CGE Pro recall
8 replies to this topic
#1 Alph
Alph
Posted 06 May 2009 - 02:22 PM
It apears that Celestron is recalling the CGE Pro's. Does anyone know what's the reason for the recall?
#2 gosavich
gosavich
Posted 06 May 2009 - 02:49 PM
I saw a post on Astronomy.com forums indicating that it is due to the first run of mounts being assembled with the wrong type/strength of locktite. That's totally unconfirmed however. I don't even know if it would make sense.
#3 blueman
blueman
    Photon Catcher
Posted 06 May 2009 - 11:07 PM
That is a shame, but I have never been one to want to buy something when it is first released. Hopefully they will fix whatever it is in a short time.
Blueman
#4 Telescopeman54
Telescopeman54
    Vendor - Trapezium Telescopes & Services, LLC.
Posted 06 May 2009 - 11:23 PM
The wrong type of Locktite? I think that's stretching things a bit.
Steve
#5 Charlie Hein
Charlie Hein
Posted 07 May 2009 - 06:08 AM
Hi Alph, do you have a link or can you point us to a source? I'm sure folks would like to know...
Charlie
#6 Charlie Hein
Charlie Hein
Posted 07 May 2009 - 06:13 AM
Here's the Astronomy.com thread. Looking to see if I can find an official statement from Celestron... I think I'll also ask Mike to see what he knows about it.
EDIT: Posted a PM to Mike and an email to Celestron.
#7 JerryWise
JerryWise
Posted 07 May 2009 - 07:10 AM
I use Loctite a lot on various jerryrigged projects. Not so much for locking down bolts but to maintain a precise position of the nut on the bolt or threaded rod. Situations where a lock washer will not work. The only choices are Loctite or the cap nuts with nylon insert. Loctite is often best when the adjustment nut/shaft does not tolerate the force needed to run a nylon insert nut down the shaft to proper position. Speculation only but it likely has something to do with precise adjustment of shaft end play. A good area to use the right Loctite. Commendable of Celestron recalling these to make sure.
#8 Astronomics
Astronomics
    Vendor: Astronomics
Posted 07 May 2009 - 11:29 AM
The "recall" on the Pro mount is due to a locktite issue. The wrong spec locktite was used. They don't think it will cause an issue, but they want to make it right. That is the whole reason for the "recall".
#9 vegasMike
vegasMike
Posted 08 May 2009 - 12:19 PM
ill take a lock'loose mount for a discount :)
