question regarding CG5 AS-GT mount
3 replies to this topic
#1 vicop408
vicop408
Posted 01 April 2009 - 03:13 PM
I recently purchased a CG5 mount with go-to. My question is when I'm using the hand-controller, do I leave the RA and the DEC lock levers engaged(tightened)? I looked at the manual front-to-back and could not find the answer. Thanks.
---vic
#2 mclewis1
mclewis1
    Thread Killer
Posted 01 April 2009 - 03:19 PM
Yes Vic, they need to be tight to keep the motors and encoders engaged, if you loosen them you'll mess up the electronics and the mount won't be able to go to accurately.
#3 vicop408
vicop408
Posted 01 April 2009 - 03:22 PM
Got it. Thanks for the quick response!!!
#4 hydrogia
hydrogia
Posted 01 April 2009 - 07:52 PM
Don't tighten too much, though!
I used to tighten the heck out of the clutches to make sure that they wouldn't move, and after a while, the little piece of plastic that pushes into the shaft became smooshed. It just led to me having to tighten even more for the same effect.
Also be careful not to tighten the RA clutch too much or it will dig into the plastic housing of the RA motor during a slew. I made that mistake and didn't find out until my motors started to really whine about it in the middle of an east-west transition.
