Celestron ADM mount (cg5) for astrophotography
2 replies to this topic
#1 toobad
toobad
Posted 22 May 2009 - 12:17 AM
Hi.
I'm new to the forum and am from Croatia.
I'd like to buy used Celestron ADM mount with drive.
I think in US its called CG5.
This is the link.
http://www.teleskop-...info/p435_.html
Its in german, I'm affraid (but http://translate.google.com is good).
It has following drive
http://www.teleskop-...---2achsig.html
I'd like to use this combination with slr lenses for widefield photography, with ED80, and late perhaps with fast newton.
Is this combination any good for astrophotography? How long single exposures can I expect with it without trailing errors?
Thanks.
Tomislav
#2 rmollise
Posted 22 May 2009 - 08:21 AM
Hi.
This is the link.
Thanks.
Tomislav
This "ADM" is actually the good old Celestron (Synta made) non-go-to CG5. Could you use it for astrophotography? Sure. The main problem with these is usually the large amound of backlash in the declination gear-system. Good balance, close polar alignment, short f/l, maybe a little gear adjustment and this could be fine for your purposes.
#3 toobad
toobad
Posted 22 May 2009 - 10:27 AM
I suppose then I should save for something better.
Perhaps it would be enough for widefield...
