Vixen Mounts and CG-5 Tripods - Compatible?
7 replies to this topic
#1 TomN
TomN
Posted 22 February 2009 - 01:43 PM
Does anyone know....Will the Vixen GP and GPD2 fit my CG-5 aluminum tripod?
#2 plyscope
plyscope
Posted 23 February 2009 - 04:20 PM
Hi Tom
I believe they are compatible. I have a new GPD2 mount and have recently purchased a tripod hub from an EQ5 which is simalar to a CG-5. I picked up a Vixen pier adapter at the same time. The EQ5 tripod hub is slightly smaller diameter but still acceptable.
#3 Miguel Lopes
Miguel Lopes
Posted 23 February 2009 - 05:28 PM
I had a CG5 and then bought a Vixen SXD. I had to make minor adjustmenst to my pier. If you are in a hurry, yes, it works. But if you want to make fine polar adjustments, you need to replace the small top screw that is used for the azimuth adjustment by a bigger screw.
And you need to make a hollow metal cylinder that matches the Vixen smaller inner tube. Costed me some 20€ in a good metal worker.
#4 watcher
watcher
Posted 23 February 2009 - 10:05 PM
The GP2 and GPD2 should be an exact fit.
#5 Al Canarelli
Al Canarelli
Posted 23 February 2009 - 10:57 PM
If you're talking about the telescoping aluminum tripods of yesterday, yes they will fit if the Vixen has the correct tripod mounting ring. If it's a new mount, it probably does not have the correct ring.
The real question here is, why would you ever want to use that terrible aluminum abortion that was called a tripod? The only good place for that thing is in the garbage. Do yourself a favor and don't use it.
#6 plyscope
plyscope
Posted 24 February 2009 - 06:21 AM
Here is a picture of an EQ5 hub with GPD2 mount. I am still working on the wooden tripod and have not yet used this for observing.
#7 plyscope
plyscope
Posted 24 February 2009 - 06:24 AM
GPD2 and Vixen pier adapter.
#8 plyscope
plyscope
Posted 24 February 2009 - 06:28 AM
Pier adaptor compared to EQ5 tripod hub.
I agree with Al, the old style aluminium legs are not much use unless using a very compact and lightweight OTA. Much better if you have the stainless steel or wooden legs. I am guessing the CG-5 has the same type of design as the EQ5 at the connection to the mount at least.
