Lunt LS 100 Telescope now available
No replies to this topic
#1 APM M.Ludes
APM M.Ludes
    Vendor (APM Telescopes, Lunt Solar Systems, Lunt Engineering)
  • Restricted Vendors
Posted 19 March 2009 - 09:42 AM
We have right now 2 pc Lunt 100 mm H-alpha Solar Telescopes available from stock, the modell is the LS100THa/B1200
Art. No. LS100THa/B1200
100mm H-alpha Solar-Telescope with B1200 blocking filter
The LS100T/Ha is a complete Solar Telescope. The refractor based system has a precision aligned singlet chromatic lens with a 100 mm aperture. The front singlet lens reduces the stray-light over an achromat by half. With the matched collimation lens set, it also fully corrects on axis coma, astigmatism and de-centering aberrations and provides a full spherically corrected flat-field Solar-Telescope. The focal length is 800 mm providing a ~7.3 mm image thru a 12 mm blocking filter. Course focus adjustment is via a slide tube. Focusing is achieved with a High Precision 2" Starlight Feather Touch Friction focuser with the a 10:1 reduction as standard equipment.
An internal etalon with tune adjustment allows for a <0.75 Angstrom bandpass.
Delivered with order:
• optical tube with 2" feather touch focuser with 2.5" travel, includes adapter
• tube ring
• B1200 blocking filter
• transport case
The Price from Lunt/Tucson is US $ 4,498.00
first reviewes and images can be found at the Cloudynights Forum : SOLAR
You can also order now and pick it up at NEAF given to you personaly by Andy Lunt's Hand :-)
Markus Ludes
Luntsolarsystems
