Gemini and warm restart...
4 replies to this topic
#1 David Pavlich
David Pavlich
    Transmographied
Posted 02 April 2009 - 04:19 PM
I usually do a warm restart, however, when I slew to an object and if's off a little, I center it, but when I goto "Align Telescope" the only option is to Sync. Question: If I Sync it remembering that it's a warm restart, will it cancel my pointing model?
The reason I ask is that on a Cold Start, anytime you select sync, it's like starting over.
Thanks! David
#2 f29pc
f29pc
Posted 02 April 2009 - 05:08 PM
David, after a warm restart and pressing Sync should only sync the current model to where the scope is. When you do a cold start it wipes out any modeling and starts over.
Paul
#3 David Pavlich
David Pavlich
    Transmographied
Posted 02 April 2009 - 05:20 PM
Thanks, Paul! I figured that was the case, but I didn't want to have to do the alignment over.
David
#4 HunterofPhotons
HunterofPhotons
Posted 03 April 2009 - 10:50 AM
.... I figured that was the case, but I didn't want to have to do the alignment over.....David
Don't worry about losing a model. A flawed model is worse than no model. I would be concerned about losing a perfect model like Heidi Klum, but who wouldn't?
I used to image at long focal lengths with a Gemini. It only took me 5 minutes to make a new model that would center objects in the test image. The quality of your 'synchs' and 'additional aligns' is important, though. Use crosshairs to center your stars and a 5 star model will get you off and running. Doing a few aligns at the end of a night out will give you a widely-spaced model which, I believe, helps refine the model's accuracy.
dan
#5 David Pavlich
David Pavlich
    Transmographied
Posted 03 April 2009 - 05:09 PM
dan
That's exaclty what I do. That's why I like the Gemini. Last night, I did the Sync thing and it was fine. As it turns out, M64 was only off by the tiniest bit from center. I use a reticle ep for my star alignments. It's the only way. :grin:
David
