Heavy Duty Altaz with Slow Motion controls
33 replies to this topic
#1 AlienRatDog
AlienRatDog
Posted 18 February 2009 - 01:50 PM
What Altaz mounts out there that are heavy duty (can handle something like an EON120 or Explore Scientific 127mm triplet) that has slow motion controls?
#2 Erik D
Erik D
Posted 18 February 2009 - 02:08 PM
How much $$$$ you got?
http://www.binoscope...ino.htm#altazmt
Strong enough to handle your 12 inch SCT or a 6 inch refractor.
ERik D
#3 Doug D.
Doug D.
Posted 18 February 2009 - 02:11 PM
I think the Tak Teegul with Lapides modification would handle the 120 but I'm not familiar enough with your other scope to have an opinion. If you do some searching here on CN and elsewhere you'll find a lot of info - it is a pretty popular mount. I use one with my 105EDF and it has no problems with it at all and it is clear to me it can handle a good deal more.
There are also additional mods possible that help with capacity and, of course, there is no substitute for a solid set of legs.
#4 Luigi
Luigi
Posted 18 February 2009 - 02:48 PM
Tegul or AtroTech voyager are both marginal IMO for a 120ED. I'm using an Orion AZ for the Eon 120 and IM715. I can mount both on it at the same time and it's very stable. No slo mo tho.
#5 Fred1
Fred1
Posted 18 February 2009 - 06:23 PM
Check out the Half Hitch, there's a sale on:
http://www.halfhitchtelescope.com/
#6 Erik D
Erik D
Posted 18 February 2009 - 08:27 PM
There are heavy duty Alt Az mounts that can handle up to 50 lbs on each side. See the discussion and links in this thread for more info: Giro DX and XXL
Slo mo control is not needed if the OTA is perfectly balanced. However, If you change back and forth often between a heavy binoviewer and light wt EP it may not be very convenient for you. You will need to rebalance. I use a Losmandy Saddle and 13.5 inch male dovetail plate with my 6 inch F8 refractor. It's pretty easy for me to achieve perfect balance. 300X is no problem.
ERik D
#7 John Huntley
John Huntley
Posted 18 February 2009 - 09:41 PM
How about a solid EQ mount (eg: EQ5 or Vixen SP) used in Alt-Az mode ?.
John
SW England
#8 Jerry Hyman
Jerry Hyman
Posted 18 February 2009 - 10:03 PM
I haven't seen any recent posts on there delivery, but Astro-tech is suppose to be coming out with a heavy duty version of their Voyager.
~jerry
#9 Erik D
Erik D
Posted 18 February 2009 - 10:12 PM
John
SW England
I like that idea a lot.
IIRC the old Astro Physics 706 head and the Vixen DX can be used on the side as an Alt az head with slo mo. The problem is no manufacturer or dealer seem list which EQ head can be used that way anymore. I am not sure if they want to discourage using a EQ head that way or just don't feel there is a demand.
I went to visit Company 7 in Md, USA many years ago. I think Marty was mounting an 7 in F9 AP refractor on a 706 mount in Alt Az mode.
ERik D
#10 Per Stymne
Per Stymne
Posted 19 February 2009 - 03:02 AM
Abe,
The Track The Stars is a hefty alt-az mount with with goto controls, but possibly too pricey for a "poor PhD student".
I saw this mount at a star party half a year ago. It was a truly impressive piece of equipment, with a price tag which fully matched the engineering.
http://asp.trackthestars.com/
#11 Eddgie
Eddgie
Posted 19 February 2009 - 08:16 AM
Wow.. Never saw this one before. Horribly expensive, but I LOVE the concept! It is ashamed that no one is making something like this in large quantities. I am a visual only observer so don't need to worry about field rotation, and If I could get a mount like this at a Clestron CGE Price, I would be there in a heartbeat!
#12 hudson_yak
hudson_yak
Posted 19 February 2009 - 09:24 AM
Agree, finally an alt-az that's actually a balanced design. The concept seems so obvious when you look at it.
#13 Doug D.
Doug D.
Posted 19 February 2009 - 10:29 AM
The price on that TTS-160 seems a bit insane. Given that it can hardly be called portable, I just don't see why you wouldn't just go with a nice AP 900 or 1200 (or Mach 1) rather than this? Is there a reason to be wedded to Alt/Az (horizon-based) coordinates instead of the more "practical/universal" equatorial coordinate system. Trust me, I use and love alt/az mounts for certain scopes and especially for convenience but I don't get this... what am I missing. I like the overbuilt German engineering involved in this sucker though.
