Introduction
Introduction
I would like to present for your consideration a departure
in the way we look at nebula. I am
hesitant to suggest that I have discovered anything as I would imagine that
there are some others who have tried this concept in the past-.My only wish is
to share the information with anyone interested in the hope that it may advance
the way you visually enjoy nebulas,
which, in most cases are limited to just a small handful with what is
currently available to the amateur astronomer. I think that I can honestly say that with the proposed
system described below, you will
be able to see a 1000% improvement in your ability to view nebulas.
I am going to refer to the concept as the "system" for the purposes of this
article. The system consists
of two principal blocks, with an
additional third block which is an enhancement to the system. The two essential items in the
system are a high-gain image intensifier,
the only one I know of that is currently being marketed is the Collins
I3, the second essential item is a narrow-band Hydrogen-Alpha filter. There are a number of suppliers
of this type of filter, the main
criteria is that its pass-band be less than 15 nm wide. In case you have no experience with
this type of filter, this is a
filter that is used exclusively for astrophotography. These filters,
until now, were completely
useless for real-time observations.
The filter I use is a Schuler 9 nm Hydrogen-Alpha filter. I also have a 6 nm Astronomics filter
which works very well with a very slight reduction in brightness. The third element of the
system, which is optional, is a focal-reducer/field
flattener. There are a number of
manufacturers who supply these as well.
I use a Denkmeier Star-sweeper. What this accomplishes in the over-all scheme is a
reduction in the focal ratio on my scope from an f4 to about an f3. For normal visual use, this would be meaningless because of
how your eye adapts to light, but
with the I3, which acts like a
real-time camera, it makes a
noticeable improvement. The
system works well without the focal reducer, but if the object is to see as much as you can-then push the
envelope.
The Methodology of the "System"
The system is basically tow elements which function very
well together, which by themselves
either perform poorly on nebula or not at all. Let's look at the system components. The Collins I3 is a real-time
image intensifier, using
technology which was developed for the armed services for the purposes of night
vision. The latest
technology in this field is an amplification system capable of amplifying light
by as much as 50,000 times. Like
most amplification systems,
reality is much less,
mostly due to various losses in the transformation of energy from one
state to another. There is
also the factors raised by the amplification of the light you want as opposed to
the amplification of the light that you don't want. This is generally described in terms of
signal-to-noise ratio. This is
usually expressed in dB. In the
case of the latest thin-film I3 technology, we are talking about signal-to-noise ratios on the order of
25 dB. That is essentially a
two and a half magnitude increase.
I don't know exactly how that would correlate to the visual intensity of
the object you were trying to observe.
If it were a direct 1 to 1 correlation, you would be able to see objects
2.5 magnitudes lower than before.
Which would be greater than the doubling of the aperture of the
instrument you were viewing with.
Not a bad return on your investment. But-there are many factors involved in this system and
the actual return for your effort could far outweigh the simple doubling of
aperture. My experience has lead
me to believe that in some instances,
you will see images with the "system" that simply could not be visually
observed with 100 inches of aperture,
let alone a doubling or tripling.
Later on in this piece, I
will describe things that I can see with the "system" that are totally
imperceptible with out it.
Back to the methodology. The I3 has gain,
we have established that.
In all of your conventional viewing systems, you really are simply trying to minimize losses. You do have gain of sorts, although it is passive, by the concentration of light from a
large aperture being focused into the much smaller pupil of your eye. But-in most portions of a
conventional system you are trying to minimize the amount of lost light and
stray light and trying to maintain the same concentration of a wide bandwidth
of light all focusing on a single small point, hopefully,
exactly the same.
With a conventional telescope
and eyepiece, the
corrective coatings, the amount of
reflectivity of the mirror, the
amount of baffling, even the different
kinds of glass used in the lenses,
all play a big part in reducing the loss of light as well as the
integrity of the color that arrives at your pupil. Since light bends differently at different
frequencies, this is not as easy
to do as it sounds. It requires
many corrections both reflectively and optically in order to get an image that
we would refer to as "color free".
