LXD75 Proper dual mount
8 replies to this topic
#1 Mittag55
Mittag55
Posted 24 April 2009 - 09:15 AM
I have just ordered a new mount and plan for now using it for my 130 mm reflector and adding a 80 or 90 mm guide/imaging refractor on it...is there any proper physics or distribution of weights i should know about or can i just pair up the scope rings and balance the rig out.Any help or point to the right info would be helpfull.
:question:
#2 Jerry3672
Jerry3672
    Vendor - Quantum Astronomy Products
Posted 24 April 2009 - 12:46 PM
The best tip for that LXD75 is to have your mount a little (East) heavy. The gears always should climb a bit. If you are balanced perfectly, then the backlash will allow the mount to bounce back and forth and you will have long stars.
I have my 90mm guide scope on top of my 10 inch SN reflector. I had to add a custom weight to the end of the shaft, but you won't have that issue with a 130mm scope.
#3 Mittag55
Mittag55
Posted 24 April 2009 - 04:21 PM
Thanks for the input...West heavy it will be.
#4 EricJD
EricJD
Posted 24 April 2009 - 05:37 PM
Eh mate, don't you mean East heavy so that as it rotates it's always pressing against the gears? I always balance east heavy and get nice round stars at 6 minutes on my LXD75.
#5 jgraham
jgraham
Posted 24 April 2009 - 09:42 PM
The LXD75 should handle that easily. Mine carries an LXD75 SN6 with a 90mm MCT as a guide scope. I usually balance mine evenly on both axis, then shift a small counter weight to make it just a tad east-heavy so it climbs against the load. Also, while guiding I use either north-only or south-only on the dec.
My standard imaging kit...
#6 Jerry3672
Jerry3672
Posted 25 April 2009 - 11:55 AM
Opps- You are corerct- East heavy so the gears are climbing.
#7 Jerry3672
Jerry3672
Posted 25 April 2009 - 11:56 AM
Take note of where John has his camera. I have seen his image before and use his Idea to keep the mass in the correct place. This is the best place for the camera
#8 Mittag55
Mittag55
Posted 25 April 2009 - 06:08 PM
Thanks...this is why i read the posts...lots of neat tricks and tips to keep me out of trouble. :bow:
#9 Mittag55
Mittag55
Posted 29 April 2009 - 04:48 PM
Well i have a 105 mm Antares coming to go on my mount so all is well. i will try it balanced at first to see how smooth the mount is and ofset East if it needs sit...Thanks all for the help