#14 AlienRatDog
AlienRatDog
Posted 19 February 2009 - 11:05 AM
I just want a nice Altaz with slow motion controls that can hold a 120-130mm refractors, they seem rare on the market...dont think they exist...well unless I am not finding them...
#15 Per Stymne
Per Stymne
Posted 19 February 2009 - 04:28 PM
Neither have I found any heavy duty altaz mounts with manual slow motion controls. There seems to be an upper limit of 6 kgs/15 lbs load. Everything with a greater load capability than that seem to be altaz mounts with no motion controls at all except "push the OTA gently if you want to track".
#16 Per Stymne
Per Stymne
Posted 19 February 2009 - 04:37 PM
Track The Stars is a Danish design, not a German. Btw, I just discovered they are building a new web site, http://www.trackthestars.com
#17 Doug D.
Doug D.
Posted 19 February 2009 - 05:06 PM
sorry, my bad. Then I guess I like the overbuilt Danish engineering... ;)
#18 DennisF
DennisF
Posted 19 February 2009 - 07:58 PM
Stellarvue has a new mount just out, the MG. Not many out in the field yet. Starlighter has one on order I think. I believe they recommend it up to their 115mm and they tend to be conservative. It does have slo-mo.
#19 7331Peg
7331Peg
    Sirius Observer
Posted 20 February 2009 - 02:23 AM
The Disc Mount-6 can definitely hold the 120 and 130mm scopes you're referring to - I've had a TMB130 on mine, and it handled it with no problem at all. It doesn't have the slow motion controls, but I ordered the handle for it and I have no problem tracking objects without any stiction in either horizontal or vertical motion. If you're working against gravity in the vertical direction, it sometimes takes a bit more effort to move the scope, but even then, no stiction. It isn't cheap, but it's the best you'll find for a 130mm scope.
Stellarvue is making the M7, which will also hold the 130mm scope, but again, no slow motion controls and with the tripod and saddle plates, it's pretty close to the DM-6 in price.
Teton Telescopes also has the Max Load for alt-az, also expensive and no slo-mo controls, but like the Stellarvue offering, it really doesn't need them.
The Giro may be able to handle the 130mm, but I have no experience with anything that heavy on it.
The reality is that a good mount for a 130mm scope is going to cost quite a bit of money, and the GOOD mounts don't really need slow motion controls.
#20 Clive Gibbons
Clive Gibbons
    Mostly Harmless
Posted 27 February 2009 - 09:27 AM
Yeah, that looks like a good mounting.
Apparently, it's made by
Kunming United Optics and they offer lots of other quality accessories, so no worries.
#21 islandsteve11
islandsteve11
Posted 27 February 2009 - 11:31 AM
Doc Abe,
I think the most cost effective solution is to wait for the new AT heavy duty Voyager, assuming Mike B can get either the mount head or tripod manufacturer to make an adapter so the two parts are compatable. I assume you saw Mike's post regarding his "silly, but a problem none the less" issue with the parts manufacturers' unwillingness to make adapters.
I wish I had the mega $$$ for a nice binoscope or the European alt-az.
#22 jrbarnett
Posted 27 February 2009 - 04:13 PM
Can't be the same mount, can it? According to the owner, Stellarvue is "waiting for gears" and will be "cranking out" its own mount. The Kunming is a turnkey, complete mount solution. There'd be no reason to wait for parts or crank anything out if it were simply a re-branded product.
#23 Nick Lloyd
Nick Lloyd
    He asked for it
Posted 27 February 2009 - 09:44 PM
I've been happy with my Giro II-DX. Had a 40 lb 7" refractor with counterweights and it worked like a charm. Right now I use a 9.25" SCT and a 4" triplet side-by-side.
Is there someone producing an aftermarket slow-mo control for the Giro???
#24 Wes James
Wes James
Posted 28 February 2009 - 05:11 PM
Joe Castoro/Binoscope Company makes saddle type mounts- similar to the Helix Hercules with both slo-mo controls and encoders. They can handle big loads.
#25 Clive Gibbons
Clive Gibbons
    Mostly Harmless
Posted 03 March 2009 - 10:57 AM
Well, lo and behold, Vic has just stated that his shop is so busy, he's outsourced the whole MG/MGE project.
There ya go... :imawake:
