Home / Zhumell 12" Dobsonian Altitude Bearing Modification
by Andrew De Luca 07/27/10
 Voice your opinion about this topic in the forums
By Andrew J. De Luca
I found the altitude & azimuth bearings to be very loose on my Zhumell even when the knobs are turned down tight.
Upon removing the knob I found a roller bearing between two washer. Behind that is a plastic clutch that tightens around the shaft when pressure is applied by tightening the knob.
Figure 1
Figure 2
I tried to find the washer at Home Depot and my local hardware store without luck. I opted to fabricate one out of a piece of 1" PVC pipe. I cut 1/4 inch pieces and than used coarse sandpaper to get them under 1/8" and finished them with emery cloth.
Figure 3
Figure 4
Figure 5
Figure 6
Figure 7
When rebuilding I left the outer washer off. The fabricated washer is held in place by the shaft and the knob housing.
Figure 8
The tube still moves like butter but now the bearing clutch grabs and holds. The tube stays erect when applying pressure or moving the scope out of the garage. Total cost of project about $20.00 including tools completed in under 3 hours including planning & shopping.
Upcoming projects:
  • Wheels
  • Azimuth Clutch
Back to Top
Contact Us
CN Reports | Reviews | Articles | Forums | Classifieds | About Us
Copyright© 2004 Ad Libs Advertising.
Privacy Policy
Search Cloudy Nights
Advanced Search
Friday, May 24, 2013
Cloudy Nights Supporters
Astronomics
Telescopes  www.astronomics.com
