LXD 75 ??
5 replies to this topic
#1 Rick Whitman
Rick Whitman
Posted 07 June 2009 - 01:56 PM
last night did polar alignment using kochab method.when i did alignment process alignment stars were ~15 degrees off.
during the process it ask daylight savings y/n of course i said y.should this have n since i'm doing my polar alignment with this method
thanx :crazy:
#2 rmollise
Posted 07 June 2009 - 02:10 PM
thanx :crazy:
It don't matter what you use for your polar alignment, DST must be ON right now. Fifteen degrees does sound like a time problem, however...double check Timezone and all other settings.
#3 Jerry3672
Jerry3672
    Vendor - Quantum Astronomy Products
Posted 07 June 2009 - 02:11 PM
When you say Kochab method do you mean using the polar scope and aligning the counter weight bar to Kochab?
The daylight savings should be set to yes if your area observes daylight savings time and you are in the daylight savings time of year. This sets the universal time to your local time so the alignment is correct.
If you were 15 degrees off then the incorrect time setting would explain the error. 1 degree for every 4 minuets is 15 degrees for one hour.
#4 Jerry3672
Jerry3672
Posted 07 June 2009 - 02:18 PM
Sorry Uncle Rod, my post must have been just behind you. I type slow, your answer wasn't posted when i started my reply. I'm glad we had the same answer :D
#5 Rick Whitman
Rick Whitman
Posted 07 June 2009 - 02:52 PM
yes jerry that waswhat i did
#6 Jerry3672
Jerry3672
Posted 07 June 2009 - 03:59 PM
Good, I do too. This method works well.
