5" APO on a Teegul Lapides mount
3 replies to this topic
#1 CESDewar
CESDewar
    GorillAstronomer
Posted 01 June 2009 - 07:36 PM
Well, not any 5" APO - the Televue NP-127 which has long been recognized as one of the lightest 5" APO's around. The OTA itself only weighs about 16lbs - probably up to around 20lbs with diagonal, rings and a light-weight finder.
I have had the scope and mount for over a year, but never tested this combination because I assumed it would not be really usable. But recently, I put my Celestron C-8 on this combination and found it worked remarkably well and that topped out at about 21 lbs.
So I finally tried this combination tonight, including a 60mm SV finder. Now, mind you, I have one very fine tripod underneath the Teegul mount - a Gitzo 5530. Of course the tripod and mount together barely top 12lbs, so they are lighter than even the scope (!).
So how well does it work? Well I have to say I was a bit flabbergasted. Settling time after a really hard rap on the mount was 4-5 seconds. With vibration pads underneath the legs, this dropped to 2 seconds - now this is in more than slightly acceptable territory!. I was able to focus tightly at 264x on the moon in real-time - the small amount of vibration was not enough to interfere with finding a perfect focus. I was not expecting it to be this good, especially since there's only a very small Vixen rail. I use this mount/tripod extensively with my much shorter TMB92 and TMB0105/650, but it was definitely a revelation to find it working so well with this mount.
I usually use my DM-6 with the NP-127, and sure - that's a more stable combination. But I also like slow-motion controls and the far lighter weight of this mount (less than half the DM-6 and tall tripod I have it on.
And yes, this mount and tripod are pushing some $1,300 - so this is pricey combination, but then again the NP-127 wasn't exactly an inexpensive purchase :grin:. I had in fact tried the NP-127 last year on a Vixen PortaMount and the settling time on that was about 10 seconds - definitely into unacceptable territory.
The NP-127 is an unusually lightweight 5" APO - many scopes this size start around 20lbs. The NP-127 is not nearly as short though as its F5.2 FL might suggest, since it's a Petzval design and its main objective is probably closer to F10.
#2 NHRob
NHRob
Posted 01 June 2009 - 08:07 PM
Try that on a beefier tripod.
Rob
#3 The Ardent
The Ardent
Posted 01 June 2009 - 10:45 PM
The clearance Oberwerk tripod worked very well with my Teegul. Immediate compatibility. But Im only using a 60mm.
I dont have the part that holds dovetails, I cant try other scopes with this mount.
#4 BrianRG
BrianRG
    Skippy
Posted 01 June 2009 - 11:41 PM
Oh, is there a mount in that picture? I was drooling over the scope so much I didn't notice at first. :grin: :drool5:
Looks like some remarkable capacity in a lightweight mounting setup.
