Gary Hand is the owner of Hands on Optics and has over 30
years of astronomy experience.
Neither mirror nor prism are better. If you notice, every manufacturer
of quality scopes with fast focal ratios uses mirror diagonals. Every manufacturer
that sells quality scopes with long focal ratios sells prism diagonals. It’s
not an accident. You get the diagonal that matches the scope.
Assuming the same quality of manufacture, prisms give less light
scatter, a good thing. And unlike a mirror, they are also self collimating.
But they also create false color in scopes with fast focal ratios. Just like
your old Jr. High experiments, when you send light into a prism at an angle
other than perpendicular, it will cause false color. Fast telescopes send
light into a diagonal prism at a steeper angle and can in fact introduce false
color into a scopes where there was none. The sharper the angle (faster the
telescope) the more false color is introduced. Prisms are more expensive to
make in larger sizes than mirrors and may account why in 2” and larger
diagonals, mirrors dominate.
Prisms on the other hand never scatter light and therefore can
produce excellent contrast. Also, they never age. In terms of transmission,
each depends on the coatings. A multicoated prism and enhanced Aluminized
mirror can both achieve about the same 98% transmission. But that really is
not important. (WHAT DID HE SAY?)
Most of the discussions about diagonals have centered on reflectivity.
Of all the characteristics that make a good diagonal, reflectivity is one
but not the most important. But it is the easiest characteristic to market,
96% is better than 95% right. There is a vast amount of laboratory data that
proves that human beings cannot perceive a few % of light change, yet it is
the characteristic most often quoted to define how good a diagonal is. Buy
X because its 97% and not Y because its only 95%. Yet even Meade’s and
Celestron’s new ads for their high transmission coatings state that
you CAN NOT really “see” the difference and they’re talking
about 10% difference. On the other hand, a camera can easily “record”
the difference. But you don’t use diagonals when photographing do you.
So, why is it that people that demand full documentation on
the optical accuracy of their $5000 telescope, only worry about the brightness
of their diagonal and not accuracy? Isn’t accuracy, in this case flatness,
at least as important than brightness. Doesn’t the difference between
a 1/7th wave vs. a 1/20th wave surface have a greater impact on your viewing
than the difference between 94% vs. 98% transmission. The few that supply
accuracy papers on their diagonals do so before they are coated, not after
and there can be a huge difference. The papers make you feel good, but do
not reflect (sorry) the actual product you receive. As a rule, the brighter
the coatings, the more layers of coatings had to be laid down, and the less
it reflects (sorry again) the accuracy of the original precision flat surface
accuracy. Standard Aluminum coatings (88%) have one layer, semi enhanced (91%)
2 layers, enhanced Aluminum (94%)has 3 layers of coatings. Dielectric coatings
can have up to 22 layers. The advantage of a dielectric coated mirror is its
longevity. Unless abused, they will last a lifetime.
In short, use the diagonal that works best your scope. It may
be the one the manufacturer supplied.
Look for the most accurate diagonal, then the brightest.
Look for all metal parts, a machined housing is best but
not required.
A true 90.00 degrees is important. That means 1 piece CNC
machined housing.
User collimatable is nice.
The substrate is important. Cervit, Zerodur, Astrosital
and Quartz are better than Pyrex. Pyrex is a bit better than BK7. BK7 is
better way than plate glass. |
