CGE, EQAlign, and questions...
3 replies to this topic
#1 tjensen
tjensen
Posted 20 April 2009 - 08:00 AM
Hi all,
Well I finally got my pier, so I spent the weekend installing it and the CGE. Naturally, I ran into a few snags...
First question... the new CGE version allows for polar alignment on any star. Yet, when I adjust the alt, or az, the star seems to move in the same plane... hence no centering occurs. Any idea why? ( I was using Arcturus)
Second question... I tried EQAlign and the program says that I need ASCOM 2008 installed and then crashes. I have ASCOM 2008 installed, so it seems that EQAlign isn't recognizing it... anyone had this problem or know of a fix?
Cheers
Tim
#2 rmollise
Posted 20 April 2009 - 08:34 AM
Hi all,
Cheers
Tim
This is an inevitable problem when trying to center a star to East or West using the alt/az adjusters. Make it easy on yourself and use a star to the South...or just good, old Polaris.
#3 tjensen
tjensen
Posted 20 April 2009 - 08:41 AM
I got thinking about that after the clouds moved in... Polaris is blocked by trees, so I'll shift to the south next time.
Cheers
T
#4 tjugo
tjugo
Posted 01 June 2009 - 03:22 PM
Hi Tim,
I had the same issue with eqalign.
To fix the ASCOM issue I installed the ASCOM .NET Client Toolkit Update from here:
http://ascom-standar...formUpdates.htm
The direct link is:
http://download.asco...ate(1.0.5a).exe
Jose
