For those of you who don"t know
me, I build large Dobsonian telescopes as a hobby. My definition of
large is
24" and up. I teach telescope building classes that emphasize the
reasoning
behind doing something a certain way, rather than just following a set
of
plans. I consider myself a more than competent woodworker. I am an
AstroMart
Moderator, and I currently use a 30" f/5.3 Dobsonian telescope that I
designed
and built myself. The largest telescope I have built is a 36". I have
owned or
used almost every brand of Dob in the world, and when a new one comes
out, I
can"t wait to put it to the test.
There was quite a bit of anticipation surrounding the
Astro-Tech 16, it was supposed to be a souped up version of the Meade
Lightbridge.
Costing $400 more, it was going to have to be pretty special
considering they are both made by the same company, GSO of Taiwan.
I had
borrowed a Meade 16" Lightbridge some time ago but it did not impress
me.
It
almost seemed like the people who designed it went out of their way to
make it
not Astro friendly.
White painted lips inside the tube, bearings that rode on
felt, ALT bearings that were dished out to make it as difficult as
possible to
add encoders... I did not even bother with a review, I simply returned
it.
I got the very first production unit from Great Red Spot.
I
told the owner, Jeff Hindline, that I wanted a sealed unit.
That way no cherry
picking of the optics could take place, and I could relate what the
average
user would encounter when purchasing this scope.
He agreed and it went
something like this:
ARIVAL
The scope comes in 3 large boxes weighing in at 155 lbs
total.
My office scale says that the entire scope when unboxed weighs a mighty
141 lbs
(That"s more than a 20" Obsession weighs).
Now don"t assume that
extra weight is always a bad thing.
It can make a scope actually more stable.
Most people who have used an "ultra light" telescope can relate to
what I"m
saying.
How can a smaller aperture scope weigh more than a larger
one?
Two reasons; the scope base is physically larger and it is made of
particle board.
The Ground Board of the scope is almost 32" across!
That
would be the size of a GB on a 25" truss scope.
Again, a large GB gives the
scope a wide stance, and that can equal stability.
Particle Board can weigh
twice as much as plywood, and can degrade in wet conditions, but the
thousands
of GSO Dobs out in the field shows their fused plastic coating does a
good job
repelling moisture.
INITIAL ASSEMBELY
The contents of the
base box.
Inside the largest box is the Ground Board, the Rocker Box,
three Struts and a box of hardware.
No instructions or diagrams were included
with the scope.
I"ll cover assembly a little more thoroughly than usual to
help out the early adopters.
Bottom of Ground
Board
The bottom side of the GB (the side without the Teflon) gets
the three feet using the three gold screws.
You could even make this scope a
tad more stable by placing the feet directly under the Teflon pads, or
moving
them all the way out to the edge.
I did not want to drill any additional holes
in a scope that was not mine, so I used the predrilled holes provided.
Roller Sandwich
The Rocker Box rides on a hybrid system of both "lazy susan"
rollers and Teflon pads.
It looks like in this case that the Teflon functions
as a speed control, keeping the scope from spinning too fast.
The rollers are sandwiched between two, thin metal discs.
The plastic coating on the particle board would bee too rough to roll
directly
on.
The GB was very dusty out of the box.
I vacuumed up the debris to keep it
from getting into the rollers before assembly.
Hybrid system
Rocker Box Damage
At this point in the review I"m
going to point out that the underside of the Rockerbox was damaged in
shipping
because the staples that hold the Teflon pads on were not set beneath
the
surface of the Teflon.
So the metal staple scraped up the bottom plastic
coating of the RB.
I always teach my telescope
students that using screws, staples, or nails to hold the Teflon on to
the
scope is false economy.
Sooner or later the soft Teflon will wear down to the
metal fasteners and the screws will destroy the bearing surface.
Always use
"Acid-Etched" Teflon and GLUE it onto the telescope.
Because you get to wear
the entire thickness down, you get twice the service life out of the
Teflon.
The big fix
Using a standard screwdriver, I tapped all three of the
staples halfway beneath the surface of the Teflon.
Shave at a very low
angle
To repair the bottom of the RB, I simply shaved the rough
plastic coating at a very low angle with a fresh razor knife blade.
Testing
the scope, I could not detect the point where the repair was made.
The Azimuth Tension Knob allows you to crank down the
resistance of the GB.
In practice, the best match for the resistance of the
Altitude knobs was leaving the knob not cranked down at all.
This "loose"
resistance setting gave the best feel.
