Two MiniTower Questions
3 replies to this topic
#1 asteroid7
asteroid7
Posted 07 June 2009 - 06:31 PM
1. What is the purpose of Syn To Target and how do you go about it?
2. On the first page of the display the top two lines read: TRA and TDEC. What is this? Further down the display it reads RA and DEC.
Thank you
Rich
#2 Lenardo
Lenardo
Posted 07 June 2009 - 08:57 PM
#2 not sure
#1 you have done your alignment. do your First goto target and it's NOT quite centered, you click sync to target, use the arrow keys (reduce the mount speed to ~16X from the default 64x btw-took me 2 months to realize this)and center the target then press the center ok button. it further refines the alignment for the better.
#3 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
Posted 07 June 2009 - 09:02 PM
1) TRA is target RA and TDec is target declination.
2) Synch to target:
Matches the telescope's current equatorial coordinates to Target Right Ascension and Declination. You do this after you've centered the object.
If you don't have an owner's manual, download it here
#4 asteroid7
asteroid7
Posted 07 June 2009 - 10:50 PM
Thanks, guys.
