110v to 12v power supply, purchase or DIY???
13 replies to this topic
#1 PGW Steve
PGW Steve
Posted 28 February 2009 - 12:51 AM
I've been running my mount in the back yard for a while now and don't see much point in lugging booster packs that have a limited life under the strain of dew heaters and -25C temperatures.
I know that Kendrick and Astro-Physics sell an off the shelf inverter. I'm wondering if there is another option for a heavy duty all in one type inverter. As far as a do it yourself project, could you use a heavy duty battery charger as the 'transformer' and then attach 12v sockets to the charging cables?
Any help would be appreciated.
#2 TheMenace
TheMenace
Posted 28 February 2009 - 04:50 AM
http://salestores.co...sppoceacto.html
I have something like this from radio shack and it runs my EQG just fine.
#3 johnpd
johnpd
Posted 28 February 2009 - 05:50 AM
Try this one or this one.
#4 mclewis1
mclewis1
    Thread Killer
Posted 28 February 2009 - 11:50 AM
Steve,
Don't hook up a connector to just a transformer, you need a well regulated and protected 12v power supply. Something that will put out a consistent 12.5 - 13.5 v under all normal loads and that if in the event of a failure will not dump the raw (18+ v off of the transformer) into your scope.
Sure you can build one but I'm with johnpd ... just buy a Pyramid or other well respected brand of power supply. Don't go really cheap (off of ebay from an unknown supplier). The few extra dollars spent will be good insurance.
I use a pair of Pyramid 9KX's to power my CGE and imaging gear. Size your power requirement and then add 50% and you'll likely never have to worry about it again.
#5 ccs_hello
ccs_hello
Posted 28 February 2009 - 01:17 PM
If the device is used outdoors, please make sure the ventilation holes are not exposed to the ambient.
Open-frame type is not recommended.
Clear Skies!
ccs_hello
#6 Luigi
Luigi
Posted 01 March 2009 - 08:12 AM
A battery charger is not designed to run 12V devices, but to charge batteries, so is the wrong device to use for a number of technical reasons. Good 12V supplies(actually 13.8 volts, which is the fully charged voltage of a 12V lead acid battery) are very reasonable. You can get a 30 amp supply around $150, maybe less. Keep the supply in your house and run heavy gauge wire for 12V to your observing location. Put a fuse at the power supply to limit the current to that which is safe for the wire you use. For 30A, you need something like 6 gauge wire. If you use smaller gauge wire, use an appropriate smaller fuse. Check here for wire gauge recommendations. http://www.powerstre...m/Wire_Size.htm
#7 rmollise
Posted 01 March 2009 - 10:43 AM
I doubt you would save any money, and the quality of the current would be worse. If you don't want to use a battery, look at a good, REGULATED AC power supply. Radio Shack as 'em, and the ones from MFJ are good and reasonably priced as well.
#8 John Carruthers
John Carruthers
    Skiprat
Posted 02 March 2009 - 11:16 AM
Have you considered a PC PSU? steady volts and a reasonable supply of amps. Cheap too.
#9 Kaizu
Kaizu
Posted 02 March 2009 - 03:53 PM
I bought this and it works well with my G11. It gives ca.5 Amps max. and the voltage is guite stabil 13V. I think that there are similar availlable also in Canada. These come from China and I think that the million Chinese can't be wrong.
Kaizu
#10 Fish
Fish
Posted 02 March 2009 - 07:54 PM
Hello all,
I've used Astron power supplies for years in both amateur radio and astronomy applications. Some have been on 24/7 for years with nary a glitch. Depending on your needs, you can get models that can put out over 50 amps (!) at 13.8v continuous. http://www.astroncorp.com and available through numerous dealers.
No, I have no financial interest in them; I just like their products!
Regards, Marc
#11 Doug D.
Doug D.
Posted 03 March 2009 - 02:00 AM
The Pyramid power supplies are great as others have suggested. AP has chosen to offer one of these (PS9KX) for their mounts - but if you look around you can find them for quite a bit cheaper (like Amazon or the Bay).
#12 MartyT
MartyT
Posted 03 March 2009 - 04:17 PM
All of my equipment (CGE mount, dew heaters, QHY8, etc.) runs off of cheap 12V power supplies like this one:
http://www.12vadapte...v/6-amp-6a.html
You don't need anything fancy.
#13 mclewis1
mclewis1
    Thread Killer
Posted 03 March 2009 - 04:48 PM
The 2.5mm tip on the power plug for these power supplies is the wrong type for Celestron products. They require a 2.1mm tip. Using the larger diameter one opens up the possibility of intermittent connections. Yeah you can split the center pin a bit more than normal to make these work but IMHO you're just asking for trouble at some point.
#14 MartyT
MartyT
Posted 04 March 2009 - 05:04 PM
Sorry - I didn't give a complete description of what I'm using.
All my power supplies are outfitted with Anderson PowerPole connectors, as are all the cables going to various devices. I can connect any device to any power supply and it's impossible to reverse the polarity of anything.
In the case of the CGE, I actually have a PowerPole-to-cigarette lighter socket cable that goes between the supply and the stock DC cable that came with the mount.
