Best of the ETX
36 replies to this topic
#1 MMICKELS
MMICKELS
    Aluminum Knight
  • Loc: Land of Shake and Bake
Posted 24 April 2007 - 06:50 PM
Many thanks to Joe Lalumia, Odin, and ect for providing the content for this thread! :bow:
This thread is best viewed in threaded mode.Otherwise it won't make much sense.
The content was provided by the Cloudy Nights ETX forum members and not by MMICKELS
Legend
TC: Table of Contents post. No link provided.
Mods this is a work in progress, so please don't comment in this thread.
#2 MMICKELS
MMICKELS
    Aluminum Knight
Posted 24 April 2007 - 06:51 PM
Follow this thread to find the answers to some frequently asked questions.
#3 MMICKELS
MMICKELS
    Aluminum Knight
Posted 24 April 2007 - 06:52 PM
Follow this thread for answers to some common controller problems.
#4 MMICKELS
MMICKELS
    Aluminum Knight
Posted 24 April 2007 - 06:53 PM
Follow this thread for answers to some common ETX scope problems.
#5 MMICKELS
MMICKELS
    Aluminum Knight
Posted 24 April 2007 - 06:55 PM
Ya want to fix your scope up with some new gear? Follow this thread.
#6 MMICKELS
MMICKELS
    Aluminum Knight
Posted 24 April 2007 - 06:56 PM
Some projects and solutions for ETX users.
#7 MMICKELS
MMICKELS
    Aluminum Knight
Posted 24 April 2007 - 06:58 PM
A picture is worth a thousand words.
#8 MMICKELS
MMICKELS
    Aluminum Knight
Posted 24 April 2007 - 07:27 PM
You know where you are, but does your ETX know?
#9 MMICKELS
MMICKELS
    Aluminum Knight
Posted 24 April 2007 - 08:00 PM
When you need a part to fix your ETX.
#10 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:14 PM
Manuals and related info
#11 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:15 PM
Meade Manuals
#12 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:18 PM
Look for the ETX stuff
#13 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:20 PM
Meade Software Downloads
#14 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:21 PM
Autostar
#15 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:24 PM
Starpatch
#16 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:26 PM
Weasner
#17 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:27 PM
Science and Hobby ETX Accessories
#18 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:29 PM
Telescopehouse UK
#19 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:30 PM
Meade Accessories
#20 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:40 PM
Discovery Accessories
#21 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:42 PM
ETX Braniac
#22 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:44 PM
UK Astro Engineering Accessories
#23 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:47 PM
OK.......let's keep the thread going with this basic instruction on ALIGNMENT and SETUP.
1. Don't use the 8 internal batteries. Buy a separate 12 volt power source, either from Celestron or a good automotive 12 volt pack.
2. Download and install the latest firmware from the Meade web site...right now it is 43Eg for the 497 hand controller.
3. When you get your firmware on the scope do a RESET with the hand controller. Then setup the time, date, and SITE, and correctly setup Daylight Savings Time.......it's a YES right now (April). The PE version should do time and date automatically but check it anyway.
4. Do a Calibrate Motors.
5. Do a TRAIN drives........in both DEC and RA, the controller is a little tricky here and you can easily miss training on one of them.
6. You can do all of the above inside the house or in the backyard with a small TARGET on a tree or wall a distance away from the scope.
7. Setup the mount outside with a bubble level........LEVEL of course. PE version is different; read the manual.
8. Put the scope in the HOME position......read the manual!!
9. I made a boo boo on this one! and erased it!
10. Then do a TWO star alignment.........BRIGHTEST STAR should have already been selected in the hand controller.
11. The scope will NOT hit the alignment stars exactly......center the proper star and push ENTER.......do this again for the second alignment star.
12. Use a widefield eyepiece to align .......something greater than 20mm.........yes I know more magnification is better...........but for beginners this works first time AND they will be less frustrated finding the alignment star and centering it in the eyepiece.
13. As you noticed the factory finder is really useless! Buy a right angle finder or a Telrad style finder to use for alignment. Rigel makes a nice small telrad type finder. Google "Rigel Quickfinder".
Now GOTO something............you did download the TOURS ??? NO....... well no problem, just get a skychart off the internet and GOTO one of the open cluster MESSIER (M) objects. Pick a bright one like M44, or M42.......or GOTO a planet. There that was not very hard. Have fun!
By the way if you stay inside a certain constellation you can SYNC on a star or object in that constellation........then your gotos will be very accurate in that part of the sky. Center the star or object and hold down the ENTER key for 2 seconds, the hand controller will BEEP and ask you to press Enter again.......there ......now you are SYNCED!
GOTO wherever you like in that part of the sky........you can use this technique as you move from constellation to constellation and continue to have excellent GOTOS.
Provided by Joe Lalumia
#24 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 05:58 PM
Some Items for a Hassle free Alignment of ETX125PE
> Remember to Program the ZIP code of the area your viewing from.
> The base side with all the connector jacks should be facing WEST.
> When the controller asks you to align on the brightest star, you need to verify which star its looking for (depressing the '?' button will display this star name)as the star is not necessarily close to where the scope has slewed.
> Pressing the button above the '?' which has a light bulb Icon will turn the view finder on or off as well as the red led on the end of the controller.
Provided by Odin
#25 MMICKELS
MMICKELS
    Aluminum Knight
Posted 25 April 2007 - 06:00 PM
I've had all kinds of problems with the GoTo on my scope, but this board helped me solve them - working great last time out. Couple of my problems:
1. Meade set the location to Calif when I sent it in for warranty repairs.
2. Meade set the target to terrestrial - I didn't find that one for quite some time.
3. Using internal batteries - now have a Celestron Power Tank.
4. Didn't get the EXACT time - now set it from internet time site.
Thanks again.
George
Provided by George NC
