Nexstar SE Mounts
29 replies to this topic
#26 Doug76
Doug76
    Long Achro Junkie
Posted 24 April 2009 - 10:22 PM
Oh yeah, the SV102ED is way too big for either of the SE mounts. The smaller SE mount works fine for the 66mm ED's, and the larger SE mount works for the shorter 80mm's.
BTW all, I did figure out how to make the degree sign. Too much involved, so I'll stick to the asterisk.
And of course, the AT80EDT is gone. So is my AT66ED. Still have the two SE mounts, but the small one sees no use nowadays.
#27 Don Allen
Don Allen
Posted 01 May 2009 - 03:24 PM
Thanks Doug.
Don
#28 Doug76
Doug76
    Long Achro Junkie
Posted 01 May 2009 - 10:47 PM
You are welcome.
#29 Charlie Hein
Charlie Hein
Posted 02 May 2009 - 07:15 AM
90º - Doug, the numbers must be input on the 10-key pad. If you're on a laptop then you should be able to shift in and out of a pseudo 10-key on the right side of your keyboard.
Hopefully that works for you!
Charlie
#30 Doug76
Doug76
    Long Achro Junkie
Posted 02 May 2009 - 09:36 AM
No, I found how to do it, but it's too much to do to get a simple character, so I'll stick with using the asterisk or simply writing "deg".
