CG5 -ASGT Index Marks
5 replies to this topic
#1 wsuriano
wsuriano
Posted 23 April 2009 - 03:11 PM
I just received a CG5-ASGT and set it up indoors just to make sure everyting was there and worked. So far, so good. One questions though. I can tell already that I am going to lose the index stickers before too long. They're not stuck on very well. What have you all done to preserve the RA and Dec index marks?
Bill
#2 rmollise
Posted 23 April 2009 - 05:25 PM
Bill
Mine ain't fallen off over four years of use. If they look like they are gonna depart, though, a little glue will hold 'em. Superglue or your choice.
#3 Luigi
Luigi
Posted 24 April 2009 - 06:53 AM
The stickers aren't always accurately placed anyway. The main thing is to align the dec axis in the vertical plane with the OTA parallel to the RA axis. The only thing this does is make going to the first alignment stars more accurate.
#4 rmollise
Posted 24 April 2009 - 08:50 AM
True, but what really matters even more than that is just starting from the same position each and every single time.
#5 donsinger1
donsinger1
Posted 24 April 2009 - 09:24 AM
I agree, essentially make your own in the counterweight down position for the shaft and point north, mark the DEC and RA axis with a sharpie and off you go.
In fact, I have found that few of such marks, even latitude scales, are accurate. I have polar aligned my CGEM many times, including a good Drift Alignment, and my latitude scale shows me at 43.5deg N, not the 45.3 I am actually at in Portland.
#6 Fred1
Fred1
Posted 25 April 2009 - 12:40 AM
Follow Luigi's advice above, then put a piece of yellow electrical tape across the joining line and slice through the line with a razor. Perfect index alignment everytime.
