Is CGE Worth Twice The Price Of The Orion Atlas?
28 replies to this topic
#26 MartyT
MartyT
Posted 24 September 2008 - 03:39 PM
I can't take credit for the ratchets or the Alt knobs. I believe I got the ratchet idea from Joe, gimme that Giordano's pizza, Cipriano and I know Joe gave me the link to McMaster for the knobs. Changing the grub Alt grub screws to the knobs is one of the single best and simple modifications that can be made to the CGE, by the way.
David
Man, I always find this stuff 30 seconds too late... Just ordered the CGE replacement knob set from ADM and then find that there's a cheaper source...
David, can you share the URL to McMaster-Carr for the knobs?
#27 mclewis1
mclewis1
    Thread Killer
Posted 24 September 2008 - 06:26 PM
McMaster-Carr is rarely cheaper than anywhere else ... their stuff is usually some of the best quality and priced accordingly.
I didn't know ADM had replacements for the alt clamping bolts (grub screws). The CGE replacement bolt set I got from Anthony replaced all of the bolts on the pier to make setting up and breaking down the mount much easier.
#28 David Pavlich
David Pavlich
    Transmographied
Posted 24 September 2008 - 08:18 PM
David
No...you did alright. The knobs you ordered are not what I was talking about. The knobs I spoke of replace the set/grub screw for the Alt adj. Different animal. I have the Losmandy knobs for my CGE...basically the same thing that you bought from ADM.
David
#29 dpastern
dpastern
Posted 25 March 2009 - 06:00 AM
As someone new to astro imaging and quality EQ mounts, I'd logically agree with Ed's comments.
I've seen some excellent images from an EQ6 (or less) mount, provided the mount was accurately polar aligned, drift aligned, well balanced, and not over laden, and then guided using something like phdguide. Some of these images rival those taken by more expensive mounts. I've seen some average imagers with very expensive equipment taken well, let's just say, not very good images.
Take care with how you set things up, treat the mount well, and a cheaper mount will perform. Is the CGE worth 3 times the price? imho, no. Not unless you image with heavy loads that are beyond the ability of the EQ6 to handle.
I've found that Astronomy is like hi fi - it's a big you know what contest about who has the biggest, or most expensive piece of kit. Half the people with expensive setups probably don't really use them, or use them very well.
Dave
I just purchased an Atlas (upgrading from a ASGT) so I just answered the Atlas vs CGE question. To me the comments concerning the CGE being the minimum to get into serious imaging are a little bit of a stretch. I have seen some absolutely high quality images produced using "lower" grade mounts. The big difference to me was the capacity. Yes the CGE has higher weight capacity and if that was the determining factor in image quality I would agree that the CGE is better. We all know that there is more to it than that. The skill of the operator is a much larger factor. I personally did not need the capacity at this time. Since astronomy equipment holds its value exceedingly well (>80%), I don't need that much capacity and my skill is still growing, there was no reason to spend that much money. In addition my imaging targets are wider field where I don't need the super high accuracy.
I bought a used Atlas. If I need to step up in terms of capacity then I can sell the Atlas without taking a huge hit and buy the CGE.
As with most of these things there is never a right or wrong answer. It all depends on money and what you want to do.
Ed
