Alt-az mount warning
10 replies to this topic
#1 brianb11213
brianb11213
Posted 13 May 2009 - 05:59 AM
Nearly had a nasty accident with my WO FLT 110 / EZ Touch last night. I was carrying it "over my shoulder" to a better location to see an object low in the east, the tube swung round & clouted me on the head hard enough for me to see many unfamiliar constellations, in fact I was stunned for a few minutes and could easily have dropped the whole caboodle.
No damage to scope or mount, only a bump on the head which would probably have been worse if I hadn't been wearing a nice thick wollen beanie.
Must remember to check that the axes are tightened down before carrying the scope this way in the future.
#2 Chase McNiss
Chase McNiss
Posted 13 May 2009 - 06:37 AM
Brian,
Glad you didn't drop anything and that you are OK but wondering if you came up with any names for the constellations you saw. Thanks for the heads up. :smirk:
C
#3 Starlighter
Starlighter
Posted 13 May 2009 - 11:27 AM
The exact same thing happened to me only with my Portamount with the SV102ED mounted.
I had loosened the tension on the azimuth since that scope needed it. As I picked it up, the scope swung around and clobbered me good! I though I was seeing stars only not through the scope! :tonofbricks:
Fortunately, I was able to set the rig down before I nearly fell down. I ended up with a nice bump on my noggin.
So people, like Brian said, be careful when you pick up an AZ mount with the scope still attached, especially if it's a heavier one. Make sure the tension is secure.
#4 antilles72
antilles72
Posted 13 May 2009 - 11:53 AM
Thanks for the heads up as well. I always keep it tightened anyway, but I am human...
#5 GShaffer
GShaffer
Posted 13 May 2009 - 03:46 PM
Better yet.....remove the OTA and carry them independantly..... your noggin and perhaps ultimately your pocket book will thank you :)
#6 zjc26138
zjc26138
    Loved By All
Posted 13 May 2009 - 05:09 PM
Sorry about the bump on your head, but at least your scope and mount are ok. :)
I did the same thing with my AR5 and Skyview Pro Alt-Az, I didn't tighten the tension while moving the set-up and the AR5 swung around and hit me in the head. :foreheadslap: I survived and so did my equipment. :waytogo:
#7 Starlighter
Starlighter
Well, the problem for me is I sometimes only have to move the mount several feet. That's because the object I'm viewing has gone behind the limb of a tree. To go to the effort of removing the scope each time would make it a royal pain.
#8 zjc26138
zjc26138
    Loved By All
Posted 13 May 2009 - 05:16 PM
Same for me. :smirk:
#9 GShaffer
GShaffer
Posted 13 May 2009 - 05:28 PM
While I understand your point..... 10 feet or 1000 feet doesnt really matter if you knock yourself out or do major damage to the equipment as a result.....but then all life is a gamble :)
#10 Jim7728
Jim7728
Posted 13 May 2009 - 06:22 PM
OUCH!
I took a good whack to the head when the 11lb weight attached to my Giro swung around while I was bringing it back into the house.
Luckily I have a thick head...luckily I have a brick head...
:grin:
The bar counterweight now rests on my shoulder whenever I carry the tripod around. ;)
#11 brianb11213
brianb11213
Posted 14 May 2009 - 04:09 AM
The Lumpy Head, The Wobbly Knees and The Compensation Lawyer ;)
Seriously, though, it looks as though I'm not the only one to have had this particular accident ... if I've helped anyone else avoid similar, or worse, I'm happy.