Dobson"s Hole was easy to cruise
through, but please be reminded that the scope and Teflon was new.
It is
possible that after the Teflon wears down a bit, more resistance will
be
required.
Time will tell.
I usually paste wax the surfaces that ride against Teflon,
but the scope moved so well, I did not bother.
I would give the whole scope a
waxing once a year to keep the rust away.
Rocker Box Sides
The Rocker Box sides are plastic coated particle board also.
They accept the two carrying handles.
If this was my own scope, I would move
both the handles to the front board of the scope, because the way they
are
designed to be installed, they are too far apart for easy carrying.
The hardware box came with an Allen Wrench hex tool to screw
everything together with.
Please, save you fingers and use a hex bit in your
cordless drill.
Be careful to not over tighten the screws or they will easily
strip out in the predrilled particle board holes.
If you do strip a screw
hole, drip a few drops of white glue down the hole and screw it in
again in the
morning.
Each side of the RB has a slot that accepts the LOTA (
Lower
Optical Tube Assembly).
There is a piece of felt adhered to the leading edge
of both slots so you don"t chew up the wood every time you slide it
in; very
clever.
One piece was un-adhered as delivered, so I simply wiped clean any dust
and stuck it back where it belonged.
I"m glad one piece was already properly
installed, because without directions, I would have never guessed where
those
pieces of felt belonged (and that they are applied over the leading
lip).
Lower OTA Box
Inside the LOTA Box we have the Finder Scope box, the LOTA
and the mirror cover, also known as the "Trash Lid".
In the past year, many
Meade owners discovered that the Trash Can Lid had worked itself loose
in
shipping and had destroyed the optics of their Lightbridge.
Astro-Tech was
wise to specify that the lid should be nowhere near the delicate mirror
during
shipping.
It may surprise some that the mirror is just sitting
unprotected inside the LOTA.
The LOTA
is
in a plastic bag, so it
is
protected from dust.
This seems like a workable system and of course, far
better than the Trash Lid damaging the optics.
There is no way on person can lift the LOTA out of the
depths of the box.
Better to cut the tape on the bottom of the box and just
let the LOTA and the Styrofoam base slide out on to the floor.
ALT Bearing
The coolest and most innovative thing about this telescope
is the Altitude bearings.
Most telescopes are just copies of tired designs
from 20 years ago, but this is something new
and functional.
The ALT bearing is a big hunk of machined aluminum that
will impress any real man.
I took off one of the knobs to see how the system worked and
I just had to heft the knob in my hand a few times and smile.
One can easily
imagine milling a 1 /4" hole into this knob and it being ready for
encoders.
ALT bearing w/o knob
What's inside the
ALT knob.
Under the knob are a few washers and a Needle Roller Thrust
Bearing that make the whole system work so smoothly.
Those of you who tried
the sticky and jerky Starhopper Dob resistance system and expected more
of the
same are in for a pleasant surprise; the AT16 is smooth!
The second part of what makes these ALT bearings so great is
that you can adjust the Center Of Gravity by moving the bearing center
point
back and forth.
A scale is engraved (well, probably stamped, I could not tell)
on the hub so you can adjust both sides identically.
I"ve seen this feature
before on expensive, semi-high end Dobs, but never engraved with any
type of
scale, and certainly never this precise.
I"ll discuss more about this feature
in the use section of the review.
Contents of the UTA
box
The Upper Tube Assembly box held the UTA, Battery pack for
the primary mirror fan, 30mm eyepiece, and a 9mm eyepiece.
Although advertised
as being included, there was no laser collimator or moon filter
included with
the scope.
It was nice to see a battery pack, jack and wiring included
with the stock scope.
I don"t know how many times I"ve seen people unpack
their mega buck Obsession scope, only to discover that Obsession gives
you a
fan with just dangling bare wires, no battery pack or jack and no way
to hook
it up.
Mirror Cell - Yes,
they left a gap between the mirror face and the safety clips.
The Mirror Cell was an odd contraption.
The mirror was
supposedly floating on an 18 point cell, but the mirror was glued in
with big
black globs of silicone, so the floating points could not be examined.
There
were three safety clips that would hold the mirror in place should the
silicone
fail (fat chance, they used a lot of silicone).
The clips were mounted about a
millimeter above the face of the mirror (as it should be).
If the clips were
to touch the mirror face, they would induce astigmatism into the image.
The mirror is actually 1/16" of an inch shy of being a full
16".
The center spot was measured and determined to be accurately placed.
Rear Cell - Don't
use the white knobs.
