Feb09 Sketching Poll Run-Off!
8 replies to this topic
Poll: Feb09 Sketching Poll Run-Off! (41 member(s) have cast votes)
Please pick your favorite Sketch:
You cannot see the results of the poll until you have voted. Please login and cast your vote to see the results of this poll.
Vote
#1 Charlie Hein
Charlie Hein
Posted 09 March 2009 - 11:26 AM
We have ourselves a run-off for the Sketching Semi-Finalist in the February 2009 CN Imaging/Sketching Contest! Please choose your favorite from the choices below.
varmint:
Constellations over Sedona Rocks in the morning
Observing Info:
Naked Eye
Feb 18, 2009, 3:30-4am MST in Sedona, AZ.
Transparency was above average
Seeing was average
Temp was about 40 deg F.
Light periodic wind and some thin high clouds wafted through from time to time.
Location was in an empty field off of Highway 89 in Western Sedona.
NELM around 5.3-5.5 at the time of observation. The 1/8th crescent moon had just risen in the east in Scorpius, contributing some light pollution. The Milky-Way was not visible.
Sketching details: raw sketch was graphite on engineering paper, focus was on the silhouette of the mountains, even in the dark there were two prominent shadows visible on the main rock formation (Capitol Butte I think is it's name) that I roughed in on the raw sketch. I also focused on star placement of the constellations. Many constellations were visible, and I focused my effort on identifying most of the visible stars. During the generation of the raw sketch I just happened to witness a meteor streak through the field I was sketching, so I captured that as well.
Final sketch used Navy Blue acid free cardstock, a combination of graphite and black charcoal for the mountain silhouette (started with graphite and found it was too shiny, so added a layer of charcoal and used a blending stump to smooth out the silhouette), white charcoal pencil for the stars.
frank5817:
M42/ M43 Orion Nebula and Its Companion
Everyone that has taken a telescope or pair of binoculars outdoors to view the heavens on a clear winter night in the northern hemisphere has seen the Orion nebula. It is that fuzzy star in the middle of the hunter’s sword. M42 the “Great nebula” is a stellar nursery and emission nebula that shines as bright as a 4th magnitude star while its smaller companion on the other side of the intervening obscuring dust is M43 shining at 9th magnitude. Soon the nebula will be past the south meridian point before it is fully dark. So now is the time to take your last good looks before it’s too late; spring will be here soon.
On this night I decided it was time to try and make a sketch of this winter gem. I have made a few crude sketches in the past and know this is a tough target to capture as it appears in the eyepiece. I started by sketching the stars and lightly outlining the bright parts of the nebula with a 2H pencil. After much erasing and repositioning of stars I shaded in the bright to faint nebula gradually until it looked to be a reasonable match to the eyepiece view. After two and a half hours I consider the sketch finished. Averted vision helped with the outer faint regions.
It was a slow process but a fun challenge at the same time.
Sketching
Date and Time: 2-15-2009, 1:10-3:20 UT
Scope: 10” f/5.7 Dobsonian. 21mm Hyperion eyepiece 69x
8”x12” white CCP sketching paper, 2H, B, 2B graphite pencils, blending stump, erasers, scanned and inverted, contrast and brightness were slightly adjusted at the scanner
Temperature: -3 °C (26 °F), calm
Seeing: very good Pickering 8/10
Transparency: good 3/5
Frank McCabe
Erix:
This was done entirely at the eyepiece. The collage was put together in Photoshop after photographing my sketch (rather than scanning).
2009 Feb 13, 1600UT – 1700UT
Solar prominences in h-alpha, western limb
PCW Memorial Observatory, Zanesville, Ohio USA
Erika Rix
DS 60mm Maxscope, LXD75, 21-7mm Zhumell
Sketch created scopeside with black Strathmore Artagain paper, white Conte’ crayon and pencil, white Prang watercolor pencil.
Temp: 3° C, Humidity 60%
Seeing: Wilson 3, Transparency: poor
Scattered, winds 7mph from NNW
Alt: 34.4, Az: 159.2
Approximately 30° inward from the eastern limb, a crescent-shaped plage was seen with a dark dot during my h-alpha observation. No AR was noted in white light. There were a few proms scattered about to the north and south, but the prominences on the western limb really stood out. At first glance it looked like two detached proms, but adjusting the outer etalon and increasing magnification, that section of limb came alive with prominence structure.
cildarith:
OBJECT DATA
Object Name: C/2007 N3 Lulin
Object Type: Comet
Constellation: (Leo)
Right Ascension (2000.0): 09h 59.5m
Declination (2000.0): +12° 03'
Magnitude: ~6½
Dimensions: Coma ~15', Tail ~100'
OBSERVATION LOG
Date/Time: 28 February 2009 • 10:15 – 10:45 UT
Location: Rancho Peñasquitos, San Diego Co., California
Telescope: Parks Astrolight EQ6 • 6" f/6 Newtonian Reflector
Eyepiece/Magnification: 7.5mm Parks Gold Series Plössl +2x Barlow • 240x • 13' FoV
Filter(s): None
Conditions: Partly cloudy, calm, 54°F
Seeing: Pickering 8
Transparency: NELM 4.8; TLM 13.7
SKETCH DETAILS
Paper: 24# Cartridge Paper
Pencil: #2 Mechanical, 5mm lead; blending stump
Scanning & Processing: Microsoft Picture It!
Comments: Finally, here is my first observation of C/2007 N3 Lulin after much frustration with uncooperative weather. A quick look at low magnification (30x) revealed the prominent ion tail, stretching at least 100' sf, while the dust tail was barely detectable as a short, broad fan spreading about 10' or so nf. Nearby Nu Leonis made a very pleasing scene. As is my habit with bright comets, I then dialed the magnification up to 240x to capture near-nuclear details. The weather gave me about 30 minutes to record the sketch shown here before the view was swallowed up by an imposing cloudbank. I was impressed by the sharpness of the pseudo-nucleus and the prominence of the dark shadow following in its wake. I was unable detect more than the slightest hint of the green color others have reported in this comet.
Please note that voting will conclude on March 10th at Midnight EST.
Many thanks to all who took part in the contest!
#2 Charlie Hein
Charlie Hein
Posted 11 March 2009 - 06:33 AM
Well, it looks like Erix just squeaked it past varmint to become February's Finalist in the CN Imaging/Sketching Contest! Please join me in congratulating her on a job well done and wish her good luck in the finals!
Charlie
#3 varmint
varmint
    I invite more abuse
Posted 11 March 2009 - 09:11 AM
Congratulations Erika! Beautiful sketch.
#4 frank5817
Posted 11 March 2009 - 10:18 AM
Excellent work Erika, a very well deserved win.
Frank :)
#5 markseibold
markseibold
Posted 11 March 2009 - 12:24 PM
Erika
Congratulations on winning this months contest with your excellent sketch work. Your solar sketches always inspire me to observe the sun and to sketch.
Mark
#6 rodelaet
rodelaet
Posted 11 March 2009 - 04:16 PM
Congratulations, Erika! :jump:
I found all the entries of high quality, well done everyone! :waytogo:
#7 darkstar528
darkstar528
Posted 11 March 2009 - 08:06 PM
Great job Erika!!!!!!!!!!
#8 JayinUT
JayinUT
    I'm not Sleepy
Posted 11 March 2009 - 09:02 PM
Erika, terrific job.
#9 Erix
Erix
    Toad Lily
Posted 11 March 2009 - 10:09 PM
Thanks guys. :) As usual, all the other sketches were terrific and made for a very difficult decision when voting. :bow:
