Astro-Tech Voyager Mount
40 replies to this topic
#1 asaint
asaint
Posted 11 January 2009 - 06:20 AM
Astro-Tech
#2 Tom T
Tom T
Posted 12 January 2009 - 10:12 AM
Nice review Jason!
#3 Jason B
Jason B
    Proud father of 5!!
  • Loc: Mid-Michigan
Posted 12 January 2009 - 11:20 AM
Thank you!
#4 JimMo
JimMo
    I'd Rather Do It Myself
  • Loc: Under the SE Michigan lightdome
Posted 12 January 2009 - 05:46 PM
Hi Jason,
Great review. I was tempted to write a review myself on the Voyager I've had for about a year and I agree that it's an awesome grab and go set up. As for the height, I opted to use a CG5 tripod which gets the scope up far enough for me to stand while observing. I just need to bend over a little bit to see to the zenith.
#5 Geo557  Happy Birthday!
Geo557
    Astro-Scout
  • Loc: SE GA
Posted 12 January 2009 - 07:13 PM
Very good informative review Jason. Ideal G&G mount. I plan to own one someday.
#6 Robo-bob
Robo-bob
  • Loc: Central Alberta
Posted 12 January 2009 - 07:25 PM
Would this be a good mount for a 4" F6 refractor? I have tried a bunch of alt.az. mounts only to be disappointed by the
motions and the vibrations. I really want something that will be reasonably stable and still keep vibrations under 1 second with a sharp rap to the tube. What do you all think?
I could also put the mount head on a beefier tripod if that would give me the desired result.
Rob
#7 TONGKW
TONGKW
Posted 12 January 2009 - 08:29 PM
I occasionally mount my TSA102 (102 mm f/8) on the Voyager for a quick look. The set up is usable but unfortunately as the center line of the refractor OTA is offset to one side I am a bit scared of the stability problem so I always stand by the side for fear of tipping over in case some enthusiastic viewer might give it an accidental nudge.
K W TONG
C8 + CG-5GT, TSA102 + HEQ5 PRO, MK67 + Voyager Mount, WO ZS 80FD + Kenko NES, NexStar 6SE, WO Megrez 72 + Mizar K Mount, Mini Borg 50, C5, PST
#8 TONGKW
TONGKW
Posted 12 January 2009 - 08:30 PM
The Voyager is actually more stable for mounting short length OTA such as the C8
#9 Jason B
Jason B
    Proud father of 5!!
  • Loc: Mid-Michigan
Posted 12 January 2009 - 09:45 PM
Thanks guys! This is my first "real" review so I appreciate the feedback.
#10 Jason B
Jason B
    Proud father of 5!!
  • Loc: Mid-Michigan
Posted 12 January 2009 - 09:50 PM
Rob
Depends on what 4" F6 it is. My 3" F8 is about the same length. I would guess the slight weight difference wouldn't be much. If it's a smaller, lighter OTA like the Orion 100mm F6, it should be fine in the 1-2 second range. A heavier triplett APO might be slightly worse but not much. With my 6" F5, it is still 1-2 seconds on the grass so I can't imagine it would be any worse than that.
#11 dvb
dvb
    different Syndrome.
  • Loc: Vancouver, Canada
Posted 12 January 2009 - 10:57 PM
An excellent review.
The movements aren't buttery smooth like an EZTouch, but that means that balance is not as critical, which helps. The slo-mos are also a plus.
I bought mine to mount a C6, but last time had the ED100 f/9 on it. The mount worked well with both -- but the tripod is too short!
I have considered the available extender, but will probably look for a CG-5 or a wood compatible tripod.
#12 DLB242
DLB242
    Mr. Warmth
  • Loc: Pen Argyl, PA
Posted 13 January 2009 - 07:07 PM
Ditto to the nice review. I usually observe seated even for grab and go. Right now I am using a Stellarvue M1 mount on a home made wooden tripod with my 80mm scopes. But 80mm is about the upper limit for this mount so I am looking for an Alt Az for my 102mm f/8.7 SV102BV. Doesn't sound encouraging so far.
#13 Jason B
Jason B
    Proud father of 5!!
  • Loc: Mid-Michigan
Posted 13 January 2009 - 08:51 PM
Thanks guys!
#14 paul hart
paul hart
  • Loc: Long Island, New York
Posted 16 January 2009 - 12:09 PM
Jason,
Thank you also. I was on the fence about getting a Voyager, and after reading your review, I ordered one.
#15 Astronomics
Astronomics
    Vendor: Astronomics
  • Loc: Right Here
Posted 16 January 2009 - 03:18 PM
It will most certainly take more then an 80mm scope. No worries.
#16 Chris Schroeder
Chris Schroeder
  • Loc: N.E. WI Sky Glow
Posted 16 January 2009 - 05:11 PM
Great review Jason :goodjob:
#17 Chris Schroeder
Chris Schroeder
Posted 16 January 2009 - 05:15 PM
Hi David, I used my 102ED F7 on this mount and felt the mount the could handle the weight, changing the tripod legs to wood ones would increase the stabilty for a heavy scope such as yours.
#18 Jason B
Jason B
    Proud father of 5!!
  • Loc: Mid-Michigan
Posted 16 January 2009 - 05:56 PM
Thanks Chris and Paul!
I agree with Mike on the assertion of taking more than an 80mm scope. My 6" F5 rides very nice on this mount. The only thing I would worry about is if it was a really long scope, such as an F10 4". The moment arm might lengthen the time the vibrations dampen out by a second or so. Some wouldn't mind it, some might. YMMV as they say.
I will try it one of these nights if it ever clears in mid-Michigan with one of my larger refractors. I'd do it tonight but I have a new MX7C to try out and it's actually clear!
#19 Jason B
Jason B
    Proud father of 5!!
  • Loc: Mid-Michigan
Posted 16 January 2009 - 05:58 PM
Paul,
It will be a great match for the 127mm Starmax if that is the scope you intend to use it for!
#20 paul hart
paul hart
Posted 16 January 2009 - 08:06 PM
Paul,
Yes that it will be used for primarily. It's going to fly with me to New Mexico in June. Plus I have a small car and want to take it to my brother's place in northern Michigan. :)
#21 DCS357
DCS357
  • Loc: Lubbock, Tx
Posted 16 January 2009 - 08:18 PM
Do you think I would have any problems with my Celestron 120 Omni f/8.3. It is 40" long and 12.5 lbs. I am thinking of getting this if it will support my scope. Also, will the mount work with my tripod (CG-4), i heard it will work with the CG-5)
thanks
don c
#22 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 16 January 2009 - 08:31 PM
Jason, Wonderful review! I have the AT Voyager, & love it; selling my PortaMount & keeping the AT.
Thanks for the great photos accompanying your review, also!
#23 Jason B
Jason B
    Proud father of 5!!
  • Loc: Mid-Michigan
Posted 16 January 2009 - 11:25 PM
Paul,
You'll have to try and come in September some time, during the Great Lakes Star Gaze. Nice star party in North-Central Michigan.
#24 Jason B
Jason B
    Proud father of 5!!
  • Loc: Mid-Michigan
Posted 16 January 2009 - 11:30 PM
thanks
don c
Thanks Don. The mount would have no trouble holding the weight but the length could be a problem with focusing gitters. I think it would be alright but everybody is little different when it comes to mount tolerances so, if you can, give it try before you buy.
I am unfamiliar with the CG4 tripod so I can't help you there.
#25 Jason B
Jason B
    Proud father of 5!!
  • Loc: Mid-Michigan
Posted 16 January 2009 - 11:31 PM
Thanks for the kind words Carol.