On the rear of the cell there are three black collimation
knobs and three white "lock" knobs.
The lock knobs are too far away from the
collimation knobs to act as locks, so they become collimation knobs
themselves.
Just ignore them.
You have to collimate every time you set the scope up, so
don"t bother trying to lock it down.
If for some reason you are intent on
using the locks, drill and tap new holes as close to the collimation
knobs as
possible, and move the knobs to their new homes.
Credit has to be given to AT for supplying knobs rather than
screws that require tools to use.
Whoever thought it was a good idea to need a
screwdriver or coin to collimate those other Dobs every night, clearly
was not
an astronomer.
There are three feet on the rear of the cell so you can
place the LOTA on the ground without scratching up the collimation
knobs.
Nice
idea, the LOTA is heavy, so it"s going to be seeing plenty of time on
the
ground.
Plenty of clearance
for aftermarket encoders - very nice.
The LOTA when placed in the Rocker Box has plenty of
clearance over the AZ pivot point for the mounting of some aftermarket
digital
encoders.
One of the feet is in the worst possible location for clearance, but
you can simply unscrew it and move it over a few inches, if you need
additional
room.
Most modern encoders are so slim, they will not require this step, so
it"s certainly not going to be a problem for most users.
SETUP FOR OBSERVING
To set the scope up, you place the Rocker Box on level
ground (I always rock the scope a bit to seat it in the dirt).
Then you place
the LOTA into the Rocker Box by sliding it into the provided slots.
The seam
on the LOTA faces away from you so the front Strut will be on top of
the
assembled scope.
The importance of this will be apparent latter on in the
review.
Any decently strong person should have no problem lifting up
the LOTA and getting it into the Rocker Box.
If you have back problems, you
better get another person"s assistance.
My 95 lb. Spinner girlfriend could not
quite do it by herself.
It is harder to get the LOTA out of the box during
teardown than it is getting it in. So make sure you are not the last
guy left
out on the observing field if you had difficulty getting it together in
the
first place.
Back and Front sides
of the Struts
The Struts are held in place with 4 knobs each.
DO NOT CALL
THESE
TRUSSES!!!!
Trusses are
triangles, and these Struts certainly do not form any type of
structural
triangle.
The struts are made of extruded aluminum.
You can just feel them
deflect when you squeeze them, but they seem plenty stiff for the job
at hand.
The shafts of the knobs and the receiving sockets were
clearly painted after having their threads cut.
The paint made them hard to
assemble.
I used a tap and cleaned up the holes and used a die to clean up the
shafts.
This made assembly much easier.
If you don"t have a tap and die set,
any real hardware store (not Home Depot) will perform this service for
a few
dollars.
They might even do it for free, once you explain to the bewildered
clerk that the parts form a telescope.
Do not use any grease or WD-40 thinking
that you are going to lube the threads up.
This will just attract grit in the
field and make things worse.
After attaching the three Struts to the LOTA you hold onto
the UTA and get the knobs from the struts started.
DO NOT LET GO OF THE UTA
BEFORE HAND!
There is no positive stop to lay the UTA onto during this
process, so if you just set the UTA around the Struts, it can fall at
any time.
It is not secure until the knobs are in!
Go around and re-tighten all of the knobs now that the UTA
is installed.
The addition of the UTA changes the angle of the Struts, so they
need the final tweak.
UTA and Spider
assembly
I checked the focuser for square-ness and it was almost
perfectly square.
A small tweak of the focuser screws fixed it nicely.
The
secondary positioning was only off by 1/8", that"s the closest
I"ve ever seen a
Far East scope.
Using the CatsEye sight tube, I corrected the offset.
The Secondary Holder was clearly a leftover from some other
GSO scope.
Most GSO scopes require an Allen Wrench to make the adjustments to
the secondary.
Scopes designed by astronomers have knobs to adjust the
secondary, so that you don"t drop any tools onto the expensive
primary while
collimating.
The AT16 requires a Philips screwdriver to make the adjustments.
This is even worse than an Allen Wrench because if you drop a
screwdriver on
the mirror, you are likely to do much more damage than a little Allen.
In
addition, Philips screw heads will strip out from repeated torque
(remember, you
are going to make this adjustment EVERY time you observe).
And it gets worse.
The Philips screws have sharp, circular
ends that dig into a soft metal plate on the secondary holder.
So instead of
each adjustment screw deflecting the mirror in a predictable pattern,
they make
the mirror spin in a little circle!
It was maddening.
I took out the screws and used a metal file to smooth off
their ends.
