Home / Astro-Rubinar 100/1000
by Otto Piechowski 04/17/03 | Email Author
  * Peer Review
Overall Assessment:
The Astro-Rubinar is a camera lens that, due to the nature and quality of its construction, functions well as a telescope.
Specifications:
  • 106mm Clear aperture
  • F10 - 1000mm when used "straight-through" near the visual back. F15 (1600) when used with a 90-degree mirror star diagonal.
  • OTA is about 7" long and weights just over 5 lbs (2.5kg)
  • Focusing is done by rotating the OTA
  • Central obstruction is 13% by area, 34% by diameter
  • Illuminated circle of 46.5mm (meant for use with a 35mm camera and not with medium format camera)
Accessories: (included by ITE)
  • screw on metal dew cap/light shield
  • full aperture dust cap
  • screw on visual back dust cap
  • screw on visual back (needed to use 1.25 inch accessories)
  • ¼-20 camera tripod fitting on an OTA encircling ring next to the visual back
  • three full aperture screw on filters (green, red, neutral)
  • 45 degree erect image diagonal
  • 32mm fully coated plossl
  • soft padded case
  • instruction manual
  • certification of ¼ wave-front accuracy
Other Components Evaluated:
  • Astro-Rubinar as described above ($475)
  • accessories as described above
  • Orion Min-EQ tabletop mount ($60)
  • cg4 tripod with wood adaptor plate to allow use of mini-eq on top
  • Orion EQ-1M single axis drive ($60)
  • Orion EZ Finder II pointer ($40)
  • eyepieces: 32mm ITE plossl, 17mm Celestron Nexstar plossl, 12.5mm University Optics orthoscopic, 7mm UO ortho., 4mm UO ortho ($60@)
  • Celestron mirror star 90 degree diagonal
  • Ocular Filters: neutral, light orange, light yellow, medium yellow, light green, light blue, diffraction grating
  • full aperture Baader film solar filter
Outward Appearance of the Astro-Rubinar system:
The Astro-Rubinar is a catadioptric design; but it is not a Maksutov or Schmidt telescope. The system includes three full aperture lenses, a primary mirror, a rear surface secondary mirror and a small field flattener lens. The secondary mirror is affixed to the outermost aperture lens. A set of two full aperture lenses is situated between the secondary and primary mirror. The primary mirror is spherical. The field flattener lens is situated in the optical back, behind the primary mirror. The central obstruction of the secondary mirror is 13% of the area and 34% of the diameter of the clear aperture. Light passes through 18 optical surfaces and reflects off two mirror surfaces on its way to the eyepiece. The reason for all of these optical components was to create an excellent flat photographic lens. However, it was discovered that the quality of the components created a good telescope that also has very good near focus capabilities.
Included with the scope is a certificate asserting that the wave-front error (p.t.v.) of the optical system is ¼ wave at 555 nanometers. This certificate is signed by by Mr. Bill Burnett (proprietor of ITE) and by Mr. Mike Palermiti (optical systems evaluator). That the end product is diffraction limited is amazing and a testament to good optical work on the individual elements and good mechanical work on the overall assembly.
The lens mirror alignment creates a light compact optical tube assembly. The scope is 7 inches long with the dew shield and diagonal removed. It weighs just over 5 pounds (2.5 kilograms). This solid metal OTA is painted black with etched in markings. With both attached, the unit is about a foot in length and about 5 inches in diameter.
The scope is attached to a camera tripod or to an equatorial mount by means of a ¼-20 fitting. This fitting is attached to a ring of metal that is affixed to and encircles the scope near its visual back.
This unit has a number of cosmetic imperfections. The metallic ring has a roughened-up look to it; a number of striations/scorings which have been painted over. Further, the markings etched on the scope have a rough though uniform appearance. Finally, at the very edge of the field-flattening lens is a small chip/crack. This appears underneath or right next to the retaining ring. The chip is perhaps 1.5mm by 1mm and can be seen reflected off the field-flattening lens. However, when light is blocked from reaching the chip, the reflection is removed from sight.
A very long baffle tube extends most of the way from the primary mirror central hole to the secondary. Within this tube are many baffle-edges. All interior surfaces have a dull black appearance.
Performance (optical):
The scope has been tested by Mike Palermiti for ITE and a wave-front error of ¼ wave at 555 nanometers has been ascertained.
