Jupiter and Io - June 1st
10 replies to this topic
#1 MvZ
MvZ
Posted 01 June 2009 - 12:31 PM
Hello All,
This morning I managed to get out of bed after only 2 hours of sleep to start imaging on Jupiter. When I saw Jupiter in the south-eastern sky through the trees, I just had to drag myself outside, and set up my equipment.
This time I tried something new; instead of my usual Ir-RGB method (using a color wecbam for RGB, and the b/w webcam for Ir), I wanted to only use my b/w webcam to get a color image.
Now there was only one problem; I don't have proper R,G,B filters, so I had to improvise a little.
For the red channel I used an astronomik planet pro Ir-pass filter (>742nm). For green a W21 orange filter, and for blue a W47 blue filter.
The b/w Toucam Pro II webcam was used on my 10" Starfinder telescope (with a 2x barlow) to get the images.
Io can be seen on the far left, and the GRS is starting to appear from the upper right.
Jupiter was at 19 degrees altitude when I shot this image. This year, it's maximum altitude at my location will be about 22 degrees.
#2 Jason H.
Jason H.
Posted 01 June 2009 - 12:58 PM
Nice going Emil! Those filter substitutions seem to have worked nicely for Jupiter (Io's a little red on my screen.) I visited your website, I like your animations and work, and all the more so because of your latitude!
Jason H.
#3 iceman
iceman
Posted 01 June 2009 - 01:53 PM
That's a very very nice image for the altitude! Heaps of detail.
The normally red areas are a bit yellow to me??
#4 LivingNDixie
LivingNDixie
    TSP Chowhound
Posted 01 June 2009 - 02:39 PM
Beautifull
#5 LivingNDixie
LivingNDixie
    TSP Chowhound
Beautifull
#6 isramirez
isramirez
Posted 01 June 2009 - 02:41 PM
Very nice Jupo! :)
#7 Mert
Mert
Posted 01 June 2009 - 05:12 PM
Great shot Emil, very sharp and detailed!
#8 MvZ
MvZ
Posted 01 June 2009 - 05:27 PM
Thank you all!
Mike, the difference between the red and green channels aren't very big, I think that is what is causing the yellowish look. Of course I could tune it more in Photoshop, but I didn't want to do that this time, because I wanted to see what these filters actually did.
I probably need a 'greener' filter for the green channel next time (instead of the orange filter). But still, there are colors in this image, and I'm very happy about that :)
Here's an even bigger version of the image (added another 25% in size, the original image was already resized to 133%)
#9 BrianFitz
BrianFitz
Posted 02 June 2009 - 03:31 AM
Stunning image!!
#10 suburbanskies
suburbanskies
Posted 02 June 2009 - 08:32 PM
Nice image - definitely worth the loss of 6 hours of sleep!
#11 Freddy WILLEMS
Freddy WILLEMS
Posted 02 June 2009 - 11:21 PM
Great capture for that low altitude !
