G11 Dec. Clutch Knob Problem
7 replies to this topic
#1 lowdog
lowdog
Posted 30 May 2009 - 08:56 PM
Tonight I was setting up for imaging session and when it came time to balance I could not loosen the dec. clutch knob. The dec. shaft will move when I try to loosen the knob but not freely enough for balancing. The knob is locked tight. Have any other G11 owners had a similar problem. Please let me know.
Jeff
#2 revans
revans
Posted 30 May 2009 - 09:23 PM
Why not cover a pipe wrench with a towel so as not to leave any marks behind, and force it loose? You could also use some WD40 spray sparingly and see what happens after a couple of hours...
Just my 2 cents... I just got my G11 a couple of days ago, so I'm not particular expert on this mount...
Rick Evans
#3 Charlie Hein
Charlie Hein
Posted 30 May 2009 - 10:33 PM
Jeff
I've not seen this. Do you have the upgrade clutch knobs?
#4 LLEEGE
LLEEGE
    True Blue
Posted 30 May 2009 - 10:52 PM
NO! Do not use a pipe wrench. Even with a towel it will mar the surface. If you must, try a strap wrench.
#5 lowdog
lowdog
Posted 30 May 2009 - 10:53 PM
Yes, I have the upgrade knob on both axis so I try not to tighten them to much.
#6 blueman
blueman
    Photon Catcher
Posted 31 May 2009 - 12:13 PM
Agreed, a pipe wrench is not the answer.
Have you grabbed the top saddle and tried to turn the knob?
Blueman
#7 lowdog
lowdog
Posted 31 May 2009 - 01:57 PM
I was finally able to loosen the knob today by tapping on one of the knob spokes with a rubber mallet. I don't know how it got so tight because I only hand tighten them. I store it in a square plastic tub on top 4 inches of foam padding. It lays on its side so maybe their was to much pressure on a spoke causing it to over tighten. Thanks to all who replied.
Jeff
#8 blueman
blueman
    Photon Catcher
Posted 31 May 2009 - 09:29 PM
Probably the temp difference between when you tightened it and tried to loosen it?
Blueman