Appearances of intra and extra focal images of bright stars and of point light sources are strange, even disturbing to the non-optician who has become accustomed to MK, MN or apochromat optical systems. The intra-focal image is a sharply defined elliptical structure with a well-delineated ring forming the very perimeter. The extra-focal image is mushy in comparison, lighter in tone, and elliptical as well. The elliptical shape of the intra focal image is perpendicular to the elliptical shape of the extra focal image. This is an indication of astigmatism. The use of Cor Berrovoet’s Aberrator-software indicates that the astigmatism of this particular scope creates a wavefront error of between .248 and .276 wave-front error. At a high degree of de-focus both the intra/extra focal images present nearly identically shaped and distinct double rings. Such astigmatism, according to expert opinion, does not compromise the diffraction limitation of this system; either its ¼ wavefront error or 80% strehl ratio.
There are no easily accessible means to collimate the scope. However, the collimation seems to be very close to dead-right-on collimation with only a slight loss of the doubled aspect of the ring-pair in the greatly defocus intra-focal image.
The in-focus image of point-light-sources, when the air is stable and when the scope is thermally equalized, presents a round airy disk and a single diffraction ring of uniform size, uniform distance from the airy disk and uniform brightness. Quite often, the continuity of the diffraction ring is disrupted by four tiny black notches, each 90 degrees away from the next. Sometimes, the diffraction ring is continuous.
The scope functions well on terrestrial objects, providing pleasant views of distant objects and sharp, clear, flat views of objects as near as 14 feet whether the system is used with a diagonal or straight through. This is a bit longer than the advertised near-focus capability of 4 meters (13 feet).
During times of ambivalent sky stability, with a limiting zenith magnitude of 4.5, the scope reveals stars of magnitude 13.0 with averted vision at 300X (75X per inch). The Great Nebula in Orion gives a very satisfying appearance through a 17mm plossl; as aesthetically pleasing as seen through an MK67. The appearance of the epsilon lyrae double-double is greatly superior to a Celestron F5 80mm achromat refractor and somewhat inferior to the view through the MK-67. Albireo and gamma Andromedae give color saturation views more like an F5 80mm refractor than like the MK-67. In a somewhat stable sky, Castor’s two components can be seen at 50X, though the companion of Rigel is not visible. In a stable sky, eta orionis which is listed as a double whose components are a full magnitude different separated by 1.5 arc secs, is easily resolved; the fainter of the two nestling on the diffraction ring of the former. In a borderline-stable-sky, one can see detail within sunspot penumbra, easily see faculae and detect the presence of rice grain. In an unstable sky the Cassini division of Saturn is detectable but not what would be called, visible. In a stable sky, the division becomes detectable at 90X and visible at 220X (55X per inch) as a faint vague pencil thin line. At moments of good stability the division can be detected through nearly the whole ring, and at moments of very good stability becomes readily apparent. On the moon and on planetary detail, best visual acuity is accomplished at between 20X and 30X per square inch of aperture (80X to 130X in this system) as is true for all telescope systems. Accordingly, though higher magnification may provide more pleasing views of a few objects due to an enhanced image scale, no additional detail can be observed above 130X, even with good orthoscopic eyepieces. Only slightly more detail can be seen at 130X with a good quality ortho, than at 95X with a fair quality plossl.
There appears to be no chromatic aberration at all. None was observed at the terminator of the moon bright planets or stars.
Astronomical views are always dependent on atmospheric stability and thermal equilibrium within the optical system itself. Due to the number and arrangement of the optical components within the system, it can take up to 45 minutes for the scope to “cold soak.” Of course, should the temperature be dropping, “cold soak” may take longer or may be repeated.
This system provides completely flat field-of-view images. In all the plossl and orthoscopic eyepieces the field is flat edge-to-edge. Images are focused clear across the field of every eyepiece from the 32mm plossl to the 4mm ortho. When looking at objects with a straight lined edge near the perimeter of the eyepiece field of view, the line seems to curve away at the ends of the line. This may, however, be only an optical illusion of a line approaching a curved arc-shaped concave edge.
Another very attractive feature for those stargazers who are also scopists, is that extremely sharp images can be obtained of nearby objects. At the near-focus of 13 feet, the level of detail revealed is such that this system can be characterized as a long-distance microscope.
Another outstanding feature is that there is no glare in terrestrial views. This is probably due to the extensive baffling, to the flat black paint and to the optical design. Even at 100X per inch and above, no glare was seen. As a comparison, in the C-90, intrusive and distracting glare appears at 40X per inch and greater. The situation with astronomical viewing of bright objects is somewhat different, though the contrast is very good. When gazing at a gibbous moon, at only a short distance from the dark terminator the field is flooded with a decidedly bluish glare. Again, it does not impact the view of features at the lunar terminator, but it is noticeable. This may be due to the plossl eyepieces used with this system, or it may be an artifact of the coatings and complex optical system. The latter probably explains another curiosity of this system. When a bright planet such as Jupiter is displaced some one or two full fields’ of view width from the eyepieces’ field of view, one sees the faint wide arc of a large circle whose focus is the bright planet so displaced.
