Autoguiding w/original Meade DSI
11 replies to this topic
#1 Ricky
Ricky
Posted 08 December 2008 - 11:32 PM
Hi All,
Ive got a mount that uses the Losmandy dual axis control board. It has an autoguide port, I assume it is st-4 compatible. Ive also got an original Meade DSI ccd imager laying around. It looks to me like I could use PHD Guiding as the control software and hook-up to the autoguide port from my laptop via the Shoestring GPUSB adapter. Does this look right?
#2 Craig
Craig
    Vendor (Stark Labs)
Posted 09 December 2008 - 01:15 AM
Ayup -- looks just fine.
Craig
#3 MikeCatfin
MikeCatfin
Posted 09 December 2008 - 07:34 AM
That's exactly what I use. Works very well.
#4 LLEEGE
LLEEGE
    True Blue
Posted 09 December 2008 - 08:05 AM
Except the cable supplied with the DSI is not ST4 compatible.
I figured this out after a few days of head scratching. I bought some new RJ45 (IIRC) ends from Radioshack and reversed on of the ends. I think the MEade cable is straight through and ST4 is cross through. Or the opposite.
#5 Ricky
Ricky
Posted 09 December 2008 - 09:19 AM
Thanks everyone for your inputs!
#6 MikeCatfin
MikeCatfin
Posted 09 December 2008 - 09:31 AM
The DSI cable doesn't go into the ST-4 port though; it goes into the laptop so it shouldn't make a difference. The cable from the GPUSB goes into the ST-4 port so if you get the RJ45 cable from Shoestring you should have no issues.
#7 LLEEGE
LLEEGE
    True Blue
Posted 09 December 2008 - 11:10 AM
Right, but the DSI cable doesn't work from the GPUSB to the ST4 connection. (at least mine had to be switched)
#8 MikeCatfin
MikeCatfin
Posted 09 December 2008 - 12:49 PM
I seem to be missing something here. The DSI only comes with a usb cable that connects to your laptop so there would be no need to connect it to the GPUSB. And the GPUSB connects to both the laptop via usb and the mount via RJ45.
Do you mean your GPUSB cable had to be changed? Thanks.
#9 LLEEGE
LLEEGE
    True Blue
Posted 09 December 2008 - 01:04 PM
My DSI's came with:
DSI Camera
AutoStar Suite Software
USB Cable
LX200 serial cable
DB-9 to RJ-11 Adapter
497 AutoStar Serial Cable
(had the #'s wrong, but the cable that came needed to have one end reversed. It works now. :)
#10 Nick-Sydney
Nick-Sydney
Posted 21 June 2009 - 10:55 AM
Can anyone explain what the DB-9 to RJ-11 Adapter and cable are used for? I can't figure it out...
#11 jrcrilly
jrcrilly
    Refractor wienie no more
Posted 21 June 2009 - 11:16 AM
It's used to control a Meade telescope mount if desired (serial port autoguiding, planetarium software goto control, firmware updates) from a PC serial port.
#12 Nick-Sydney
Nick-Sydney
Posted 23 June 2009 - 12:19 PM
Ahh, thanks for that. I don't have a meade mount. LOL
