Comet Lulin over Belgium.
7 replies to this topic
#1 rodelaet
rodelaet
Posted 04 March 2009 - 02:36 PM
Comet Lulin.
Until now I had only seen the comet through the sketches of this forum. With these beautiful sketches in mind, I finally turned my little binoculars towards Lulin. I knew its trajectory and expected to bump into the comet somewhere between Leo and Cancer. And in fact I did find the comet very easily. It’s a bright target. The bright nucleus is very conspicuous. At first sight, Lulin reminded me of an unresolved globular. After a few seconds, I could clearly determine the direction of the weak tail of the comet. Averted vision was mandatory. Of course, the binoculars were mounted, which also supported the averted observation of the weakest details. You may need averted vision as well to see the comet tail in my sketch.
Site : Bekkevoort, Belgium ( 51° N )
Date : March 2, 2009
Time : around 21.15 UT
Binoculars : Bresser Spezial-Jagd 8x56
FOV: 5.9°
Filter : none
Mount : Trico Machine Sky Window
Seeing : 3/5
Transp. : 3/5
Sky brightness : 19.56 magnitudes per square arc second near zenith (SQM reading).
Nelm: 5.3
Sketch Orientation: N up, W right.
Digital sketch made with Corel Paint Shop Pro X2, based on a raw pencil sketch.
(Note: if the sketch does look too dark on your monitor, try to darken the room.)
#2 markseibold
markseibold
Posted 04 March 2009 - 05:06 PM
Rony
Very nice sketch work :bow: :bow: :bow: You are rendering about the same as I see the comet from light polluted skies at 7 miles out of downtown Portland. I can just barely make out the tail with binoculars and averted vision, exactly as your sketch shows.
Although there are many beautiful photographs in the web, your sketch shows the true and accurate eye visible image from urban skies and should serve well to educate other readers.
Thanks for posting your work and sharing the veiwing tips,
Mark
#3 frank5817
Posted 04 March 2009 - 07:30 PM
Rony,
Excellent sketch of comet Lulin. :bow: :cool: :rainbow: As it moves to the west and away from earth it is great to see we will continue to get opportunities to view our departing visitor for a while longer. With that hyperbolic orbit it will not be back. Great sketch Rony. :bow:
Frank :)
#4 varmint
varmint
    I invite more abuse
Posted 04 March 2009 - 11:44 PM
Rony, great capture. I did have to wait until dark to really view the image (too much glare on my monitor).
#5 CarlosEH
CarlosEH
Posted 05 March 2009 - 05:37 AM
Rony,
An outstanding observation of Comet Lulin. You have captured the appearance of this ghostly interloper very nicely. The ion tail does require the use of averted (not inverted!) vision. Thank you for sharing it with us all.
Carlos
#6 rolandlinda3
rolandlinda3
Posted 05 March 2009 - 10:21 AM
Beautiful wide field view. It really is fun to watch it. Roland
#7 asteroid7
asteroid7
Posted 05 March 2009 - 02:34 PM
Ditto, nice wide view sketch
#8 rodelaet
rodelaet
Posted 09 March 2009 - 04:23 PM
Thanks a lot for the kind words, guys! :)