Finally, the telescope provides a very wide true field of view (up to 1.7 degrees with a 53 AFOV degree 32mm plossl when viewing occurs near the visual back). When used with a star diagonal, the true field of view reduces to just over one degree.
Peformance (mechanical):
Focusing is accomplished by rotating the tube. Those experienced at using a C-90 will find this scope easy to focus. Some scopists may require adjusting the position of the eyepiece in the diagonal cell. Again, to those familiar with such a focusing style, this is not difficult.
The sweet-spot of best focus is very narrow. This may be a necessary consequence of the optical design of this system that allows a flat field with a very short focal length, or it may be the necessary consequence of a modest amount of astigmatism. If the latter is the case, it may be that in this unit fine focus can be obtained, but at the cost of a bit more effort.
The field-flattening lens is very near the visual back of the scope. So close in fact that one could easily crack or scratch this lens by inserting a diagonal or eyepiece into the screw on visual back. One solution, suggested by Mr. Palermiti, is to shorten the insertion tube on the diagonal so that it does not extend to the field-flattening lens.
The entire scope with the Orion Min-EQ tabletop mount weighs in at less than 15 pounds. The OTA is slightly heavier than the five-pound counter weight. In some positions, the counter balance cannot withstand the force of the telescope weight. However, it does not put undue strain on the equatorial locking screw. Nor does it limit the effectiveness of the EQ-1M single axis drive. The drive is very smooth and accurate. Once the scope is situated relatively near the celestial pole, an object centered in a 4mm orthoscopic eyepiece remains in that field of view without adjustment two hours later. When the drive is turned on, images do not vibrate and thus, do not impact the view of close double stars. (An addendum: after three months of use, the RA axis has become a bit sloppy. It seems to tighten up by rotating the axis a few times without the scope or counterweight in place.)
By making a disk of wood 5/8 to ¾ inch thick and a few inches in diameter with a notch at one end and placing it on top of the cg4 tripod head, one is then able to dismantle the screw-base of the Min-EQ and then mesh the rest of the Min-EQ to the cg4 mount. Between the use of the Min-EQ tabletop mount and the adapted cg4 mount, any object can be observed at a comfortable height and location.
With the telescope’s relatively large true field of view, an Orion Star Pointer provides an adequate means for finding objects in the sky if one has a good familiarity with the position of objects in relation to bright stars or has use of a good star chart providing the same information. Another benefit of the star pointer is that it is very light, hardly affecting the balance of the equatorial mount. Further, the pointer has an easy-to-use mechanism for adjusting its position. Finally, the switch that turns the pointer on and off and adjusts the brightness has a very definitive sound and feel. The only drawback of the pointer is that one often leaves it on inadvertently. It would be good if this unit had some type of automatic shutoff function.
The telescope comes with a screw on metallic dew cap/light shade. Care needs to be taken when screwing on the dew cap that the threads are not stripped. Also, in the dark especially, but at any time, care needs to be taken not to let the cap slip allowing its thread edge to touch the surface of the forward full aperture lens. It is also possible to screw the full aperture filters onto the telescope and then screw the due cap onto the filter. Though there is no astronomical advantage to using full aperture filters instead of ocular filters, one can disassemble one of these filters and replace the glass with Baader filter material, thus creating a very convenient solar filter.
The scope comes with a full aperture lens cap that covers the front of the scope when the dew cap is not installed. It would be a nice modification to the current Rubinar design if this lens cap could be modified to fit on the scope with and without the dew cap in place.
Peformance (composite/in the field):
Alan MacRobert is correct; a small telescope will see more than a large telescope because it will get used more often. This is due to the lack of excessive weight and clumsiness. Further, a consideration for aging stargazers is exposure to the cold. The lessened weight and size often eliminates the need for assembling the scope outside or lessens the amount of time this takes. These strengths are true of the Astro-Rubinar mounted on the Mini-EQ1 mount. A second advantage of the low weight and lessened size is the small amount of space that is needed for storage. In the case of this particular scope; it, its mount and drive, and all of its accessories stated above are stored in two 13” plastic tool-boxes, the 15” soft padded bag, and Orion’s smallest eyepiece case. These take up about two square feet of shelf space, can be transported easily in any vehicle and can all easily be carried outside in one trip.
