I've been into astronomy for 30+ years now and have seen and used a good many different eyepieces. Being primarily
a planetary observer in my early years, I used only orthos. I remember the eyepiece that I would use all the time
on the 12 ½" f/10 scope, would be the Meade 12.5mm ortho. Saturn would look great through this eyepiece.
A few years later, University Optics orthos caught my attention, so I bought a set and have used them since. These
UO orthos were the best going eyepieces and were hard to beat. Even when using Zeiss orthos, I would always revert
back to the University Optics orthos. So it just goes to show that you do not have to spend an astronomical amount
of money to get great eyepieces.
When it comes to the planets, orthos are definitely the way to go (or so I thought) for sharpness contrast
and brightness. The only thing I was looking for in eyepieces when observing the planets was good eye relief. Well,
I finely found the eyepieces that give the eye relief, brightness, sharpness and the contrast. These eyepieces
are made by Siebert Optical. Not only is the owner Harry a joy to do business with ( which is hard to find today
) but you can personally talk with the designer about the eyepieces that he makes.
After asking Mr. Siebert which eyepieces he would recommend for observing this coming Mars opposition, he recommends
his 7mm, 10mm, 12.5mm to be used with my 6" f/8 refractor. I've read some good reviews on his 10mm eyepiece
being used on M42 with great results and the same with his 12.5mm, so knew I would be able to use these for my
deep sky observing also. Well, enough about all of this, and onto my results of the testing that I did with these
eyepieces.
My testing began with the 12.5mm Siebert against the Meade 12.5mm ortho, UO 12.5mm ortho and a Meade 12.5mm
Plossel. The eye relief of the Siebert was more comfortable to view through than either of the Meade eyepieces
and the UO ortho. I began testing the eyepiece for coma near the edge of the eyepiece. This was a main concern
I had after reading that this was a minor problem with the Siebert in fast scopes. In my f/8 refractor stars were
pin points all the way across the whole field of view with no coma seen at all. With the Meade Plossel there was
coma near the last 10% of the field of view, while there was no coma at all in the Meade or UO 12.5mm orthos. As
for sky blackness, the Siebert was the best. I then moved onto Jupiter to compare sharpness and contrast among
the four 12.5mm eyepieces. At 384x with the help of a 4x TV POWERMATE, the Plossel was in the back seat compared
to the two orthos and the Siebert 12.5mm eyepiece. The Siebert was sharper and was a good deal brighter than the
Meade ortho and was running head to head with the UO ortho. In brightness the Siebert out did the Meade Plossel
and was a tad bit brighter than the UO ortho. The Siebert beat the Plossel in contrast and had just a tad bit more
contrast than the UO ortho and the Meade ortho (the difference was slight but noticeable among the three). I find
myself using this Siebert 12.5mm eyepiece a lot for globular clusters in my 9 ¼" SCT also.
The Siebert 15mm eyepiece ( that I got for deep sky observing ) is everything that the 12.5mm is, but with
a slight ghosting on Jupiter. It is brighter than the Meade 4000 series 15mm SP and the sky is much blacker also.
When compared to the UO 15mm ortho on Jupiter, the only problem it has is the ghosting like I said earlier. As
far as brightness goes it is equal to the University Optics ortho, but because of the ghosting it loses out on
sharpness and contrast. Where the Siebert 15mm excels, is on deep sky objects. When observing open clusters with
the 15mm Siebert and the 15mm SP Meade, the Siebert is sharper and with no coma at all across the whole field of
view. The Meade had no coma also, but where the Siebert beats the Meade is in the blackness of the sky which makes
the stars sharper.
My two new favorite Lunar and planetary eyepieces are the Siebert 7mm and 10mm wide angles.
All I can say is that the 7mm is great. It is very sharp and shows a lot of sharpness on Jupiter and Saturn.
Contrast is a must see to appreciate kind of thing with this eyepiece, with a lot of detail being seen easily.
I compared this eyepiece against one of the greatest planetary eyepieces out there, which is the one and only University
Optics 7mm ortho. Boy was it a fight to the end, no way did I ever think that this would be the best duel going
for me during this comparison. I thought for sure when it came to these two eyepieces that the University Optics
would walk all over the Siebert in contrast and sharpness. (I was only thinking this because I've compared the
UO 7mm ortho to a good many high-priced eyepieces and it always won) Well, it now had an eyepiece that not only
ran neck in neck with it in the contrast arena but also in sharpness and brightness. When it was all done and over,
the Siebert made me a believer that there was an eyepiece out there that could do it.
The end result showed that the Siebert 7mm Wide Angle was as sharp and had as much contrast as the old University
Optic 7mm ortho did. Siebert Optics just edged out the UO in brightness, and the background sky was blacker in
the Siebert 7mm Wide Angle than in the UO 7mm ortho. The Siebert 7mm has a 65 degree field of view compared to
45 degree field of view for the UO ortho. The same results were to be had with the Siebert 10mm comparison, with
the only difference being in brightness. University Optics 10mm ortho was a bit brighter between the two eyepieces.
I highly recommend the Siebert 7mm, 10mm, and 12.5mm for planetary observing and the 15mm for bright nebulas
and tight open clusters. With the 4x TV POWERMATE the 15mm is a good globular cluster eyepiece when the seeing
allows that kind of power to be used. I used the combo of the 4x POWERMATE and the 15mm in my 6" f/8 Refractor
on M13, what a sight it was, totally resolved right to the core with dark lanes running through the cluster.
I've read so many reviews where people say that in the looks department the Siebert's wont win any contest's,
but I must say that this is not all that true. These are nice looking eyepieces and very well built with a good
solid feel. They are very light weight which is good as far as I'm concerned. The other thing that gets me is when
reviewers write things like, these are nice sharp eyepieces for the money.
Come on now, these are great eyepieces even if they were $200 instead of $40 to $45. You do not hear this kind
of comment about the University Optics ortho's which sell at $55 to $65, and these are great eyepieces which have
stood the test of time. Mr. Siebert is doing use all a favor by making a good line of eyepieces at a very good
price, keep up the good work Harry. I own the whole line of Meade 4000's and all the University orthos, the whole
line of Vixen LV eyepieces and now I'll be owning all the Siebert's.
