for
capturing faint objects is defined as
where ?=15.
This gives the optimal combination of exposure length and number of sub-frames
for total time
TTotal that
result in the lowest possible detectable target signal levels. Increasing the total exposure will
allow even fainter target signals to be detected but there are practical
limits. The equation can be
changed around to fix either
TTotal,
sub-frame exposure, or number of sub-frames and solve for the optimal value of
the other two. Use Tables 2,
3, and 5 as guidelines to get the best combination of sub-frame exposure, total
time, and number of sub-frames to stack for a given target at a specific
location. If you prefer to give up
a little SNR and minimum signal to get more sub-frames then use
p=10% and ?=10.
Using the minimum exposure and optimal exposure equations
wisely can increase the efficiency of your time under the stars.
Further Research
A useful research project is to find out how small the
atmospheric noise can get when shooting from some of the best places on
Earth. It would be interesting to
find out that as amateurs (using that term very loosely considering the
incredible quality that is achieved) really start spending the money and effort
to set up remote observatories in exceptional locations if camera noise becomes
the dominant problem and we need a breakthrough in low-noise cameras for the
next level of quality.
Another suggestion is a way to measure atmospheric
extinction such that a formula can predict using camera A on telescope B at
location C, the maximum useful exposure time is
X minutes. This is a rather
involved project because it has to take into account the actual telescope
parameters and its effect on low-level signal detection. This would be of significant value for
setting expectations and preventing astrophotographers from wasting hours
trying to achieve the impossible.
It would also point out the weakest link in the chain that gives the
most improvement when upgrading.