History of this particular selection:
I was the owner of an MK-67 on a cg4 (mount/drive) with a wide range of orthos and a stunning MK70 Konig (another good suggestion by Bill and Mike). After two years of very satisfying viewing with this assemblage, I began to grow dissatisfied because my work, family obligations and age made me less and less willing to set the scope up for viewing and take it down. Also, I missed the terrestrial and near-focus views of the humble C-90.
Thus, began the journey of obtaining what I believe to be the perfect balance in a telescope: good optical quality, aesthetically pleasing, light weight, easy transport, easy assemblage and dis-assemblage, robustness, good quality drive and tracking, good near-focus capabilities, appropriate accessories.
To cover the cost of this purchase, I disposed of the MK-67, MK-70, cg4. Many professionals and amateurs advised me not to do it, because of the very good quality of the MK67. Though the overall quality of the Astro-Rubinar does not stand up to the standards of the MK-67, MK70, cg4 set up, it is better suited to my tastes and needs.
An experienced amateur asked if I was disposing of this in order to upgrade. With a slight bit of rye humor I could honestly say that “No, I am downgrading.” Of course, a downgrade to what I believe is more suitable for me.
After-the-Purchase Service:
My desire was to obtain a scope that provided the ability to see objects only a few feet away and to see the Cassini division on Saturn. Bill assured me that this scope, under proper stability, could do just this because it was equal in optical quality to the Questar 3.5. As I studied the advertisements, I also noted the short focal length of 1000mm. This meant that I could obtain a wide true field of view with long focal length eyepieces. It also meant that University Optics 4mm orthoscopic eyepiece would create a magnification in (what some consider the ideal high magnification) range of 50 to 60X per inch. The advertisements also showed that a 32mm plossl and a right angle 90 degree star diagonal was included along with lens caps for the visual back and the full aperture front.
Once the order was placed, I was told that delivery would be in one to two weeks. Near the end of the two weeks I called and learned that it would take somewhat longer. In the third week, an email response to a further query informed me that it should arrive soon. Soon it did; that very day. Bill, simply, went ahead and had the scope shipped, from the Florida testing site, by second day air, without requesting or requiring additional payment.
Assemblage of all the obtained elements now in hand, was a pleasure. Using it was a pleasure too, providing good views and easily meeting my desire for a unit that was easy to handle and provided a good near focus. It was also enjoyable to actually have a certificate of optical quality. A further pleasant surprise was the inclusion of three full aperture filters in very substantial well-made housings at no cost.
Then, as always happens, imperfections became apparent: scratches on the ring, chip in the field-flattening lens, a shockingly long focal length with the diagonal in place resulting in the realization that I should not have purchased a 4mm ortho for this system as it now provided magnifications of 100X per inch of aperture, the astigmatic and dissimilar intra/extra focal star and point source light images, the dangerous nearness of the field-flattening lens to the visual back and a 45 degree erect image diagonal being provided instead of the advertised 90 degree diagonal (this was fortunate for me in that I possess a very good 90 degree diagonal but not an erect image diagonal). These occasioned a number of calls and emails to Bill and Mike. Bill returned every email inquiry quickly. Both Bill and Mike talked at length over the phone when I called. Every query was responded to with full attentiveness to the descriptions of my concerns. One such interchange was to report the chip in the field-flattening lens, not so much to desire a replacement (since it did not seem to affect performance) but to put it on record in case it should enlarge through temperature changes or mechanical stresses.
A sign of good customer service is the willingness of a company to consider sensible suggestions. Bill was open to my suggestions that the advertisement on the website be changed to mention the focal length of the optical system with a star diagonal in place and not just the focal length at the visual back, and that the owner manual contain a warning that care was needed in inserting the diagonal/eyepiece so as not to crack the field-flattening lens.
Evaluating Oneself as an Observer:
The ITE optical evaluator, Mike Palermiti said to me in a phone conversation that “Field "tests" are not really tests of the telescope’s optical quality, but, rather, a learning session for the observer. All too often, amateurs spend too much time trying to evaluate an instrument, when the facts are that they are really evaluating themselves as observers.”
Novice scopists and amateur stargazers can see more problems then might actually be present. We might overplay the negative and underplay the positive. We may become a bit obsessive, especially as it relates to systems-perfection. In this latter regard, I am grateful to my tutelage under a number of persons. These include the astronomer, Fr.Myron Effing (a student of Carl Sagan’s) who taught me the advantage of the “brute force” design; sacrificing cosmetics in order to put effort and money into optical quality; Andrea Tasselli who once wrote that what’s important about a telescope is that it is meant to be looked through and only secondarily to be looked at, Bill Burnett who once questioned my self-presumed ability to distinguish between a 1/6 and 1/8 wave-front corrected system based on lunar observations and Mike Palermiti for his comments immediately above.
