CG-5GT gps question
4 replies to this topic
#1 pizzaboy71
pizzaboy71
Posted 12 May 2009 - 09:01 PM
How helpful is this gps add on ? does it help the mount track any better ?
#2 jrcrilly
jrcrilly
    Refractor wienie no more
Posted 12 May 2009 - 09:08 PM
No. Its only function is to enter date, time, and location information. The mount will track precisely the same even if that data is not entered at all.
#3 Domerman
Domerman
    Just Lucky, I Guess.
Posted 13 May 2009 - 12:02 AM
The time, date and location don't effect the tracking? I was unaware of this. Then what is the point of entering these things into the hand controller?
#4 jrcrilly
jrcrilly
Posted 13 May 2009 - 12:07 AM
They aid in star alignment, which is required for goto operation.
#5 WadeH237
WadeH237
Posted 13 May 2009 - 09:47 AM
Specifically, they help the mount to know where to point to find the initial alignment stars. The date and time information is also necessary to find solar system objects.
The location, date and time information is not needed for doing goto on deep sky objects and it's not needed for tracking. Tracking accuracy is solely determined by the polar alignment. When I use my PST during the day, I often just set the mount up pointed north and turn it on and pick quick alignment. It will track the sun just fine that way.
You can put totally bogus information in as the location, date and time if you want to. When the mount points to the first alignment star, it will be way off - but if you go ahead and center the alignment stars anyway, the mount will point to anything except solar system objects.
Another piece of trivia: The polar alignment accuracy does not affect goto performance. You can set the mount up in a pretty random way and do two alignment stars. When you do a goto, it will hit the target. But if polar alignment is way off, tracking will not be good.
-Wade
