GIRO Mini sansone or Giro mini standard ???
2 replies to this topic
#1 lmgtz_doc
lmgtz_doc
Posted 03 April 2009 - 09:52 AM
Does any one has a Giro mini ?? If have it please post a n image to see the size, any comment about it , thanks.
Luis Gtz.
#2 Jim7728
Jim7728
Posted 03 April 2009 - 10:23 AM
I had the Giro mini, now being used by lady friend. ;)
It's compact, well built and has very smooth motions. I recommend a tripod with an elevating column for clearing tripod legs when pointing up.
Mini is good for ota's <7lbs. Over that will need,imo, a counterweight bar on the opposite side of where scope is mounted , else azimuth motion will be very stiff.
Here it is mounted on a Bogan 3026 and WO-66mm. I did have some issues balancing the 66 due to the ota's short length, but solved with a longer dovetail bar.
#3 lmgtz_doc
lmgtz_doc
Posted 04 April 2009 - 07:34 PM
Thanks Jim, I am thinking to buy a Giro Mini " sansone " that has the double of payload and with a counterweight ( means another telescopes and extra arm ) it may works with my FLT 98 mm aluminium version.
thanks.................Luis Gtz.
