List of Paracorr settings for all brands of EP's
222 replies to this topic
#201 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 02 December 2013 - 12:26 AM
Anyone input the Delos line into the settings?
All the Delos eyepieces except the 17.3 and 14 will use setting "D" with the Paracorr's supplied 1.25" adapter.
The 17.3 and 14 will require setting "A" for right now, also using the 1.25" adapter.
There may be another, lower-profile, 1.25" adapter for the 17.3 and 14.0 a little later on, as the "perfect" correction for those two will require a setting a little farther in than setting "A".
But "A" will still correct a lot better than no Paracorr, in the same way that the original Paracorr didn't completely correct the 31 Nagler or 21 Ethos but they still were improved a lot over no Paracorr.
Don, will the 17.3/14 Delos only come close to working optimally with the Type 2 ParaCorr? I tried both in my Type 1 (PCV-2000) on setting 1 and the 14 Delos edge performance compared to the XW 14 left much to be desired in the f/4.3 STS 11.
TeleVue now makes an "In Travel" adapter that drops the shoulder of the 17.3 and 14 Delos 1/8" below the top of the Paracorr. If the 17.3 and 14 are used with this adapter, they become parfocal with the 12-3.5mm range when those are used with the standard adapter that comes in the Paracorr.
If there is an optimum setting for the 3.5-12mm Delos in the Paracorr 1 (and they would all use the same setting), the use of the In-Travel adapter will allow the 17.3mm and 14mm to use the same setting as all the other Delos eyepieces.
Since the short focal length Delos are parfocal with most of TeleVue's 1.25" eyepieces, and none of them used setting 1 in the original Paracorr, the key is to use the correct setting for the other 1.25" eyepieces (I can't remember if it was setting 2 or 4 when using the supplied 1.25" adapter) and use that same setting for the Delos range.
If the 17.3mm and 14mm Delos are then used with the new adapter, that setting would also be optimum for them.
#202 Starman81
Starman81
  • Loc: Metro Detroit, MI, USA
Posted 02 December 2013 - 11:38 AM
Thanks Don. The setting for 1.25" TV eyepieces in the ParaCorr Type 1 is setting 4, so I'll have to try them out with the In-Travel adapter.
#203 Phillip Creed
Phillip Creed
    Idiot Seeking Village
  • Loc: Canal Fulton, OH
Posted 07 April 2014 - 07:34 PM
Paracorr Type-1:
30ES-82: Setting ~ 1.7 (closer to "2" than to "1").
This would put it at around the same setting as a 20T5, if you're thinking about a Baader MPCC for this eyepiece.
Clear Skies,
Phil
#204 charles genovese
charles genovese
  • Loc: Madisonville Louisiana
Posted 26 September 2014 - 02:02 PM
My understanding of coma correctors is they should be a fixed distance from the primary ( or correspondingly a fixed distance inside the focal plane). Therefore th proper way to do this is to set the focuser to maintain the paracor at the proper location and actually focus using the paracor tunable top!
#205 MSWcdavis
MSWcdavis
Posted 14 January 2015 - 08:35 PM
I haven't read anything about paracorr settings for the 30mm 82degree Explore scientific eyepiece.  Any suggestions anyone (type 1 paracorr for 32mm ES 82)
Edited by MSWcdavis, 14 January 2015 - 08:36 PM.
#206 star drop
star drop
    contra contrail
  • Loc: Snow Plop, in the dreary of Lake Erie.
Posted 15 January 2015 - 10:02 PM
Post number 203 by member Phillip Creed, two posts above yours in this thread answers your question.
#207 MSWcdavis
MSWcdavis
Posted 15 January 2015 - 10:37 PM
sorry i searched the thread with explore scientific not "ES" - didn't see that post
my bad
#208 MSWcdavis
MSWcdavis
Posted 16 January 2015 - 09:01 PM
another simplistic question
what is the first mark on a paracorr?
is it the lowest mark, or the highest?
does it go 1,2,3,4,5
or 5,4,3,2,1
i'm assuming the former but want to check
#209 star drop
star drop
    contra contrail
Posted 17 January 2015 - 09:58 PM
Mark one is the longest configuration and mark five is the shortest configuration.