My mother-in-law who, in living that life common to us all in which we learn to deal with accommodation, once said, “You never get the whole pie. You have to work at accepting/liking/improving the pieces you get.” Though my MK67 accustomed me to the absence of astigmatism and a ribbon-like appearance to the Cassini division; I am finding myself very satisfied with this telescope which is very portable, stores easily, gives very good views of terrestrial objects, performs as a long-distance microscope, gives good astronomical views, whose drive and mount function flawlessly and supported by two very knowledgeable and available professionals.
Addendum February, 2003
Since the original review I have made additional discoveries about this fascinating telescope. Some of these are elucidations of previous comments, and some are corrections. These addenda are due to having had more use of the scope and having, with the encouragement of Jeff Barbour and Mike Palermiti, dissassembled the entire scope.
  1. The optical system contains two full aperture lenses which surround the secondarly mirror baffle, two mirrors and a cemented field-corrector doublet. Thus light passes through eight optical surfaces (not 18) and off of two mirror surfaces on the way to the eyepiece.
  2. The field flattener doublet lens can be removed. This does not affect the quality of views through eyepieces at all. However, it does reduce the focal length of the system from something like F16 (using a diagonal and eyepiece) to under F10 (using a diagonal and eyepiece). This means that with a 32mm plossl, the AFOV is c. 1.5 degrees rather than 1 degree. At the optical back (without the diagonal) the 32mm now gives an AFOV of 2.4 degrees.
  3. However, with the field-flatterner lens removed, only two of my five eyepieces come to focus on celestial objects when using the diagonal. Three changes to the mechanical system can be done which would allow all eyepieces to reach focus in this configuration; two of which I have done but one of which is beyond my capability. Totally dissassembling the scope, including removing the focusing sleeve (which holds the full aperture lenses) from the inside most tube which holds the primary mirror assembly, one can reach focus on all eyepieces by (A) using a hack saw to remove a tiny focus stop piece of aluminum (glued to the inside most tube) about a half centimeter by 1&1/2 centimeters, (B) using a hack saw to cut off two centimeters or so of the non-machined (the screw) end of the sleeve (This must be done very gently with the sharpest of blades so as not to "torgue" this tube. If this tube torques, the screw focus mechanism will be destroyed), and (C) machining the inside most tube to continue the screw-machined lines further than they are now placed, by around 2 centimeters. I have done (A and B), the manufacturer will have to do (C). In this way, I believe, any eyepiece can come to focus at a WONDERFUL minus F10 configuration with a 1.5 AFOV.
  4. By removing the tiny piece of aluminum (see (A) above) one now can now extend the "near focus". By cutting this off, I now am able to focus on objects down to just over 1 meter away (4 feet). I am now able to see microscopic detail. For example, on a five dollar bill, I was able to see details and shadings through the scope at 4 feet, which I was not able to see with my unaided eye next to the bill under bright light.
  5. It is relatively easy to loosen the retaining ring which holds the outermost full aperture lens to the scope (without dissassembling the entire scope). By doing this, one can then rotate the outermost full aperture lens relative to the inner most full aperture lens. In the case of my scope this has allowed me to "worsen" or "improve" the amount of astigmatism in the system. In terms of improvement, what I originally estimated as 1/4 wave of astigmatism has now been reduced. At 30X per inch, using a 12.5mm orthoscopic eyepiece, on point light sources, the airy disk and diffraction ring(s) indicate no detectable astigmatism to my eyes (either as to the in focus image or just out of focus image). At 55X per inch there is some indication of the tell tale signs of astigmatism (first diffraction ring, in focus, with 4 tiny notches), but no ellipticity in the just out of focus images. At an absurd 100X per inch (4mm ortho at F16 plus) only then can one see the astigmatism...but still everything focuses.
  6. On a clear steady night in the beautiful skies of South Dakota, I was easily able to see the companion of Rigel. And later, on one steady night here in Lexington Kentucky, I was able to do the same.
* Peer Review:The peer review process was a voluntary procedure in which the author’s article undergoes a detailed review by a body of his/her peers. The articles are checked for veracity and accuracy.
* First Impressions:A quick look at and through the equipment, not to be confused with an in-depth or detailed evaluation that’s taken place over a period of time.
Back to Top
Contact Us
CN Reports | Reviews | Articles | Forums | Classifieds | About Us
Copyright© 2004 Ad Libs Advertising.
Privacy Policy
  Search Cloudy Nights
  Advanced Search
Thursday, September 9, 2010
Cloudy Nights Supporters
Astronomics
Telescopes  www.astronomics.com
