SkyAtlas
2000.0
Uranometria
2000.0
FOV °
point
A
point
B
82mm =
10°
184mm=10°
82
184
mm
fov°
mm
fov°
UMi 1
3.2
B 7
UMi
y 13
UMi
front of the cup of
Little Dipper
25.5
3.11
59
3.21
UMi 2
2.7
z 16
UMi
n 21
UMi
back of the cup of
Little Dipper
22
2.68
51.5
2.80
UMi 3
4.8
z 16
UMi
B 7
Umi
top of the cup of
Little Dipper
38.75
4.73
89
4.84
UMi 4
5.4
n 21
UMi
y 13
UMi
bottom of the cup
of Little Dipper
44.25
5.40
101
5.49
UMi 5
3.9
z 16
UMi
15 Umi
top of Little
Dipper but only to #15
32
3.90
UMa 1
5.4
a 50
UMa
B 48
UMa
front of the cup of
BIG Dipper
44
5.37
98.5
5.35
UMa 2
4.5
d 69
UMa
y 64
UMa
back of the cup of
BIG Dipper
36.5
4.45
83
4.51
UMa 3
10.0
a 50
UMa
d 69
UMa
top of the cup of
BIG Dipper
82
10.00
UMa 4
7.9
y 64
UMa
B 48
UMa
bottom of the cup
of BIG Dipper
64.5
7.87
Dra 1
2.9
B 23
Dra
v 24
Dra
west side of Draco
head shortest
23.75
2.90
53.5
2.91
Dra 2
3.4
v 24
Dra
z 32
Dra
north side of Draco
head
27.75
3.38
63
3.42
Dra 3
5.4
z 32
Dra
y 33
Dra
east side of Draco
head longest
44.25
5.40
99
5.38
Dra 4
4.1
B 23
Dra
y 33
Dra
south side of Draco
head
33.5
4.09
76
4.13
Cas 1
4.9
B 11
Cas
a 18
Cas
brightest two west
side W
39.5
4.82
90
4.89
Cas 2
3.6
y 27
Cas
d 37
Cas
two closest stars
in the W
28.9
3.52
66.5
3.61
Cas 3
3.0
y 27
Cas
n 24
Cas
center of W south
to eta
25
3.05
56
3.04
Per 1
3.7
a 33
Per
d 39
Per
Mirphak to
brightest east
30.25
3.69
68.5
3.72
Per 2
4.8
a 33
Per
y 23
Per
Mirphak to
brightest northwest
39
4.76
87.75
4.77
Per 3
2.1
z 44
Per
o 38
Per
Perseus foot just N
of Pleaides
17
2.07
38.8
2.11
Tri 1
2.0
B 4
Tri
y 9
Tri
the short base of
Triangulum
16
1.95
36
1.96
Tau 1
3.2
a 87
Tau
e 74
Tau
Aldeberan across
the open V, the Hyades)
26.25
3.20
59
3.21
Tau 2
4.0
a 87
Tau
y 54
Tau
Aldeberan to the
point of the V the Hyades)
32.75
3.99
73
3.97
Tau 3
2.4
a 87
Tau
71 Tau
part way along
bottom of V
20
2.44
45.25
2.46
Tau 4
2.7
74 Tau
63 Tau
part way along top
of V
22
2.68
50
2.72
Aur 1
2.8
e 7
Aur
n10,
z8 Aur
The Kids triangle
(7, 10, 8 Aur) in one view
23
2.80
51
2.77
Ori 1
2.8
z 50
Ori
d 34
Ori
Orion's Belt stars
22.5
2.74
50.75
2.76
Gem 1
4.5
a Gem
B Gem
Castor to Pollux
36.5
4.45
83
4.51
Gem 2
3.5
a Gem
75 Gem
75 is just north of
Pollux
29
3.54
65
3.53
Gem 3
2.6
1 Gem
n eta
Gem
M35 is between
these in Gemini's foot
21
2.56
48
2.61
Gem 4
4.4
1 Gem
13 Gem
the whole foot
36
4.39
81
4.40
CMi 1
3.3
a 10
CMi
B 3
CMi
Procyon to
companion
27
3.29
61
3.32
CMi 2
4.3
a 10
CMi
B 3
CMi
Procyon to
companion
35.25
4.30
79.5
4.32
CMi 3
4.6
a 10
CMi
B 3
CMi
Procyon to
companion
37.75
4.60
85
4.62
CMi 4
5.3
a 10
CMi
B 3
CMi
Procyon to
companion
43
5.24
98
5.33
Ser 1
3.3
triangular head of
Serpens Caput
61
3.32
Her 1
6.6
pi 67
Her
n 44
Her
top of the Keystone
of Hercules
54
6.59
Her 2
6.6
pi 67
Her
e 58
Her
east side of the
Keystone of Hercules
54
6.59
122
6.63
Her 3
7.3
n 44
Her
z 40
Her
west side of the
60
7.32
135
7.34
Her 4
4.1
e 58
Her
z 40
Her
bottom of the
33.25
4.05
75.5
4.10
Lyr 1
3.4
d1d2
11,12
e1e2
4,5
NE stars in Lyra
28
3.41
63
3.42
Lyr 2
2.0
B Lyr
y Lyr
across bottom of
Lyre
16
1.95
37.5
2.04
Cyg 1
6.1
a Cyg
y Cyg
Deneb to Sadr top
to center of cross
50.125
6.11
113
6.14
Del 1
2.7
y 12
Del
B 6
Del
body of Dolphin
22
2.68
49.25
2.68
Del 2
3.1
y 12
Del
z 4
Del
body of Dolphin +
#4
25.25
3.08
57
3.10
Del 3
4.4
y 12
Del
n 3
Del
body of Dolphin +
#3 in the tail
35.6
4.34
80.25
4.36
Del 4
5.8
y 12
Del
2 Del
extending further
down the tail
47.75
5.82
106
5.76
Del 5
1.7
y 12
Del
9 Del
smaller parts of
the diamond
14
1.71
31.25
1.70
Del 6
1.3
y 12
Del
11 Del
smaller parts of
the diamond
10.5
1.28
24
1.30
