Saturn LRGB 3/17/09
6 replies to this topic
#1 sfugardi
sfugardi
Posted 18 March 2009 - 12:10 PM
Taken just before midnight on St. Patrick's Day. Seeing was not quite 3/5 as predicted by the CSC. I used a 1.8x barlow and 2.25" extension to produce this image, however, I pushed the barlow into the focuser all the way thinking it would be more stable. As it turns out, the extension magnification is increased by extending both before and after the barlow at least for this setup. The result was a smaller image closer to f27 than f30. Next time I will maximize the length on each side to capture the largest possible size. Using a strip of tape I blocked half the flow from 1 of my cooling fans, restricting the intake to approx 5cfm which I left on during the imaging session. The rear mirror temp stayed within +/-0.2degC of ambient during the 2.5hrs period, even as the temperatures dropped 1 degC per hour. Too bad the seeing did not enable me to take advantage of the excellent thermal condition.
I stacked 1200 frames of L (1/30s), 800 R,G (1/15s), & 800 B (1/8s).
Steve
#2 iceman
iceman
Posted 18 March 2009 - 12:27 PM
Very sharp, beautiful image Steve.
#3 sfugardi
sfugardi
Posted 18 March 2009 - 01:03 PM
Mike, Thanks! By the way, I still use your Registax processing method for all my webcam images and just want to say thank you for sharing your expertise.
Steve
#4 Kal
Kal
Posted 18 March 2009 - 04:46 PM
Very nice capture Steve
#5 OMAR
OMAR
Posted 18 March 2009 - 10:56 PM
Love the sharpness.
#6 HANTO
HANTO
Posted 19 March 2009 - 05:48 AM
Hi Steve,
nice catch!
Looks like a white spot close to the CM.
Cheers
Torsten
#7 sfugardi
sfugardi
Posted 19 March 2009 - 11:26 AM
Thanks guys! At first I thought the white spot was an artifact, however solshaker also captured the same storm. That night I took 3 avi runs with the middle one closest to transit and of the best seeing. I will go back and process the other 2 runs and then make a 3 frame movie which would put the them some 25min apart. Hopefully, the storm moves
Steve
