Home / CN Report: Observing the Arp Peculiar Galaxies
by Tom Trusock 05/28/07 | Email Author Voice your opinion about this topic in the forums
HueyArp
Observing the Arp
Peculiar Galaxies by Alvin H. Huey
Tom Trusock 5/07
Mastered the
Messiers? Hit all the Herschels? Wondering what to observe next?
Well, if you've got some decent aperture you might consider
investigating the weird and wacky world of Dr. Halton Arp. Several
Arp's can be seen in 8-10 inch telescopes but, like always, aperture
rules.
The Atlas of Peculiar Galaxies was initially published by the
California Institute of Technology using data and observations largely
collected through observations at Mount Wilson and Mount Palomar
Observatories. Dr. Arp observed several galaxies which did
not fall under the Hubble Classification scheme, and thus began the
catalog as to ensure a proper appreciation of these oddball galaxies
and build a realistic picture of what galaxies are really
like. Initially dismissed as statistically insignificant
further southern hemisphere observations (not in this catalog)
showed a remarkable 8% of the galaxies observed could in some sense, be
classed as peculiar.
Dr. Arp's initial catalog can be found online here:
- Atlas of Peculiar Galaxies
- Halton Arp
Ironically, what began as an attempt to catalog or classify abnormal or
peculiar galaxies resulted in something that challenged the very
foundations of modern cosmology - Hubble's law. Hubble's Law was
formulated by Hubble and Humason in 1929, and states that the redshift
in light coming from distant galaxies is proportional to the distance
of those galaxies. The further an object is, the higher it's
recessional velocity, and thus the greater it's redshift.
Mathematically, Hubble's law is fairly straight forward, and for simple
cases can be expressed as
v=HoD
where v is the recessional velocity, D is the distance from the object
to the observer, and Ho is the Hubble
constant. Hubble's Law is crucial to the basis of the
expanding universe theory, and thus is a critical piece of
observational evidence for the Big Bang.
Shortly after publication, Arp found that galaxies between 100 and 150
in his catalog (elliptical galaxies associated with disturbed spirals
or disturbed material) seemed to have some increased relation with 3C
(3rd Cambridge survey) radio sources - which were newly (at the time)
discovered high redshift Quasars. Since the redshift is
generally taken as an indicator of distance, and as Quasars are
supposedly beacons from the early universe and as such lie far from us,
their apparent physical association with bright, relatively nearby
galaxies was, and still is disconcerting to many Arp's findings were
not to go unchallenged. Arp felt that redshift may not be
solely explained through distance, and there may be some other
mechanism at work. Thus we see the introduction of the term
discordant redshift into cosmology.
From private correspondance with Prof. Roberto Abraham, Dept of
Astronomy & Astrophysics, University of Toronto - 5/29/2007:
Just as an aside: arguably the main
significance of the Arp atlas
these days, from the point of view of people studying galaxy formation,
is that it provides a convenient set of "benchmark" local peculiar
galaxies
to compare against distant objects seen in deep HST images. A large
fraction of
galaxies in HST images (upwards of 30% at modestly deep magnitudes, say
I=24 mag, with the fraction increasing sharply as one goes fainter)
don't
find a natural home in classification schemes that work for local
galaxies.
At this point we don't know why so many faint galaxies on HST images
are
morphologically peculiar. Undoubtedly many look strange because they
are mergers or
at least being tidally distorted by interactions (the case for many
objects
in the Arp atlas), because the merger rate is rising rapidly with
redshift (which is to be expected as the Universe
is getting smaller as we look further out and the galaxies are more
crammed
together).
On the other hand, a fair fraction of morphologically
distorted galaxies in HST images don't seem to resemble anything
in the Arp atlas, and just what these are (and what they are
evolving into) is
not clear at the moment. We should learn a lot
more in the next few years as adaptive optics systems with
spatially-resolved spectroscopic capability come on-line. These
will let us map out the internal motions in these systems and
figure out how fast (or even whether) they're rotating,
and to say something about their dark matter content. Some (many?
most?)
may be collapsing protogalactic clumps, and we should be able to tell if that's the case
from their internal motions too. And, of course, when JWST launches,
we'll learn a ton more about them. So the next
few years should be interesting ones.
--Prof. Roberto Abraham
But for the visual observer, even with the astrophysics of particular
members aside, the catalog is fascinating to browse through. If
you're used to picturesque ellipticals and symmetrical spirals, then
your first view of these Arp's is not unlike visiting a circus freak
show; three armed spirals, one armed spirals, colliding galaxies,
diffuse counter tails, jets, repelling arms, companion galaxies on the
arms of spirals, windblown double galaxies, galaxy chains, and many
many other oddball structures. They defy tradition. If
you're into the odd or different, then Halton Arp's catalog is just
plain cool. And frankly, some of what you find might well
surprise you.
A newcomer to the Arp Catalog
might be a bit shocked to realize that Arp 85 is M51/NGC
5195. You'll find a few other old favorites in here, as well as
some truly odd beasties of which you may have never seen the like.
The Arp catalog is setup along 4 main areas: Spiral
Galaxies, Galaxies, Elliptical and Elliptical-Like Galaxies and Double
Galaxies, with the (fairly self explanatory) sub-areas shown in the
charts below.
For the visual observer, the Arp Catalog presents a number of
interesting challenges. First and foremost, for many will simply
be detection of the various objects. The second challenge lies in
visually spotting what makes the galaxy peculiar (the jet in Arp 152 /
M 87 for example).
As an observing list, the Arp catalog is definitely slanted towards the
experienced observer with a large aperture telescope, but there are
several good targets for with smaller telescopes. In the table
below, I've listed the 21 Arp's under magnitude 11 which can easily be
seen in moderately sized telescopes. For comparison, there
are 85 brighter than mag 13, and 242 brighter than magnitude 15. (The
data set used is from Sky Tools 2.)
| Arp
Number |
Other ID |
Con |
Mag |
SBr |
| 153 |
Centaurus A |
Cen |
7.7 |
23.3 |
| 26 |
M 101 |
UMa |
8.3 |
24.4 |
| 168 |
M 32 |
And |
8.8 |
21.9 |
| 85 |
M 51/Whirlpool |
CVn |
8.9 |
22.1 |
| 337 |
M 82 |
UMa |
9.2 |
22 |
| 134 |
M 49 |
Vir |
9.3 |
22.7 |
| 37 |
M 77 |
Cet |
9.5 |
22.4 |
| 152 |
M 87 |
Vir |
9.5 |
22.3 |
| 16 |
M 66 |
Leo |
9.6 |
22.1 |
| 281 |
NGC 4631 |
CVn |
9.7 |
22.3 |
| 29 |
NGC 6946 |
Cyg |
9.7 |
23.5 |
| 154 |
Fornax A radio source |
For |
9.8 |
23.3 |
| 116 |
M 60 |
Vir |
9.8 |
22.5 |
| 135 |
NGC 1023 |
Per |
10.2 |
22.4 |
| 77 |
NGC 1097 |
For |
10.2 |
23.3 |
| 317 |
M 65 |
Leo |
10.2 |
22.1 |
| 76 |
M 90 |
Vir |
10.2 |
23.1 |
| 269 |
NGC 4490 |
CVn |
10.6 |
22.3 |
| 41 |
NGC 1232 |
Eri |
10.7 |
23.4 |
| 244 |
NGC 4038/Antennae/Ring Tail |
Crv |
10.9 |
22.9 |
Tables like this and finder charts can be generated from most
observational planning programs: DeepSky, SkyTools and AstroPlanner are
just three examples. But tables and charts can only take
you so far – it really helps to have the benefit of an experienced
observer to help you identify what you're looking for. Enter
Alvin Huey's - Observing the Arp
Peculiar Galaxies.
The guide is spiral bound to lie flat on the observing table. The
cover is a hard, laminated plastic, obviously waterproof, and the pages
are nice and thick so you won't need to worry overmuch about dew. At
10" by 11.5" and just over 1" thick, the guide is large but
manageable.
Open Observing the Arp Peculiar
Galaxies and you'll immediately find some preliminary material
on the origin and setup of the catalog along with the standard bits
concerning observing sites and equipment. After this you'll reach
the meat; nearly 400 pages devoted to the 338 galaxies in the Arp
catalog.
As a good observing guide should be, Observing
the Arp Peculiar Galaxies is organized by constellation. It
begins in western Pegasus, and proceeds around the sky until
you arrive back in Centaurus. Each section is
preceded by a regional, naked-eye finder chart where the Arps for that
particular area of sky are marked by two rings that represent the inner
rings of the Telrad or the two rings of the Rigel Quickfinder. Further
on this page, Mr. Huey provides a table listing the Arp number,
other ID, coordinates, magnitude, size, specific constellation and
Uranometria 2000 2nd edition page number. The charts work
well for quickly narrowing down specific sections of the sky, and with
the brighter Arp's are all that are really needed. For the dimmer
galaxies, one may want an additional resource (such as U2k)
to help narrow the field before making use of Mr. Huey's excellent
eyepiece finder charts.
Turn the page, and you'll find detailed notes for that particular
section of the sky. Typically there is one Arp to a page, and on
that page you'll find; the Arp number, it's classification, an
eyepiece finder chart, a white-on-black image reversed DSS image with
all components, a listing of nearby galaxies, observing notes (the
majority appear to be done with a 22" f/4.1) on all items of interest
in the field, an eyepiece sketch, and notes on the aperture,
magnification, field size, seeing, and conditions for the observations.
If you've seen Mr. Huey's other observing guides (The Hickson
Group Observing Guide, The Abell Planetary Observers Guide), you'll
spot the absence of an observers "note page" where we were provided a
spot to include our observations in the volume itself. When I
spoke with Mr. Huey about this he indicated that feedback showed few
observers used it, and given the sheer size of the Arp guide he felt
removing it would help keep the size of Observing the Arp Peculiar
Galaxies a bit more manageable. In effect it cut the size down to
one volume from what would have been two.
About the only nit one could pick is the presence of a few typos and
minor grammatical errors scattered throughout the volume. But
this is the type of thing that you run into in nearly any
self-publication (I know these pitfalls all too well
). There's nothing serious, and
certainly nothing to detract from the usefulness of the book.
All in all, I found this to be another excellent work from Alvin
Huey. Observing the Arp
Peculiar Galaxies is a resource that belongs on every
serious deep sky observers bookshelf, and is a must have for observers
looking to add Dr. Halton Arp's trophies to their collection.