Fortunately with the "system",
the issue of color free is not even on the table. We have narrowed the bandwidth by
a factor of 50 or more. We
have concentrated on a very tiny portion of the visual spectrum which, interestingly, gives us two great
advantages, first, the tiny portion of spectrum which is
Hydrogen-Alpha carries the vast majority of detail information in the luminance
portion of an astrophotograph.
Most of your expert astro-photogropher's use narrow Hydrogen-Alpha
filters to bring out the detail in their nebula pictures. Look at almost any nebula shot by
Russell Corman, Robert Gendler, or Ken Crawford, just to mention a few-they all
use narrow Hydrogen-Alpha filters to capture the luminance detail in the image. The wispy, cloudy detail in virtually all nebula are principally in the
Hydrogen-Alpha region. Putting
this filter in front of a 25 dB gain block gives you amazing detail, as well as allowing you to see portions
of the nebula you've never seen before.
Then there is the improved signal-to-noise factor that you benefit from
simply by reducing the bandwidth.
Signal-to-noise is inversely proportional to bandwidth. It takes a much larger signal to give
you the same signal-to-noise ratio in a wideband reception situation as it does
in a narrowband situation. It
would require the slide-rule-types to figure out exactly what that improvement
equates to, but-there are several
dB to be gained simply by narrowing the band pass of light. There is also a small price to
pay in that your intensifier tube is starting out with a lower level of protons
to work with, and is thus working
closer to the noise floor than it was before. One more factor comes into play here, and this one is one that you would not
ordinarily think of. The I3
has an automatic gain control, or
as the tekies call it, an AGC.
What this means is that when a strong signal enters the band pass of the
I3, such as a bright star, the gain automatically throttles down
to keep it from being over driven.
What this does is reduces the amount of gain available for all of the
information within the eyepiece, therefore, the much lower level information is
also reduced by the same amount.
Lower gain, less wanted information. The Hydrogen-Alpha filter has an enormous roll to play
here, if you recall, the people among us that like to look at
the sun use a very narrow Hydrogen-Alpha filter system to observe the sun
directly, in most cases a small
fraction of a nm in width,
sometimes as little as 0.05 nm or less. The sun puts out almost no energy in the
Hydrogen-Alpha region of the
spectrum. That is why these very
narrow Hydrogen-Alpha filters are used for solar observation allowing you to
use fairly large aperture telescopes to look directly at the sun. which viewed without the filter would
damage your eye and even damage the scope. What does this have to do with the system? I'll tell you. First off, when you look at a nebula through the system, the stars (suns, if you will) are
attenuated by as much as 20 dB or more and thus the gain of the I3 is ramped up,
compensating for the lack of bright stars in the field to the point that the
nebulosity comes booming through.
If you have ever looked at the black and white Hydrogen-Alpha
photographs on the web or in magazines, you will notice something else you may not have paid
attention to before. The
number and size of the stars in the image are dramatically reduced. The reason should now be
obvious, they are not there as
bright or in as large a number because they have been attenuated by the
Hydrogen-Alpha filter. This
unique combination of light gain,
filtering and manipulating of the AGC all working together to give you
an image that simply cannot be replicated in any other way, with the exception of long exposure
photography.
The third element of the system is simply increasing the
signal to noise ratio further by reducing the f ratio of the telescope. Any focal reducer should accomplish
this to one degree or another.
It is very common to use a reducer on a refractor or a catadoptic
reflector, but quite uncommon to
use a reducer on a Newtonian. It
usually isn't even necessary for most Newtonians because their f ratio is
usually below f6 or f7 and the eye,
which is very adaptable,
has a way of making the view an f6 Newtonian, look the same as an f4. The only difference is the f6 image is magnified a bit more
and the object is larger in the eyepiece.
