Atlas Tripod Issue: Repair Suggestions?
8 replies to this topic
#1 jrbarnett
Posted 30 April 2009 - 08:42 PM
Hi. Last Saturday I noticed that one of the black, pointy aluminum feet on my Atlas tripod was loose. I could rotate it on the stainless steel tripod leg. I'm assuming these fittings are glued in place. What sort of adhesive ought I to use to re-secure it? (Bonding cast aluminum to stainless steel.)
- Jim
#2 Scott Beith
Scott Beith
    SRF
Posted 30 April 2009 - 09:00 PM
jbweld bonds everything.
#3 Sky Captain
Sky Captain
    Metal Whisperer
Posted 30 April 2009 - 11:35 PM
JB Weld rocks! Can't go wrong with that stuff.
#4 jrbarnett
Posted 01 May 2009 - 12:59 PM
Thanks Gents, JB Weld is is then.
It's raining today (and all weekend) so I may as well fix 'er up.
#5 jim molinari
jim molinari
Posted 01 May 2009 - 03:55 PM
Did you check to see if there was a set-screw to tighten it?
#6 Telescopeman54
Telescopeman54
    Vendor - Trapezium Telescopes & Services, LLC.
Posted 01 May 2009 - 04:21 PM
I'd use contact cement because if I ever needed to remove the foot to service the leg it could be done. JB weld will not allow you to do that. Once it's on, it's on for good!
Steve
#7 Sky Captain
Sky Captain
    Metal Whisperer
Posted 02 May 2009 - 08:34 AM
Steve
Actually, JB Welded pieces can be removed if needed. I have had to do it several times over the years. Of course it does depend on the media being joined together. In this case both are metal...this removal can be done by heating both pieces with a propane torch. It depends on how much JB was used too, but generaly just 250 to 350 degrees will soften the JB product. It will become soft and both pieces will come apart.
Of course you will need to wear thick leather gloves so as not to burn yourself and \ or a clamping devise to hold each piece.
#8 rmollise
Posted 02 May 2009 - 10:23 AM
There are no screws. All the Celestron/Synta leg tips are glued on and will fall off eventually. I used Superglue, but JB is prob'ly better.
#9 StarStuff1
StarStuff1
Posted 03 May 2009 - 09:18 AM
I haven't had good luck with Superglue or JB. Better luck with epoxy. Just about my favorite adhesive for non-woodworking use is Goop. It will bond most anything to anything. Parts can be separated by wicking some acetone on the joint-the Goop will temporarily soften. Do NOT use Goop on telescope mirrors.