#210 Starman1
Starman1
  • Loc: Los Angeles
Posted 18 January 2015 - 11:49 AM
My understanding of coma correctors is they should be a fixed distance from the primary ( or correspondingly a fixed distance inside the focal plane). Therefore th proper way to do this is to set the focuser to maintain the Paracorr at the proper location and actually focus using the Paracorr tunable top!
Yes, but the coarse focusing by the tunable top, though fine for finding the correct setting for an eyepiece, isn't quite fine enough for focusing in any scope short enough to need a Paracorr.
You'll still end up using your focuser.  Because if you don't use your focuser, you;ll never achieve the very finest of focus.
And once you've used your focuser, even for a millimeter of movement, the Paracorr won't be at the optimum position any more.
So we "pre-dial" the settings for the eyepieces and tweak the focuser for best focus.
Plus, many eyepieces' best settings are in-between settings on the Paracorr.  It's unlikely that you'll pre-set the Paracorr's top to "D+" for instance.
So, after recording all the best settings for your eyepieces, you'll round them off to the nearest letter and just dial in the focuser.
That only results in about 2mm of focuser travel, which isn't significant for coma correction.
It might interest you to know that eyepieces TeleVue says are parfocal on their specifications list are not actually parfocal.  The term parfocal means the eyepieces
focus at approximately the same point, not that they focus at EXACTLY the same point.  So two eyepieces that are listed with the same Paracorr setting may require a slight tweak of the focuser to bring them to focus.  Ideally, the Paracorr's tunable top would be moved slightly but in practice one doesn't do that.
It can be easier to adjust the Paracorr's top if all your eyepieces are made parfocal before using the Paracorr.  That way, since all your eyepieces use the same setting, you won't even need to adjust the Paracorr's top unless you borrow an eyepiece.  To parfocalize your eyepieces, you start with your eyepiece that needs the most in-focus of all and freeze the focuser at that point.  Then, add spacers and barrel extenders and parfocalizing rings to your other eyepieces to put them in focus at the same setting of the focuser.  When all your eyepieces are in focus at the same position of the focuser, they are all parfocal.  After that, they will also all use the same setting on the Paracorr.
I didn't do that completely, as two of my 7 eyepieces use the in-most setting of the Paracorr, while 5 use the out-most setting.  That was easy to remember.
#211 LostParticle6
LostParticle6
  • Loc: Redding, Ca.
Posted 17 April 2015 - 02:59 PM
I believe T.V. has not produced the Panoptic 15 for awhile but anyone out there have an idea what setting it might be for the Paracorr II?  A,B, C....?
#212 Starman1
Starman1
  • Loc: Los Angeles
Posted 17 April 2015 - 05:31 PM
I think it's a parfocal 1.25" eyepiece, so probably setting D with the provided adapter.
#213 Matt Wallin
Matt Wallin
  • Loc: Portland, OR
Posted 20 April 2015 - 05:44 PM
So, finally made it out with my new Paracorr T2.  I borrowed my buddy's 11mm Nagler T6,  as a known starting point (setting "D"), since the correct Paracorr T2 setting is listed on the TV website, to set the primary/corrector distance.  I locked the focuser and noted the tube extension, then put my ES eyepieces in and found focus using the tunable top.
My results:
ES 30mm 82* = G-H (midway between those letters was best focus, almost at the maximum tunable top extension)
ES 20mm 100* = A-  (had to rack the focuser in slightly, maybe 3-4mm, after dropping to the lowest Paracorr setting, meaning not fully corrected?)
ES 14mm 100* = G
ES 9mm 100* = G
ES 5.5mm 100* = G
I plan to experiment a bit more, but those should be pretty close.  I was wowed by the detail that Jupiter showed that evening, all the way across the field of my 100* eyepieces, impressive!
Edited by Matt Wallin, 20 April 2015 - 05:48 PM.
#214 Starman1
Starman1
  • Loc: Los Angeles
Posted 20 April 2015 - 06:31 PM
Interesting about the 30mm 82 degree ES.  The comparable Nagler, the 31mm, uses setting A
There is always a little variation in settings among "parfocal" eyepieces, too..
Your result on the 20mm x 100 degree ES is consistent with mine.  I just used it in setting A.
