NEQ6 PRO
17 replies to this topic
#1 midnightblue
midnightblue
Posted 13 May 2009 - 10:58 AM
hi guys is the NEQ6 the same as the HEQ6 I've just had delivered the NEQ6 but when i ordered the mount it was HEQ6 have i been sent the wrong mount :confused: or is it just a typing error on a website
#2 rmollise
Posted 13 May 2009 - 01:51 PM
The way _I_ understand it, the NEQ6 has a Losmandy D compatible dovetail and a longer counterweight shaft. Never heard of an HEQ6...
#3 midnightblue
midnightblue
Posted 13 May 2009 - 02:49 PM
:jump: typing error i found a review on this forum claiming HEQ6 there no such mount so the NEQ6 pro is the big brother of the HEQ5 pro :foreheadslap: thanks now i can play with my new toy
#4 astro_baby
astro_baby
Posted 16 May 2009 - 04:01 PM
As far as I know theres an HEQ5, EQ6 and NEQ6 ( they all have the options of being GoTo)
As far as I know the NEQ6 was a beefed up EQ6 with a longer counterweight bar for the Synta/Sky-Watcher 300 scope. Never seen one for sale as s standalone unit in the UK.
#5 midnightblue
midnightblue
Posted 16 May 2009 - 05:24 PM
i thought they sent me the wrong one i asked the guy that
served me for HEQ6 because i seen it advertised on the net
as HEQ6 and later found out there was no HEQ6 so i assumed
it was a typing error and the EQ6 PRO is called NEQ6 as
you have now pointed out the correct order HEQ5 EQ6 NEQ6
PROs will the NEQ6 have the same pointing tracking
accuracy as the EQ6 :o now i am worried purchased from
telescope planet £950 it came direct from optical vision
as telescope planet was out of stock and now looking at
the invoice it's a EQ6 PRO SKYSCAN GOTO SUPER HEAVY DUTY
EQUATORIAL MOUNT should i be worried :mad: :( :confused:
:confused:
#6 Kenny2004
Kenny2004
    Vendor - Icodome
Posted 17 May 2009 - 09:40 AM
I thought the NEQ6 is a step up from the EQ6, so you're getting a better mount. I"d say call the manufacturer of the mount to sort all this out and confirm.
#7 RogerRZ
RogerRZ
    Whatta you lookin' at?
Posted 17 May 2009 - 05:34 PM
This is correct. In addition, the NEQ6 has the dovetail saddle that permits it to mate to a Losmandy D series plate.
My EQ6 pro has been outfitted with an ADM saddle that, except for the longer CW shaft (which I don't need for my current setup), makes it identical to the NEQ6...
#8 astro_baby
astro_baby
Posted 18 May 2009 - 12:33 PM
Well iyf you wanted an EQ6 with GoTo thats what you have there. The price is cheaper if you shop around. I have seen them for about £890 in the UK.
I dont think anyone sell sand NEQ6 because its adapted for the biggest SkyWatcher scope.
THe bits to create an NEQ6 from an EQ6 (longer weight bar and different saddle) are all available as extras anyway.
What sort of scope will you be mounting on it ?
#9 midnightblue
midnightblue
Posted 18 May 2009 - 01:56 PM
for the moment c6 and equinox 66 I'm in the process of saving
all my pennies for a c9 or the sky-watcher equinox 120 that's
what i got my mind set on until i start reading the great
reviews here on CN which may sway me to something else
so its an eq6 with added extras and N in front
#10 rdegoutier
rdegoutier
Posted 18 May 2009 - 04:00 PM
I have the NEQ6, which the box says is an EQ6 Pro. Nice mount, very few drawbacks from my perspective except:
1. Light in Polarfinder is too bright and turns on with scope. I added a 100K ohm pot with on/off to solve this.
2. CW shaft is still not quite long enough. I added a 3 inch extension which lets me balance my MAK Newt 190 loaded with camera and guide scope.
3. Should ship with three 11 lb weights, not two. I ordered another weight.
Other than that, a wonderful mount. Dead accurate tracking.
#11 midnightblue
midnightblue
Posted 18 May 2009 - 04:31 PM
in the hand controller there is a utility to turn down the brightness of the polar scope red light :cool:
#12 midnightblue
midnightblue
Posted 18 May 2009 - 04:43 PM
my hand control ver.03.23
directions
setup mode >press enter
handset settings >press enter
scroll to polar-scope led
0% off full bright 100% goes up in 2% increments
#13 rdegoutier
rdegoutier
Posted 18 May 2009 - 05:26 PM
Oh, ahah..... :foreheadslap:
I thought that was just for the HC brightness.
Oh well, it was fun putting the pot in.
#14 Coromandel
Coromandel
Posted 19 May 2009 - 02:17 AM
directions
A friend looks after the astro kit for the school his kids attend and they have at least one EQ6 Pro. My friend hates the bright LED so when I told him about the handset fix he was sceptical because he's tried everything already but he went to the school to try this anyway.
Over the phone he told me that the handset has the following menus under "Setup Mode/Handset Settings":
*LCD Contrast
*LCD Backlight
*LED Backlight
*Beep Volume
Whatever the "LED Backlight" setting does, my mate said it doesn't alter the brightness of the polar scope LED at all. The firmware version on the one he checked out is 3.24.
Next week he will do the resistor mod too.
#15 midnightblue
midnightblue
Posted 19 May 2009 - 06:54 AM
works fine on my mine
#16 midnightblue
midnightblue
Posted 19 May 2009 - 07:07 AM
its the :POLAR SCOPE LED: he should be looking for
the :LED BACKLIGHT: is for the hand controller buttons
#17 rdegoutier
rdegoutier
Posted 19 May 2009 - 11:21 AM
...Over the phone he told me that the handset has the following menus under "Setup Mode/Handset Settings":
*LCD Contrast
*LCD Backlight
*LED Backlight
*Beep Volume
So after the revelation from Midnightblue, I went and checked, and sure enough there is a setting for Polar Scope LED. I have V 3.24, so it should be there.
I think I still prefer my little adjustable pot as I don't have to fool around in the HC menu to get at it (self justification maybe? :p)
#18 Coromandel
Coromandel
Posted 19 May 2009 - 08:12 PM
I just spoke with my friend again and he confirmed the options I listed above are the only ones available on his handset.
The mounts are Skywatcher EQ6 Pros with version 3.24 of the firmware installed..