Then I placed a hard metal washer over the soft metal plate.
This
fixed the problem, but it"s something that really should have been
done at the
design stage.
If you buy this scope, be sure to replace the Philips screws
with Socket Head Hex Screws, and place Knob Caps over the heads so you
can use
your fingers only for collimation. I"m sure you have a metal washer
in the
bottom of your tool box. Your blood pressure (and primary mirror) will
thank
you.
The amount of
movement of the primary, over a 45 degree span
I like to collimate most Dobs at 45 degrees of elevation.
That way you spit the difference if there is any deflection (there
always seems
to be a little bit) as you move the scope through its arc.
I was not prepared for the amount of movement I saw in the
AT16.
The above picture shows just how off the collimation became moving the
scope just half way through its arc.
I knew I had the spider centered and
tightened as far as it would go, and I knew the Struts were tight, so
my
suspicions went to the mirror cell.
Sure enough, the three springs in the
bottom of the mirror cell are not strong enough to support the heavy
16"
mirror.
Playing with the springs, I would guess that they would be a good
stiffness for a 10" mirror, maybe.
I wedged some Styrofoam between the cell
and frame to help the springs support the mirror, but if I was keeping
this
scope, the very first thing I would do would be replace those springs
with some
stiff ones from the hardware store.
You really can"t use the scope without
them.
OBSERVING
A huge storm had just blown past, killing power to much of
South East Michigan.
And as it often happens, a nice patch of clear sky
followed the storm.
With the power out, the skies were darker than usual.
I was anxious to star test the optics because the only thing
we could test on the club"s interferometer was the secondary (which
was a
little over 1 /4 wave - a good number).
Due to the primary being glued into
the cell, it was very front heavy.
This caused the stepper motors on the
testing stage to stall or jump track.
Normally the mirror lies in a metal
sling at the center of gravity.
We tried to rig up some kind of counter
balance, but we just did not have enough tools on hand to make it work.
We
sure did not want to risk the testing stage dumping the mirror on its
face!
I used an 110v house fan to cool the mirror, as there was no
telling how long our patch of clear sky would last.
On the 16" Lightbridge I
had borrowed, the included fan had usually taken 2 hours to equalize
the
mirror, and I was not going to wait that long.
After 30 minutes of high speed
fanning, the mirror was within 3 degrees of the ambient air temp (I
tested it
with a Laser Thermometer), so I figured that was close enough to start.
I wanted to test the scope as delivered, so I started with
the included eyepieces and finder scope.
The finder scope is a Right Angle unit, with nice looking
coatings throughout.
Spinning the knurled grip on the front lens brings the cross hairs into
focus.
The adjustment knobs on the holder work very smoothly; much smoother
than the
ones on my old XT10.
The finder exhibited some astigmatism, but who cares in a
finder?
It"s not like you are going to be taking pictures through it.
I"ve been using a Telrad for so long that the RA finder was
a bit of a switch for me; especially on such a large scope.
You need to sight
the scope like you would a gun, and then spiral around while looking
through
the finder scope until the object is centered in the view.
The top Strut has a
nice set of bright chrome screws to use just for this purpose.
I"m sure after a few nights of practice it would become
second nature to use the RA finder, but like the Good Book says"¦
He
knows the
time is short (Revelations
13:18), so I
pulled the magnetic Telrad finder off my 10"
scope and stuck it on the UTA.
After a quick alignment I was in high speed
star hop mode, without standing behind the scope or craning my neck.
M13 was at zenith, so I felt that would be a good target to
try the included 30mm eyepiece with.
The eyepiece was sharp in the center, but
the outer 40% was almost useless.
Trying the 9mm eyepiece on Saturn was about
the same.
As the planet drifted from one edge of the eyepiece to the other,
you could see that the outer 30% of the eyepiece was a blur.
The included
eyepieces are not up to the caliber of the rest of this scope.
They may work
better on a scope with a longer focal length, but it"s just as likely
they
won"t.
Plan on buying some better eyepieces to get your money"s worth out of
this scope.
Switching over to Nagler eyepieces gave the scope a new
life.
At 60X with the 31mm Nagler, the scope delivered the wide, sharp views
you expect.
At 370X with a 5mm Nagler, the scope was near the limit of the
seeing for the night.
Sliding along the Moon"s terminator there were moments
of clarity that showed nice, high contrast images.
The temperature kept dropping and clouds came in so no definitive
star test ever occurred.
THE SCOPE ITSELF
The first thing you notice is that the scope is black.
Why
would anyone design a white scope that reflects any available ambient
light
into your unused eye?
