These words bring sighs to the romantic but, to the astronomer, they can mean
a lost night of useful work. Contrary to popular belief, crisp, clear Winter
nights, with the stars twinkling like Christmas lights, are the worst possible
for serious observing.
Twinkling is caused by masses of air of different temperatures passing between
the observer and the object being observed. They have the same effect as poor
quality window glass when trying to look through it. The image waves around
and the atmosphere acts like an out of control lens that keeps changing the
focus.
To the unaided eye, stars twinkle or change brightness irratically. Through
a telescope, twinkling stars dance around like a drop of water in a hot frying
pan. Planetary detail is smeared and fuzzy and little of interest can be seen
on such a night.
This phenomonon is called "SEEING" and varies considerably from place
to place and from time to time. In general, the higher up in altitude, the better
the seeing because there is less atmosphere to see through. This is one reason
professional observatories are usually located high up on mountain tops. However,
some sea level locations (southern Florida for example) can be nearly as good
at certain times and some locations such as the Midwestern U.S. are nearly always
bad.
In order to discuss seeing intelligently and to help in site selection of large
observatories, seeing must be quantified. It is also important to know what
the seeing is when evaluating a telescope. Many new scopes and their manufacturers
get a bad rap for "lousy optics" when, in fact, the best optics on
Earth could not produce a better view because of poor seeing.
To quantify seeing, one could simply judge the amount and amplitude of twinkling
but it would be to hard to get a good handle on the range or value. Much better
is the system developed by William H. Pickering of Harvard at the turn of the
century. The popular Pickering 1 to 10 scale is in common use by professionals
and amateurs alike. The Pickering scale is based on what a highly magnified
star looks like when carefully focused, in a small telescope.
A star at high magnification, under perfect seeing (P-10) looks like a bull's
eye. A small central disk surrounded by one or more concentric rings. At P-1,
it is just an amorphous blob. The central disk is known as the Airy disk and
it's size in inversely proportional to the size of the telescope objective.
That is why a large telescope can see more detail under perfect conditions than
a small one. Because of physical limits the Airy disk is the smallest detail
that can be seen at maximum magnification and the smaller it is, the less it
intrudes on the detail. Makes little difference when looking at a star which
can never be resolved because of distance but when looking at the surface of
Mars or the Moon, every feature is just a lot of Airy disks all jumbled together
and the larger they are, the fuzzier the image.
One fact little understood by purchasers of new telescopes is that the effects
of poor seeing increase dramatically as the size of the telescope is increased.
This is simply because a small telescope has to look through a much smaller
column of air than a large one. A fairly good night with a small scope might
be not worth taking out a large one. Pickering established his system using
a 5" diameter telescope and his scale would have to be fudged when used
with a scope of larger or smaller aperture.
The "PICKERING 5"
The small scope in the foreground was designed specifically to evaluate seeing
at my site and is the same size as the one used by Pickering. The larger one
in the background is the 16".
The "bull's eye" or diffraction pattern as it is known starts to
appear at about P-4 in the 5" and is distinct but unstable at P-7 (a very
good night for the Midwest). At P-7, the 16" is about the same as the 5"
at P-4. I have yet to see anything better than P-7 here which points out the
fact that the 16" has yet to be used to it's fullest capability.
It should be pointed out that I am referring here to the ability to resolve
detail and not just the ability to see dim objects. The large scope always prevails
in the latter but when viewing the surface of Mars or the Moon, for example,
no more detail can be seen on a poor night with a larger scope.
By now it should be clear why, in spite of it's modest size, the Hubble Space
Telescope has produced photographs that exceed the reach of even the largest
Earth based instruments. Being above the atmosphere, it is immune to the effects
of seeing and its resolution is only limited by its size.
For these and other reasons, it is very difficult to photograph the diffraction
pattern but there are more pragmatic ways of demonstrating the effects of seeing.
Because seeing not only varies from location to location and from night to night
but also changes drastically from moment to moment, particularly on poor nights.
A P-3 night can have instants of P-6 and a patient observer can often snatch
good views if persistant enough and does not blink at the right moment.
Because of the fast and continuous frame capture of video, it is very easy
to demonstrate these moments just by attaching a video camera to a telescope
and pointing it at the moon.
The following images were captured only seconds apart and by stepping through
the tape, a moment of good seeing was found.
P-3 (left) P-7 (right)
We now come to the details of Pickering scale as described in a S&T article
from April, 1995.
| Index |
Description |
| P-1 |
Star image is usually about twice the diameter of the third
diffraction ring (if the ring could be seen. |
| P-2 |
Image occasionally twice the diamteter of the third ring. |
| P-3 |
Image about the same diameter as the third ring and brighter
at the center. |
| P-4 |
The central disk often visible; arcs of diffraction rings
sometimes seen. |
| P-5 |
Disk always visible; arcs frequently seen. |
| P-6 |
Disk always visible; short arcs constantly seen. |
| P-7 |
Disk sometimes sharply defined; rings seen as long arcs or
complete circles. |
| P-8 |
Disk always sharply defined; rings as long arcs or complete
but in motion. |
| P-9 |
Inner ring stationary. Outer rings momentarily stationary. |
| P-10 |
Complete diffraction pattern is stationary. |
The following is a summary of the seeing conditions at my location about 50
miles NW of Chicago since Oct 1997.
Total Nights................ 213
Clear Nights............... ..71
P-1.....0
P-2.....9
P-3....26
P-4....21
P-5.....7
P-6.....4
P-7.....3
P-8.....1
P-9.....0
P-10...0
The 71 clear nights out of 213 tell another story about the effects of El Nino
on observational astronomy. It is however, only part of the story. Most of those
71 nights were only clear enough, long enough to make the evaluation. The actual
number of useful clear nights during the period was a small fraction of that
number.
I do not have a feel for what is "normal" for this area but it is
not hard to understand why no new observatories have been built in the Midwest
in the past several decades and the older ones are either decomissioned or virtual
museums.
If anyone has or wants to gather info on their site, I would be be glad to
post it here for comparison.