The eye compensates for the focal length difference in light levels. The I3 does not-just like a
camera, the f ratio of the scope is critical to the brightness of the
image, either on the CCD screen or
a photograph or in this case a phosphorus screen. If you change a camera from f4 to f5.6, one f-stop, you must double the amount of exposure
time in order to get the same image on film. Sounds pretty brutal but the I3 is no different, since you are working in
real-time, you don't have the
luxury of increasing the exposure time,
which simply means you take a loss in brightness equivalent to what
would amount to a doubling of the exposure time if this were film. Just think, going from f4 at 1 hour would require 2
hours at f5.6. Therefore, when you use any scope with the system, be it a SCT, RC, Newtonian, Refractor
or any variation of the above, you will want to reduce the focal ratio if you
can. In some cases you may have
issues with back-focus and vignetting as well as other problems, those will need to be dealt with on a
case by case basis. The
system is not dependent on the Denkmeyer Star-sweeper or any particular focal
reducer, the object of this part
of the system is simply to reduce the focal ratio anyway you can without
suffering anymore field curvature, vignetting, or color distortion than is
absolutely necessary. In the
case of the Denkmeyer Star-sweeper,
I was pleasantly surprised to see a considerable improvement of the field
with respect to flatness, very
comparable to what I get with my paracorr.
I just recently tried something out of curiosity. I plugged in a standard 25 mm eyepiece
and screwed on the narrow Hydrogen-Alpha filter as I pointed the 20" scope
toward M42. With the 20" scope M42
is very bright. It literally
jumps out of the eyepiece.
With the Hydrogen-Alpha filter in place I could see absolutely
nothing. It was pitch
dark. I thought I would be able to
see at least a very faint image peek through-but absolutely nothing. Then I screwed the same filter on
the I3 and put it in the focuser-what an amazing difference. There was a bright nebula with
all the wispy detail of a Hydrogen-Alpha long exposure photograph. I am talking about the whole M42 image
where the cloudy structure comes down to a point at the far end, along with the beautiful detail of M43
and the dark areas as well as the trapezium, with it' molten detail. This view of M42 is something no standard eyepiece can come
close to.
So What Can You See?
I have been working with the "system" for almost 9 months
now, and have had a chance to see virtually all of the different nebula that
passed overhead in a full years time.
The answer to this question is really very close to
"everything". There are a few
objects that simply defy any visual observation but the list is very
small. We have taken "The Sky 6"
and scrounged for nebula that no one ever really talks about seeing and when
you plug in the NGC or IC number or even the Able catalogue or some of the
other exotic catalogues that you probably never even thought of looking at
because you had trouble with half of the Messier objects, let alone delving into some of the really
faint objects at magnitudes of 12, 13, ore even 14th and 15th. We've seen them. The I3 with out the filter will bring
some of the brighter nebula to view,
but to a very limited extent. It also seems to have a lot to do with the number of
bright stars in the field. Don't
forget the AGC, which is pushing
down the gain and thus leaving most of the nebulosity completely out of the
eyepiece.
I started using the system in April 2006. The first thing that I looked at is the
first thing anyone looks at in the spring just after sunset, M42. There is was.
With the "system" it seemed almost as bright as it does without the
filter, but the degree of detail
in the nebulosity was indescribable.
No comparison between the conventional eyepiece and the system. The detail in M43 was also
indescribable-I could even see the running-man. I have never visually seen that before. Then in almost a dared action I moved
up to the flame, a nebula that I
have enjoyed on many occasions without the "system". But where was the horse-head which had eluded me up until
that moment. I had tried a 31 mm
Nagler lens with a Hydrogen-beta visual filter, while trying to optimize my dark vision and did my best to
use what I later began to call my "averted imagination" to try and see this
elusive site, with absolutely no
success. I had other more
experienced astronomers looking in my eyepiece on my scope and
saying to me-"there it is right there in the center of the eyepiece-can't you
see it?" And, try as I may, it
simply was not there. I really
think I gave it as good a try as anyone could without any success-so needless
to say I was quite apprehensive about what to expect with this brand new "system". I moved down from the flame and to my
surprise, not only could I see
it, I could see the wispy clouds
behind it that illuminated it from the back-it looked just like the photos
where it looks like vapors that were rising behind the horse head. It was so unbelievable that I ran into
the house to get my wife, who
cares about these things about as much as she cares about drag-racing or a good
football game. I first showed her
a picture in a magazine of the horse-head and then I took her to the eyepiece
and had her look, she saw it as
plain as day-a two year old could have seen it, it was that clear and although you would not call it
"bright" you would neither describe it as dim or faint-it was there.
