Thickness of Aluminum Pier Plate
11 replies to this topic
#1 stuper
stuper
Posted 12 April 2009 - 05:42 PM
I'm planning to make a 12-inch diameter concrete pier for my 10" LX200. If I use aluminum for the pier plate, how thick should the aluminum be?
#2 Telescopeman54
Telescopeman54
    Vendor - Trapezium Telescopes & Services, LLC.
Posted 12 April 2009 - 06:07 PM
1/2" to 3/4" should be more than enough.
Steve
#3 stuper
stuper
Posted 12 April 2009 - 06:49 PM
I can save a few bucks with 3/8". Would that be thick enough?
#4 fetoma
fetoma
Posted 12 April 2009 - 08:07 PM
I would go for an inch thick. 3/8 is too thin. How much weight is the scope and mount together? This is what I used but you can go smaller in diameter:
http://www.speedymet...m-extruded.aspx
#5 DeanS
DeanS
Posted 12 April 2009 - 08:15 PM
I did a 1/2" plate that was 12" x 12" and it was too thin. 3/4" was better, 1" would be even better.
Also you may have to tap some threads in it and 1/2" would be more difficult to do.
#6 Strgazr27
Strgazr27
Posted 12 April 2009 - 09:14 PM
Mine is 1" X 12" X 12" 7075 Plate :) Plenty strong enough.....
#7 stuper
stuper
Posted 14 April 2009 - 07:14 PM
Sorry, been away for a while. Thanks for the tips. I didn't realize extruded rod came in such large diameters. I was pricing it as flat plat, which is more expensive. I will get a 1" thick piece of 8" or 9" diameter rod. Is 6061-T6 sufficient, or should I get 6262-T6511 or 7075-T651 or something else?
#8 fetoma
fetoma
Posted 14 April 2009 - 07:32 PM
It all depends on what $$$ you want to spend. I used 6061, but 7075 is better, but more expensive.
#9 stuper
stuper
Posted 15 April 2009 - 10:55 AM
Frank, does yours made from 6061 work OK? How thick is it? What kind of scope/mount do you have on it?
#10 fetoma
fetoma
Posted 15 April 2009 - 11:35 AM
Mine is 1" thick 6061 with a CGE on top. Works just fine.
http://www.cloudynig.../fpart/all/vc/1
#11 DrBuck
DrBuck
Posted 17 April 2009 - 07:32 PM
My CGE is mounted on a one inch aluminum adapter plate that I had machined to fit the CGE base. I then drilled and tapped it to fit the screws and bolted it to my 3/4 inch stainless steel leveling plate with a 1/2 inch bolt.
#12 Hank w
Hank w
Posted 17 April 2009 - 08:18 PM
Try this link " http://www.sandsmach...com/alumweb.htm "best price and perfect for a pier plate. I've made several with there product
Hank
