ASGT Cg5 Alignment Question
3 replies to this topic
#1 Wave Vector
Wave Vector
Posted 16 April 2009 - 01:58 PM
Some objects are not in the center of the eyepiece when I use GOTO. if I use the hand controller to bring the object to center, do I have to preform another alignment?
#2 rmollise
Posted 16 April 2009 - 02:10 PM
No. You would only have to realign if you undid the locks and moved the scope manually. A number of things can help with "off" go-tos, but one which will do the most good is always using only the UP and RIGHT keys when doing final centering of the alignment stars.
#3 Wave Vector
Wave Vector
Posted 16 April 2009 - 02:31 PM
Thank you Mr. Mollise
I really needed that information. I am going out tonight, it is first clear night in a number weeks :jump:
#4 Fred1
Fred1
Posted 16 April 2009 - 04:10 PM
Also, be sure that the mount has completed its GOTO. Often it will appear that the mount has stopped, but if you check the LCD on the hand control you will see a rotating image in the upper right corner, which indicates the mount is still moving. Wait until the rotating image disappears before trying to precisely center with the UP and RIGHT keys as Uncle Rod says.