I have looked at the horse-head with a 16" Dob and a 13" Dob
from my driveway in Simi Valley with bright street lights only about 30 degrees
off axis. Another benefit of the
system, it almost eliminates light
pollution from local lights,
although bright background sky's does attenuate performance to some
degree. Then I took out a
10" LX200 and the f6.3 reducer and the "system"-the horse-head was still quite
a view. I have looked at the
horse-head and the flame together,
although much smaller in a 4" FSQ 106. I did not use the focal reducer as there isn't enough
back-focus in the FSQ. But with
the straight I3 and Hydrogen-Alpha filter it was spectacular. The next dark of the moon, I brought up a 3 inch Orion refractor
to see if I could still see it.
There is was, just slightly dimmer and smaller but completely
visible. How many of you reading
this have ever seen the Horse-head with a 3" refractor? I doubt that there are many shaking
their heads yes to that one. In
each of these viewings I tried to see anything with a conventional eyepiece and
in no instances could I see anything-not even the flame except with the 20" the
flame came through very dim but discernable, but absolutely no horse-head. My viewing partner had the identical experience in every
case. I consider the horse-head
the true test of the system-but I will now go through some of the other nebulas
in the sky.
I will describe what I have since done with the system over
the past 9 months. I moved over to
the Rosette. There it was with the
dark details, but I could only see a portion of it at a time with the 20", later I would see the entire donut with
the FSQ. The detail was somewhat
reduced with the FSQ but looked exactly like the photographs. Then I moved the scope over to the
cone. I could pull the cone out of
the nebulous patch of clouds. The
actual cone came through as a dark arrow shaped void in the nebulosity with a
bright spot at the tip of the point.
You could also see the cloudy "foxy" details in the remainder of the
nebula. I missed the witch-head in
the spring of 2006 but tried to catch it that winter. No luck-this is the only nebula that I have found will not
pop through, even though you can
see some nebulosity in the area,
you can not make out the shape of a witch-head. I also tried it with the
FSQ since it is so large-but it just wasn't there.
Thor's Helmet was absolutely stunning, and much larger than
I had expected, but for that
matter, so was the Horse-head. It was now June 2006 and I was anxious
to see Sagittarius come up because it has so many interesting nebula, but the
one everyone wants to see is the eagle.
I pulled up the eagle on June 24th and almost fell off my
chair. The detail in the eagle is
absolutely unbelievable. You can
see the three pillars very well defined and with almost the same contrast as
you see them in a black-and-white
Hydrogen-Alpha photograph.
It was breathtaking. The
next dark of the moon I took the system to Mt. Pinos where I spent the evening
with Steve Kennedy and his 28" Dob.
Many of you know who Steve is, He is one of the foremost mirror makers
in the world. And his personal 28"
scope is a masterpiece. He is
somewhat of a purest like a few others that were on the mountain that
night, a number of which liked the
conventional view through their lenses better than the "system", but when it
came to M16, even Steve was
impressed and spent a very long time looking at the pillars and commenting how
he had never seen them that good before.
With 28" of light gathering and the "system" the eagle just jumps out at
you, plus you move in closer so
the actual pillars are bigger and you can see even more detail. The brightness with his 28" and
my 20" were about the same, but
that may be because we could not use the star sweeper to bring the focal ratio
down another f stop because we ran out of back focus. Back focus with the system is, at times,
a real problem, and in many cases,
adjustments need to be made so that you can accommodate the system and still
come to focus, much like a pair of
bino-viewers. We also looked at a
whole list of objects including M8, absolutely stunning, much more detail than with conventional
eyepieces and three or four times as wide, literally two or three eyepieces wide. M17 was stunning, much much more detailed than with any
conventional eyepiece. M20 was
breathtaking but you could just faintly see some of the nebulosity in the blue
region. The red portion was
as pronounced as the best photograph you've ever seen of the object. The dark lanes in M20 were as
crisp and detailed as any photograph,
unlike conventional views.
