Saturn with home brew barlow - blimey!!!
3 replies to this topic
#1 Andy Taylor
Andy Taylor
    Twisted, but in a Good Way
Posted 28 March 2009 - 03:04 PM
Final run before a cloud bank came over...
I made a barlow from the optics from a Zeiss 2x Mutar from my 'ol parts bin. This is used as a "doubler" for a 10-100mm Zeiss Vario Sonnar motion picture lens. The original housing was trashed but the optics were perfect so...
I turned up a tube for it and had great success with Saturn.
So this last run I added another 2" extension and went for it...
This was very rough focus due to a very dim image and time was running out due to approaching clouds. I managed 975 frames before the image drifted too close to the edge of the ccd. Every setting had to be set to max to even see the image.
Captured in WXastrocapture on my Asus eepc straight to USB 8 gig memory stick.
Processed with Registax 5.
Meade DS102MAK (tweaked) Bresser mini GEM (heavily tweaked) Cheap 'n nasty RA drive (waiting to be tweaked) Phillips 840k with 900 firmware in optimised color mode.
WOW! Next time I'm going to take time to bracket focus.
Not bad for a cheap 4" Mak... :grin:
#2 Mert
Mert
Posted 29 March 2009 - 09:23 AM
Good shot Andy, great result.
With the equipment you used and made yourself this
is a really good result already!
Just a tip, try the bahtinov mask for focussing, but
don't forget to take it off after focus has been
reached, like I did in an imaging trial before :rainbow:
#3 Andy Taylor
Andy Taylor
Posted 29 March 2009 - 12:11 PM
Hmmm.. Kinda embarassing but I posted the wrong pic.:bigblush:
That one was +25% rescaled for processing... :foreheadslap:
This one is 1:1... still good I think.
As for the mask - I can get one laser cut, just a matter of finding time to generate one for my scope.
#4 Mert
Mert
Posted 31 March 2009 - 11:54 AM
Why don't you print it out on a laser
printer and glue it onto some plastic
folder.
Then with a sharp cutter, cut it out
and done, that will work for sure!
