AZ4 OR STELLARVUE M1 ?
5 replies to this topic
#1 Onslowe
Onslowe
Posted 13 April 2009 - 09:50 AM
Has anybody tried the new Skywatcher AZ 4 or Stellarvue M1 alt/az mounts. I have seen a couple of reports on the M1 head, it seems high quality and I have a suitable tripod but £160 is a fair amount of cash for a tripod head, is it worth it? The scope would be a 80mm refractor and PST (bracket reqd) and its for grab and go. Is it easy to use heads without a slow motion control? I cannot afford the like of the WO Easytouch or SkyTee etc.
Thanks for any advice.
Martin
#2 mathteacher
mathteacher
Posted 13 April 2009 - 10:02 AM
Here is a review of a 102mm refractor on AZ4
LINK
#3 Starlighter
Starlighter
Posted 13 April 2009 - 11:59 AM
I've seen and played with the AZ4 at two local Skywatcher dealers. Nice mount. Very stable and it can be locked down so when a heavy eyepiece is changed out, the scope won't suddenly pitch forward. And here in the US at $250, it's a good deal. Don't know what it runs in the UK. The tripod has tubular steel legs which makes for great stability. And I like the panning handle.
I cannot comment on the SV M1 since I've never seen or operated one.
#4 ngc2289
ngc2289
Posted 13 April 2009 - 12:35 PM
I used the M1 with a 80mm f/6 scope I owned. The mount was very smooth in operation. I was able to track Mars at around 150X with no problem. I did have the handle though which does cost extra. I don't own any big and heavy eyepieces. So I don't know how the mount would handle changing out big and heavy eyepieces. Hope this helps. :)
#5 Scott Beith
Scott Beith
    SRF
Posted 14 April 2009 - 09:23 AM
http://www.cloudynig...hp?item_id=1804
Some thoughts on the M1 with an 80mm scope.
#6 Bradley B
Bradley B
Posted 14 April 2009 - 02:53 PM
I have no experience with the AZ4, but can tell you from experience with the M1 that its ability to track was somewhat disappointing for me: push to an object, let go and the mount settles to somewhere between where you were and where you want to be, kind of a stick and grab situation.