About this time Cygnus cleared the trees and the first thing we looked
at was the Crescent. It was
absolutely stunning, as detailed as any photograph. The North American Nebula was so big you could wander around
it for hours looking at detail.
The veil was as good as any photo you have ever seen. Interestingly, the veil comes through my 20" very
nicely with a conventional eyepiece and an OIII filter, but the "system" view
was equally impressive although it did look different. I would have to say that Steve Kennedy's
28" with a conventional eyepiece with an OIII filter was a breath taking
experience and I think, in this case, I preferred the conventional view better
than the "system" view but it wasn't because you could see more with one than
the other, it was simply what
looked more exciting in the eyepiece and the contrast with the totally black
background of the conventional view simply was more impressive than the
system, which by it's nature
amplified the background light more and though it was much brighter, the contrast wasn't quit as good. Then we moved over to M27, The dumbbell
was indescribable with the "system".
You could see more detail than most of the long exposure
photographs. It was very defined
and a great deal of contrast. It
almost seemed iridescent. It
seemed to glow. One of the
all time best views with the system is M27. Between the horse-head, M16 and M27, the three alone make
the "system" worth having.
At this point is became time to push this a bit harder. We were all looking for a
challenge. How about NGC
7193, a small planetary nebula at
about 13.5 magnitude. A galaxy at
13th magnitude is hard,
a nebula at 13th magnitude is simply not going to be there, but it was. It popped right into the eyepiece and showed all the detail
that it had. I think it was better
than the photographs I found on a number of different web sites. Then we tried NGC281, the Pac-Man. Never had been able to see the Pac-Man before with either
the I3 by itself or with conventional lenses. It was not very bright but it was also low in the sky. I remember trying it later in the
evening when it was higher and the brightness and contrast had improved quit a
lot. How often have you observed
the elephant's trunk in IC1396? If
your honest, most of you probably
have never seen it. It is
difficult even with a 20" scope.
But with the "system" I could follow the dark nebula right up to the eye
opening at the top. It was
stunning. You could see the
nebulosity which seemed to go on forever surrounding this dark nebula. Then the Bubble, it was there in all it's glory, but by this time I had become overly
confident and began to expect that anything I pointed to would be visible. So far there was only one no-show
and that was the witch-head. I
pointed at another 13th magnitude planetary nebula NGC 6445, you could see the box shaped nebula
showing enough detail to make out it's character. In the next two or three months of dark moons I logged what
must have been dozens of nebula,
most of which were small planetary nebula. Including the cat's eye, the eye, the ant, even one nebula that according to the
computer on my setting circles was NS354,
which I could see but could never find much information on. I saw the California nebula well in the
FSQ and pieces of it in the 20" as
I panned over the whole thing.
Late in the fall of 2006 I looked at M1 with the "system". This was very interesting since the
previous views were before I had the Hydrogen-Alpha filter and it was simply a
gray smudge, now with the system
it had veins in it, much like the
photographs. I found very few
nebula that I couldn't see. By
this time, the Horse-head had come
up again and it is 9 months since I started with the system. I must confess that I have spent almost
no time looking at globular clusters or galaxies for the past 9 months. The
system does not work on anything but nebula and there are usually enough of
them at any time of the year to simply fill the whole viewing night.
I know there are those who would look through the eyepiece
of the "system" and then walk away complaining that it had ruined their night
vision or complain about the greenish cast of the image or the sparkles
(scintillation noise) and that they liked their tried and true conventional
view of these objects. This is not for everyone, but, I have not found anyone
who was not impressed with the Horse-head. You can never please everyone. If you already have an I3 and you have not tried a narrow
Hydrogen-Alpha filter-you are missing out on the experience of you life. For less than $200 you can buy a
good narrow Hydrogen-Alpha filter and I can promise, just the Horse-head alone is worth the $200. If you don't have an I3, it will be a
more expensive experience for you-but still well worth it.
I hope each of you gets a chance at some point in your
viewing life to look through an I3 with a narrow Hydrogen-Alpha filter (THE
SYSTEM). It could very well change
your way of looking at nebula forever.
