Ioptron Mini Tower - Random movements
No replies to this topic
#1 ACB
ACB
Posted 28 March 2009 - 01:39 PM
Hi from Argentina:
I had a strange problem when I tried to align with two stars. The balance is correct, but after selecting the second star and pressing enter, the MiniTower moves randomly to any direction. The same happens when I GoTo to any object (Select And Slew), apparently the same amount in the same direction that after the aligment.
When I align with one star I don't have the same problem.
References (Test #1):
Counter Weight = End of the "Counter Balance Arm" (*)
Anti-backlash = 0 (all axis)
OTA = GSO RC8 (with diagonal, eyepiece & finderscope +/- 18 lbs)
Power = AC & External 12V battery
(*) The same happens when I put a second telescope (William Optics ZenithStar 66 SD APO with all +/- 5 lbs) and with/without the Counter Weight in any position (I tried all options)
Do you have any suggestion?
Thanks in advance.
UPDATE:
I want to share the following:
A few minutes ago I made an alignment, with one star. If after that, I make the alignment with 2 stars, it almost never fails (I notice only a slight movement).
The failure only appears if I try to align with 2 stars right after turning the equipment on.
The shift does not seem to be so random, after all. If I try to align with 2 stars right after turning on, whenever I press Enter on the second star, it will shift almost upto the start position (I mean, the position before the adjustments made to center the object).
Anyway, I am planning to have the equipment returned for a checkup, but I thought that those details could be of interest.
References (Test #2):
Counter Weight = No
OTA = William Optics ZenithStar 66 SD APO with all +/- 5 lbs
