First checkout of my new IPI-262 Mount
32 replies to this topic
#1 karlz
karlz
Posted 08 May 2009 - 05:06 AM
I'm one of the two "early adopters" for Kevin's first run of the IPI-262 mount. There were some minor issues that cropped-up but Kevin was great in helping to work thru everything...This is one BIG mount; it's rated for 100# but I bet it would easily handle the same load as the AP1200.
The eq. head (RA+DEC) weighs-in at a hefty 93# (w/o counter-weight shaft), and the only thing that makes it managable is that it breaks into two ~45# parts.
Uncorrected PE with this mount is running +/- 1.5" peak-to-peak -- Following the pictures, I've included some screen shots from one of the PE data runs that I performed tonight; this data covers approx. 2 1/2 worm periods but longer runs show similar results.
Here're are a few pictures of the mount with my C8 and SV AT-1010 guide scope...
#2 karlz
karlz
Posted 08 May 2009 - 05:10 AM
Another pic...
#3 karlz
karlz
Posted 08 May 2009 - 05:12 AM
Yet another pic...
#4 karlz
karlz
Posted 08 May 2009 - 05:20 AM
Ok, last pic...
#5 karlz
karlz
Posted 08 May 2009 - 05:44 AM
After a little work with photoshop, I was able to convert the screen capture of the PE Analysis into a jpeg so it can be displayed....
#6 karlz
karlz
Posted 08 May 2009 - 05:53 AM
Mount PEC curve...
#7 karlz
karlz
Posted 08 May 2009 - 05:54 AM
Lastly, mount freq. analysis...
#8 nik hodges
nik hodges
Posted 08 May 2009 - 09:53 AM
looks very good, makes the C8 look microscopic -)
#9 zjc26138
zjc26138
    Loved By All
Posted 08 May 2009 - 10:50 AM
Great looking mount!
#10 David Pavlich
David Pavlich
    Transmographied
Posted 08 May 2009 - 12:15 PM
As a mount junkie, I can tell you that this sure looks like a nice piece of hardware. I hope you keep us posted about the continued performance of the mount.
Edit: You really do need to get a C14 on that thing...really!
David
#11 antilles72
antilles72
Posted 08 May 2009 - 12:34 PM
Wow!!! That is some serious mount. I am with David on this. you NEED to put a 14" on there.
#12 BWAZ
BWAZ
Posted 08 May 2009 - 01:26 PM
Great mount, the uncorrected PE sounds very high end. Congratulations!
#13 karlz
karlz
Posted 08 May 2009 - 01:34 PM
Yup, it's way too big for the C8; I had to add the AT-1010 just so I could balance the load properly. You should've seen it when I just had the little 80mm refractor on it...it was too heavy to use without the counterweight shaft installed and too light to use with it. ;)
I have a large refractor coming later this month, so that should take care of the current telescope/mount mismatch.
Karl
#14 karlz
karlz
Posted 08 May 2009 - 01:45 PM
That PE isn't corrected...no PEC, no guiding, nada. Just letting the drive run while collecting data with my webcam -- The FS2 Controller supports PEC, but the data doesn't persist across power-cycles so I don't use it.
I've done 3 independent runs now to confirm the results, because I didn't believe them at first. All the runs confirmed that uncorrected PE for this mount is <+/-2" peak-to-peak...Needless to say, I'm very happy with that result. :cool:
#15 BWAZ
BWAZ
Posted 08 May 2009 - 05:26 PM
I did mean "uncorrected", again, an impressive number. :waytogo:
#16 jouster
jouster
Posted 12 May 2009 - 12:07 PM
Some more pics would be great!
#17 JerryWise
JerryWise
Posted 12 May 2009 - 02:26 PM
Really nice setup. Those are fantastic numbers. not much to autoguide when that mount locks onto the pole.
#18 blueman
blueman
    Photon Catcher
Posted 12 May 2009 - 03:15 PM
What a beautiful beast, the performance looks better than an AP1200 really. That is a real keeper.
Blueman
#19 hersey0308
hersey0308
Posted 13 May 2009 - 08:37 PM
i would like to have this mount in the observatory and one in the living room so i could look at them all the time. the nighthawk adds a stylish elegance.
david
#20 karlz
karlz
Posted 14 May 2009 - 02:29 AM
Thanks for the complements! I just took some more pictures and I'll get them posted tomorrow. Cheers
#21 lineman_16735
lineman_16735
    Tak-o-holic
Posted 14 May 2009 - 11:18 PM
Great mount, and PE numbers. I met Kevin at NEAF. He really seems to love what he is doing. His mounts are very, very well built. If he would have been making mounts about a year ago I would have purchased one of them.
#22 karlz
karlz
Posted 15 May 2009 - 12:58 AM
More pics...
#23 karlz
karlz
Posted 15 May 2009 - 01:05 AM
More Pics 2...
#24 karlz
karlz
Posted 15 May 2009 - 01:06 AM
More Pics 3...
#25 karlz
karlz
Posted 15 May 2009 - 01:08 AM
More Pics 4...