Don't be afraid to use in-between settings if that's what's required.
I even find that parfocal pairs of eyepieces (in the TeleVue list) often require slight differences in settings of up to a half a setting.
Examples: 10mm and 13mm Ethos, or 8mm and 6mm Ethos.  And their 1.25" eyepieces don't all focus exactly at the same point.
But since a whole setting on the Paracorr is 0.1", a half setting is only 0.05", and every manufacturer would consider that parfocal
even if the focus wasn't identical.
#215 Matt Wallin
Matt Wallin
  • Loc: Portland, OR
Posted 21 April 2015 - 12:48 PM
That would suggest that maybe the 30mm ES 82* is not a clone of the Nagler, internally?  It appears that the ES 100* series uses settings very, very close to the Ethoii, and having seen the X-ray comparisons, I'd say they are a  pretty close copy!
#216 JimV
JimV
  • Loc: Austin, TX
Posted 23 May 2015 - 10:45 AM
On 1.25" eyepieces that require a lot of rack in, and don't have enough in travel with a Paracorr I:
The Glatter Parallizer eyepiece adapter adds no height and doesn't have the
setscrew problem the Astrosystems adapter has.
Most adapters add 1/4".
Eyepieces don't wobble in the Parallizer, either.
#217 Yodadonkie
Yodadonkie
  • Loc: Belgium
Posted 23 May 2015 - 02:38 PM
Hello guys, I'am from Belgium en i'am new here on this forum.My question: Works Baader Hyperions with a parracor type 2? Thanks for respons,greetings from Belgium, Benny, ;-)
#218 Starman1
Starman1
  • Loc: Los Angeles
Posted 24 May 2015 - 12:39 AM
Hello guys, I'am from Belgium en i'am new here on this forum.My question: Will Baader Hyperions work with a paracorr type 2? Thanks for response,greetings from Belgium, Benny, ;-)
Welcome.
The answer to your question is Yes.
  • Yodadonkie likes this
#219 Yodadonkie
Yodadonkie
  • Loc: Belgium
Posted 25 May 2015 - 04:53 AM
Thanks Starman1 ;)
#220 Disciplus55
Disciplus55
  • Loc: Lorraine, France
Posted 06 December 2015 - 03:49 AM
Hello,
Any setting recommendations on a Paracorr Type 1 and Pentax XW 30 and XW 40 ? My dob is a 16" at f/d 4.5.
#221 Starman1
Starman1
  • Loc: Los Angeles
Posted 06 December 2015 - 11:15 AM
What are your other eyepieces?
If you know the setting for even one of those, you can determine the setting for the XW 30 and 40 by simply
setting the Paracorr for one of your other eyepieces you know the setting for, then inserting the XW and focusing with the tunable top
without touching the focuser.  Whatever setting you end up with is the proper setting for the 30mm or 40mm.
#222 Disciplus55
Disciplus55
Posted 06 December 2015 - 12:56 PM
Thanks for the tip, my other eyepiece is only a XW10... Nothing else, i only my ortho's on my 100ED.
#223 Starman1
Starman1
  • Loc: Los Angeles
Posted 06 December 2015 - 02:23 PM
Someone far up the thread mentioned setting 1 for a Paracorr for the XW 1.25"ers.
So, start with the 1.25" adapter in the GSO coma corrector, focus, and look at the edge.
Pull the eyepiece out of the adapter 1/8" (or pull the adapter out 1/8"), refocus, and look at the edge.  If it got better corrected at the edge, continue the 1/8" process until the image gets worse at the edge and move it down 1/8" to the best correction location.  You might need to add a parfocalizing ring to the XW so you can return it to that position when reinserted.
Then, without moving the focuser, remove the adapter and slide the 2" XW into the coma corrector.  Pull it out until it is in focus and lock it down.  That'll be the position for that eyepiece.  You might want to add a parfocalizing ring, and you might need to add a barrel extender to the 2" eyepiece for safety.  And, obviously, if the correct position is well out of the coma corrector, the spacer mentioned can be added to the coma corrector so the top of the CC is higher and your eyepiece needs less height above the CC.
It's also possible the eyepiece will need to be moved in all the way and still not achieve focus.  If that's the case, don't fret it--just use the eyepiece in that position.
