In the interest of
full disclosure, I have no financial stake in any of the companies
mentioned in the following article. Additionally, special thanks to
CN forum poster JayKSC for providing the exact year Meade
discontinued the Japanese series 4000, as well as moderator BCB for
providing the link to the archived Masuyama thread which provided me
with some of the history I incorporated into this article.
For many years, the
Meade series 4000 eyepiece line stood on the teetering point between
the mass market and the high end for intermediate observers. They
offered a number of “standard” “wide field”
and “ultra wide field” oculars clearly targeted as being
a less expensive alternative to TeleVue’s venerable eyepieces.
Among the eyepieces in the Series 4000 line were what they referred
to as “Super Plössls.” What made them super as
opposed to standard garden-variety Plössls? For one thing, they
weren’t really Plössls. Meade’s original SP
configuration was a 5-element design much more akin to the somewhat
obscure (but highly revered in some circles) Masuyama eyepieces
manufactured in the 80s. This configuration integrated a singlet lens
between the two achromats and provided better edge sharpness as well
as a slightly wider field of view than a standard Plössl. The
price point was typically about halfway between standard Plössls
sold by companies like Orion and Celestron and “premium”
Plössls sold by TeleVue. For a lower cost, Meade also sold
standard Plössls under the “Series 3000” line. Both
lines of oculars were manufactured in Japan. Orion and Celestron sold
similar “pseudo-Masuyama” eyepieces under their
Ultrascopic and Ultima lines, respectively.
All of this changed
gradually over the last 11 years. In 1998, with little to no fanfare,
the Series 3000 Standard Plössls were phased out, leaving behind
only the Super Plössls. Additionally, all Japanese manufacturing
of Meade-branded eyepieces ceased that year as well. One fact that
Meade drew as little attention to as possible was that the new Super
Plössls were no longer the pseudo-Masuyama configuration they
previously had; they had very quietly been replaced with standard
symmetrical Plössls. These were NOT the same eyepieces that had
built up a legion of happy customers, although they still kept the
identical moniker of “Series 4000 Super Plössls,” as
well as the same range of focal lengths and similar external styling.
These eyepieces were manufactured in Taiwan.
With lots of fanfare
over the period from 2002 to 2005, Meade began debuting their snazzy
new “Series 5000” eyepieces. The introduction of these
premium eyepieces, clearly intended to be competition to TeleVue (but
with outer barrels that were more aesthetically distinctive from
TeleVue’s, unlike the Series 4000 predecessors) coincided with
the transfer of all of Meade’s eyepiece manufacturing from
Taiwan to China. The Series 4000 eyepieces were kept in Meade’s
product line (at a lower price point than before, and also now of
Chinese manufacture), but were shoved further into the background.
During this time Meade introduced a new, Chinese-manufactured
pseudo-Masuyama line. The Series 5000 “5 element Plössl”
(some with 6 elements in an unknown-to-this-author configuration)
picked up the long-dropped baton as the higher-end hybrid Plössl
in Meade’s lineup.
So how do all of these
eyepieces compare with one another? To find out, I recently tested a
current (China-stamped) 12.4mm Series 4000 symmetrical Plössl
against the following borrowed eyepieces:
Late model
(pre-1998) 12.4 mm 5 element Series 4000 Super Plössl
Late model 9.5mm
Series 3000 Plössl
Current model 14mm
Series 5000 5 element Plössl
While I would have
preferred that all eyepieces tested were to be of the same focal
length, neither the series 3000 nor the current series 5000 were
available in the 12.4mm focal length. In each case, the nearest
available focal length was tested. The following table is a rundown
of how the eyepieces stacked up against one-another:
5000
3000
4000 (late)
4000 (current)
Apparent FOV
60 degrees
50 degrees
55 degrees
52 degrees
Edge Sharpness
Very good
Good
Very Good
Good
Center Sharpness
Very Good
Very Good
Very Good
Very Good
Color Correction
Very Good
Good
Very Good
Good
AR Coatings
Very Good
Good
Good
Very Good
All eyepieces showed
very good images in the center of the field of view, although the 5
element models showed a slightly better edge sharpness. In both
configurations, the older Japanese eyepieces were very slightly (but
noticeably) sharper than their newer versions, and the older
eyepieces had slightly better color correction than their newer
counterparts as well. As stated in the graph, however, the
differences were greater between each configurations rather than
between manufacturing date and origin. The 5 element models had a
slight edge in terms of apparent FOV, but not a huge difference; if
you want a wider FOV, go for a dedicated wide-field eyepiece. The
newer models have darker, fuller multi-coatings on the lenses than
the discontinued models, but this did not translate to a noticeable
edge in performance.
In terms of overall fit
and finish, the older models had a much more substantial (not to
mention noticeably heavier) feel. The newer ones felt slightly
cheaper, but the current series 4000 eyepiece still felt heavier and
more substantial than comparable Celestron “budget”
Plössls supplied with the Celestron 1.25” eyepiece and
accessory kit. In a strange twist, the series 5000 5-element Plössl
seemed somewhat ill suited for screwing in filters. For reasons I was
unable to determine, the series 5000 barrels friction with filter
threads and was more prone to the filter getting stuck. This can be
maddening, especially in the dark. I also find it rather curious that
all problems with filters came from filters manufactured by Orion and
Celestron; a Meade Series 4000 80A blue filter screwed on with no
problems. I have heard anecdotal reports that Meade is using a
non-standard eyepiece barrel thread to encourage their customers to
stick with only Meade accessories. If so, that is a marketing tactic
I would have great difficulty respecting. If this were true, however,
why was there no difficulty presented by the current series 4000’s
filter threading? As it is, I’m willing to chalk this up to the
random result of a bad sample. Nevertheless I find these initial
problems peculiar.
All of this may sound
as if I am coming down hard on the new Meade eyepieces, but this
isn’t the case at all. The current Series 4000 Plössls are
very good eyepieces as long as you know what you’re buying, and
are excellent as “budget” Plössls for beginning
amateurs wanting to build up a wide range of focal lengths on the
cheap. Meade’s series 4000 accessory kit (typically selling for
approximately $250) is an attractive option for those observers. For
those buying one or two eyepieces to fill in gaps in their
collection, Meade’s Plössls typically sell at a lower
price point than comparable eyepieces from Celestron or Orion, and
they provide excellent views for that price point. If, however, you
want the absolute best performance from a Plössl or hybrid
Plössl, seek out the discontinued 5 element oculars on the used
market, as well as the (currently in the process of being phased out)
Orion Ultrascopic and (now discontinued) Celestron Ultima eyepieces.
While all of the eyepieces tested were of high quality, the
discontinued 5 element model was clearly the cream of the crop. The
pseudo-Masuyama design is highly regarded for a reason, and the older
Japanese optics certainly have the edge over their newer Chinese
analogues.
Post script: Digging
through the archived Masuyama discussion thread provided by BCB
(http://www.cloudynights.com/ubbarchive/showflat.php/Cat/0/Number/748617/page/0/view/collapsed/sb/5/o/all/fpart/1
), it has become apparent that Celestron’s Ultima and Orion’s
Ultrascopics are actually sourced from the Masuyama optical company
in Japan, which is apparently still producing eyepieces (just not
under their own brand). This information came from a representative
of Baader planetarium, a company that still sells Masuyama sourced
eyepieces. There is a possibility that Masuyama was the original
source of the Japanese Meade Super Plössls, but this has yet to
be verified.