Who would want all of that glare around the eyepiece?
The only thing that could have made the color choice better is if it
were flat
black.
The AT16 has over a half inch of wobble in actual use.
If
you are accustomed to the super stiff, zero backlash movement of a well
built
truss Dob, you are going to need an hour or so to acclimate to the
"feel" of
the AT16.
At high powers, I learned to slightly overshoot my target, so the
image would snap back into the eyepiece. The OTA is stiff enough, but
the base
is too tall and thin, so the wood itself flexes side to side.
I would describe
the motions of this scope as "smooth but springy".
If this were my scope, I
would add two vertical "fins" perpendicular to the Rocker Box sides
(there is
plenty of room on the Ground Board) to stiffen the structure.
Looking through the empty focuser, you can see over the UTA
into the sky.
This means that the focuser is too close to the front of the
scope and stray light will enter the eyepiece.
Owners will want to add a
lightweight plastic light baffle opposite the focuser for maximum
contrast.
A sharp tap on the UTA results in a 3.5 second wait for the
vibrations to dissipate.
I numbered the Struts, and then disassembled and reassembled
the scope to see how closely it held collimation.
It was way off every time.
I think it"s because you can seemingly always turn each Strut knob a
little
more.
They never just bottom out.
It is no big deal; just remember you have
to collimate the scope EVERY time you set up.
THE FOCUSER
The Focuser was a very serviceable 2 speed unit.
It moved
quite smoothly.
I"m not saying it is going to put Feathertouch out of
business, but it is a great piece of hardware.
The eyepieces are protected
with a brass compression ring, so you won"t have a bunch of set screw
marks all
over your barrels.
CAUTION: don't ruin
your filters!
Quite a few years ago Feathertouch started threading their
1.25" adapters so you could use standard 2" filters with your
1.25" eyepieces.
This saved you lots of money buying redundant 1.25" and 2" filter
sets.
The AT16 1.25" adapter is threaded for 2" filters, but they
did not make the adapter deep enough to clear the base of an eyepiece.
So if
you actually try it, you will damage your 2" filter when the two
collide.
Again, no astronomer designed this "feature" before the adapter
went into
production.
Most larger camera shops have 48mm extension rings, make sure you
get one deep enough to clear ALL of your 1.25" eyepieces.
BALANCE
OK, I admit, I saved the best for last.
The AT16 balances
perfectly with no counterweights.
Yep, you read that correctly.
Go ahead and
read it again.
Every Far East Dob usually has a bunch of magnets hanging
off it, or gym weights or lead shot.
Sometimes they don"t even balance with
the lightest, included eyepiece.
Not this baby.
I could go from the 5mm
Nagler all the way to the monster 31mm Nagler and all I had to do was
crank
down the ALT bearings.
Cranking down the ALT bearings did not make the scope
movement sticky at all.
It was smooth and silky.
After I moved the adjustment back on the ALT bearing, I
could even use the Denk II Binoviewers with no counterweight!
To say I was
impressed would be an understatement.
SUMMATION
I know this was another of my lengthy reviews, so many of
you just skipped down to the summary wanting to see if the scope is
worth $400
more than the 16" Lightbridge.
The answer to that would be - YES.
The
innovative ALT bearing resistance system is worth the money all by
itself.
To
just simply observe without having to toy with counterweights every
time you
change eyepieces is one step closer to that elusive perfect scope.
BUT and this is a pretty big but; if you did not read the
review, you need to know that the scope is not ready for starlight
right out of
the box.
It is said that every Dob is a project, and this scope certainly will
not dispel that truism.
What are you giving up with a $2500 16" scope that you would
be getting with a $6000 16" scope?
The premium scope would be lighter,
smaller and come with wheels to move it about.
It would also have a better
spider you could really tighten down, a better secondary holder and a
deeper
UTA that would block out stray light.
It would have a primary mirror that you
could simply reach in and remove for cleaning or recoating.
It would have a
mirror cell that did not use springs to support the mirror.
Finally, it would
come with a light shroud and a neck saving Telrad finder.
Hopefully, some company will come out with a conversion kit
that will have 2 plastic coated matching reinforcement fins for the
base, 3
thumb screws and washer for the secondary, 3 heavy duty springs for the
cell
and a 48mm extension ring.
A Light Shroud would be nice too.
Of course, I
would hope that Astro-Tech would simply include those necessary
improvements
with the next shipment of scopes, but I guess I know better.
Clear Dark Skies,
Dave Bonandrini
6/15/08
