1 pc big 203 mm F/6 Rich Field Refractor in USA
No replies to this topic
#1 APM M.Ludes
APM M.Ludes
    Vendor (APM Telescopes, Lunt Solar Systems, Lunt Engineering)
  • Restricted Vendors
Posted 06 June 2009 - 04:59 AM
Hello,
we have with APM now 1 pc big fast Rich Field Achromat ( 2 element airspacest fraunhofer achromat ) in stock, D=203 mm, f/1200 mm , with a longer focuse 2" eyepiece you will get to see the giant 2.25 degree FOV with contrast and pin point stars of a high quality 8" Refractor
We designed and manufactured this large APM achromat for those customers who love wide field viewing, but dislike reflective telescopes, such as the classical Newtonians and Dobsonians, and their spider vane diffraction spikes, need to be regularly collimated and cleaned as well as the often awkward observing position they can require. For those customers who love pin point stars on a black background, and who like to observe the many Milky Way objects, galaxies and nebula with a 2" wide field eyepiece, this scope may be for you. It is exceptional at viewing large, dim and diffuse objects with a 2" O-III filter. The owner of this scope can forget about cleaning mirrors or collimating again.
- Manufacturer: APM
- Model: Achro 203/1200
- Finder: 8 x 50
- Tubelength for observing: 50.39 inch
- Focuser: 2" Starlight Feather Touch with 3.5" sliding draw tube
- Coating: Super-Multicoating on all 4 Surfaces
- optical Design: doublet air-spaced Fraunhofer achromat
Weight: 40 pounds
F/ ratio: 5.9
Tube weight: 40 pound
asking Euro 4,950 Euro
thanks for your possible order
Markus Ludes
